shopping cart scroll
Eric-P
Eric-P posted this 08 November 2015
Anyone know why after clicking on shopping cart window seems to be iframe or scroll it is not responsive and impossible to change, for virtuemart 3.
[url=http://postimage.org/][/url]
Hello, Anyone know why after clicking on shopping cart window seems to be iframe or scroll it is not responsive and impossible to change, for virtuemart 3. [url=http://postimage.org/][img]http://s4.postimg.org/4u27zrhvh/shopping_cart.jpg[/img][/url]
41 Comments
Support Team posted this 10 November 2015
could you please provide direct link to the shopping cart page that demonstrates the issue?
Hello, could you please provide direct link to the shopping cart page that demonstrates the issue? regards, Aileen
Eric-P
Eric-P posted this 11 November 2015
Hello to you,
in fact the site is locally on my computer, I already do the test on the internet, and the problem remains the same, the strangest is that demo versions that you submit online have the same problem when you reduce for mobile phones it y to an iframe, or scroll bar on the shopping cart page so this is a bug that developers have not seen, identified problem even in prestashop.
hebergeur dimage
prestashop
virtuemart
Hello to you, in fact the site is locally on my computer, I already do the test on the internet, and the problem remains the same, the strangest is that demo versions that you submit online have the same problem when you reduce for mobile phones it y to an iframe, or scroll bar on the shopping cart page so this is a bug that developers have not seen, identified problem even in prestashop. [url=http://postimage.org/][img]http://s18.postimg.org/ytjsc8ond/Capture_prestashop.png[/img][/url] [url=http://postimage.org/index.php?lang=french]hebergeur dimage[/url] [prestashop][1] [virtuemart][2] [1]: http://i1888099.prestashop.19.preview1-live.billiondigital.com/fr/order [2]: http://i1905078.joomla.23.preview1-live.billiondigital.com/index.php/shop/vm-shopping-cart/checkout_task
Eric-P
Eric-P posted this 13 November 2015
For me this is clearly a major bug, the basket page is not pretty with the bar in iframe scroll the preview is not beautiful on Tablet and smartphone, someone would have an idea to solve this problem. all cms are affected
Support Team posted this 16 November 2015
Sorry for the delay.
The cart summary table on the Shopping cart template is html <table></table> outputted by CMS.
This table behaves as usual table on small screens.
You can try adding some css to make the table columns behave as block (display: block;). But this is not perfect solution. And this solution is individual for each theme. It depends on the result you want to achieve.
Hi, Sorry for the delay. The cart summary table on the Shopping cart template is html `<table></table>` outputted by CMS. This table behaves as usual table on small screens. You can try adding some css to make the table columns behave as block (`display: block;`). But this is not perfect solution. And this solution is individual for each theme. It depends on the result you want to achieve. Thank you, Olivia
Eric-P
Eric-P posted this 16 November 2015
Thank you, I do the test but your method doesn't really, if you have something a can more concrete because the display on mobile phone is not pretty, this did not normal that this problem is present on all cms that you propose.
Support Team posted this 17 November 2015
Hello Perez,
lets try to find a solution exactly for your theme.
Please provide us with a link to your real site with shopping cart
Hello Perez, lets try to find a solution exactly for your theme. Please provide us with a link to your real site with shopping cart Regards, Aileen
Eric-P
Eric-P posted this 18 November 2015
Thank you for your reply, only currently I am working on my computer, so this is not possible at the moment, although I have other sites on the internet, I have seen a few tricks by activating bootstrap and the responsive, but the result remains small.
Eric
Thank you for your reply, only currently I am working on my computer, so this is not possible at the moment, although I have other sites on the internet, I have seen a few tricks by activating bootstrap and the responsive, but the result remains small. Eric
Support Team posted this 19 November 2015
Hello Perez,
I see that you're working mainly with Prestashop themes. We'll check what could be done about it and will let you know.
Hello Perez, I see that you're working mainly with Prestashop themes. We'll check what could be done about it and will let you know. Regards, Aileen
Support Team posted this 20 November 2015
Hello Perez,
as you may know the Themler themes are based on bootstrap. The scrollbar in responsive mode is cased by specific bootstrap settings which are not overwritten by Themler theme. The only solution is to reduce the size of all shopping cart elements and it will be done in Prestashop theme in one of the next updates.
Till then the custom CSS workaround may be applied to specific theme.
If you need help with it please provide us with the link to your page.
Hello Perez, as you may know the Themler themes are based on bootstrap. The scrollbar in responsive mode is cased by specific bootstrap settings which are not overwritten by Themler theme. The only solution is to reduce the size of all shopping cart elements and it will be done in Prestashop theme in one of the next updates. Till then the custom CSS workaround may be applied to specific theme. If you need help with it please provide us with the link to your page. regards, Aileen
Eric-P
Eric-P posted this 20 November 2015
Hello to you, thank you for your speed, this is good news for lovers of Prestashop, but there if my memory is good the problem is the same as for Virtuemart, I'll watch all ca.
a good day and thank you,
Eric
Hello to you, thank you for your speed, this is good news for lovers of Prestashop, but there if my memory is good the problem is the same as for Virtuemart, I'll watch all ca. a good day and thank you, Eric
Support Team posted this 21 November 2015
Hello Perez,
actually the issue with VirtueMart templates is the same, the same Bootstrap classes are applied.And the way to resolve is also the same.
