I'm using Themler for a static html site. I want to use some external scripts so I can create a random image and a slideshow. I need to create a folder to do this.
I'm aware that if I create a folder, it will disappear once Themler refreshes content unless I write protect the folder. Thi sis referenced elsewhere in the forum.
I think this is a bug - you should be able to use external scripts etc. without having to write protect anything. It would be nice not to have to worry about this.
Many thanks, David
P.S. I must say that the support I am getting is excellent
Hi I'm using Themler for a static html site. I want to use some external scripts so I can create a random image and a slideshow. I need to create a folder to do this. I'm aware that if I create a folder, it will disappear once Themler refreshes content unless I write protect the folder. Thi sis referenced elsewhere in the forum. I think this is a bug - you should be able to use external scripts etc. without having to write protect anything. It would be nice not to have to worry about this. Many thanks, David P.S. I must say that the support I am getting is excellent
