Where can I change the text in the footer ( Joomla template created with Themler ) ?
Unfortunately, nowhere find what
You can remove that text within the application. Just remove the Backward links control. Or add your own text control with the desired footnote.
Thank you.
Just where do I find this application exactly ? Unfortunately can not find anything in Themler ?
Are you able to open the template in the Themler editor? Then click on the link itself. The backward Links control will be highlighted, then press Del and it should be deleted.
Where exactly do you, "Or add your own text control with the desired footnote. "? I would like to add my own link there rather than themelers. Seems like you could edit this within the app so we could use it by default.
> Hi, > > You can remove that text within the application. Just remove the Backward links control. Or add your own text control with the desired footnote. > > Sincerely, > Hella Where exactly do you, "Or add your own text control with the desired footnote. "? I would like to add my own link there rather than themelers. Seems like you could edit this within the app so we could use it by default.Hi,
You can not edit that exact control but you can remove the Themler backward links control and then add the Text control and type your own details there.
I can't remove backward links
no cross to del it on the control, and del key don't del the control
Can you help me?
Sorry for my poor English... I am French
Hi there
I had the same problem....
You can edit/switch off the backlinks in the settings of your theme.
Go to Home->Settings. Scroll down to DESCREPTION and edit/switch off your backlinks.
See also http://answers.themler.io/articles/96550/theme-settings
Themler v.418
Regards, Tobi
Hi there I had the same problem.... **You can edit/switch off the backlinks in the settings of your theme.** Go to Home->Settings. Scroll down to DESCREPTION and edit/switch off your backlinks. See also http://answers.themler.io/articles/96550/theme-settings Themler v.418 Regards, Tobi [1]: http://answers.themler.io/articles/96550/theme-settingsHi there
See also http://answers.themler.io/articles/96550/theme-settingsThemler v.418
Regards, Tobi
Thank you for your answer
> Hi there > > I had the same problem.... > > **You can edit/switch off the backlinks in the settings of your theme.** > Go to Home->Settings. Scroll down to DESCREPTION and edit/switch off your backlinks. > See also http://answers.themler.io/articles/96550/theme-settings > > Themler v.418 > > Regards, Tobi > > > [1]: http://answers.themler.io/articles/96550/theme-settings Thank you for your answer