Hello Perez, actually the issue with VirtueMart templates is the same, the same Bootstrap classes are applied.And the way to resolve is also the same. Regards, Aileen
floridachilds692
floridachilds692 posted this 06 May 2026
Managing scroll behavior in shopping cart layouts can really affect how smooth the browsing experience feels, especially on mobile screens where spacing and button placement matter a lot. A clean layout paired with comfortable styling choices like Soda Shoes chunky heel designs can make product pages feel more balanced and easier to navigate without overwhelming the user. Small interface improvements such as sticky cart sections and better spacing often help shoppers stay focused while browsing different fashion items.
Managing scroll behavior in shopping cart layouts can really affect how smooth the browsing experience feels, especially on mobile screens where spacing and button placement matter a lot. A clean layout paired with comfortable styling choices like [Soda Shoes][1] chunky heel designs can make product pages feel more balanced and easier to navigate without overwhelming the user. Small interface improvements such as sticky cart sections and better spacing often help shoppers stay focused while browsing different fashion items. [1]: https://sodashoesco.com/chunky-heels/
30websiteproject
30websiteproject posted this 07 May 2026
5555Bet Game Latest Earning App Download Now 2026 Online gaming keeps evolving and every now and then a new idea captures attention quickly. The number pattern creates a rhythm that players start recognizing after a few rounds. That combination is not easy to achieve but this game manages it well. Select your preferred game and begin with small bets to understand the flow. There is no need to spend too much time learning complex systems. The process is simple and does not require unnecessary steps. Many players are searching for simple games that offer quick engagement and smooth performance. Why Players Are Switching to 5555Bet Game Many users are moving toward this game because it offers something fresh. What Makes
[5555Bet][1] Game Latest Earning App Download Now 2026 Online gaming keeps evolving and every now and then a new idea captures attention quickly. The number pattern creates a rhythm that players start recognizing after a few rounds. That combination is not easy to achieve but this game manages it well. Select your preferred game and begin with small bets to understand the flow. There is no need to spend too much time learning complex systems. The process is simple and does not require unnecessary steps. Many players are searching for simple games that offer quick engagement and smooth performance. Why Players Are Switching to 5555Bet Game Many users are moving toward this game because it offers something fresh. What Makes [1]: https://apksfold.com/5555bet/
30websiteproject
30websiteproject posted this 08 May 2026
Almost every tech tool I have been using for the past three years has some AI feature baked into it now. Visit for more information Free AI tools list
Almost every tech tool I have been using for the past three years has some AI feature baked into it now. Visit for more information [Free AI tools list][1] [1]: https://www.freeaitoolscafe.com/
30websiteproject
Explore the best IPTV Dubai subscription services with HD live channels, movies, sports, and fast streaming across the UAE. https://iptvdubaimax.com/
30websiteproject
30websiteproject posted this 13 May 2026
Learn how to solve percentage problems easily using the Dreisatz method with simple step-by-step explanations, clear formulas, and real-life examples. https://rechnerdreisatz.de/
Learn how to solve percentage problems easily using the Dreisatz method with simple step-by-step explanations, clear formulas, and real-life examples. [https://rechnerdreisatz.de/][1] [1]: https://rechnerdreisatz.de/
30websiteproject
Zcash is also become easier to access and use. Robinhood’s heel afford ZEC to a bombastic retail user base, while THORChain, Near Intents, Zodl, and a growing number of bridges are expanding deconcentrate access to the Zcash ecosystem. At the same time, nearly 31% of circulating ZEC is now admit in shielded pools, suggesting meaningful acceptation of its core privacy features. If shielded ZEC equipoise rise further, it could indicate that recent buyers are not equitable chasing momentum, but intend to hold ZEC for the long term. Of course, it’s important to support in mind that Zcash has just seen a dramatic price spike (the coin is up about 40% in the last week), so a astute price correction in Best crypto wallets
Zcash is also become easier to access and use. Robinhood’s heel afford ZEC to a bombastic retail user base, while THORChain, Near Intents, Zodl, and a growing number of bridges are expanding deconcentrate access to the Zcash ecosystem. At the same time, nearly 31% of circulating ZEC is now admit in shielded pools, suggesting meaningful acceptation of its core privacy features. If shielded ZEC equipoise rise further, it could indicate that recent buyers are not equitable chasing momentum, but intend to hold ZEC for the long term. Of course, it’s important to support in mind that Zcash has just seen a dramatic price spike (the coin is up about 40% in the last week), so a astute price correction in [Best crypto wallets][1] [1]: https://www.cryptoupdatesnow.site/
30websiteproject
30websiteproject posted this 14 May 2026
GPT32 is an online earning platform that allows users to start with a small investment and generate returns through its digital dashboard system https://gpt32.net/
30websiteproject
30websiteproject posted this 17 May 2026
PAK Super Game APK is a real money earning app designed for players in Pakistan. It offers exciting slot machines, card games like Teen Patti and Andar Bahar, and daily bonuses. https://superpak.com.pk/
PAK Super Game APK is a real money earning app designed for players in Pakistan. It offers exciting slot machines, card games like Teen Patti and Andar Bahar, and daily bonuses. [https://superpak.com.pk/][1] [1]: https://superpak.com.pk/
30websiteproject
30websiteproject posted this 18 May 2026
A.W. Martin Construction & Restoration Services provides professional home remodeling, renovation, and restoration solutions in New Jersey with quality craftsmanship and reliable service. https://awmartin.com/
A.W. Martin Construction & Restoration Services provides professional home remodeling, renovation, and restoration solutions in New Jersey with quality craftsmanship and reliable service. [https://awmartin.com/][1] [1]: https://awmartin.com/
