After a lot of editing templates in CMS it became very apparent that working in desktop Themler is faster and the preferred workflow. So, when I export a zip file from CMS and import from that zip into Themler desktop, I have a lot of 'left over' formatting and content from the default Themler template. Even when you select File>New and then import, you're still not working from a blank canvas. Am I doing something wrong or is there a way around this?
From desktop Themler I saved as a zip file, the originally CMS exported project and re-imported back into my CMS. Everything looks the same in the CMS as it originally did, so there's none of the extra formatting I saw on desktop Themler. So my ideal scenario would to have both desktop and CMS templates display the same layout.
After a lot of editing templates in CMS it became very apparent that working in desktop Themler is faster and the preferred workflow. So, when I export a zip file from CMS and import from that zip into Themler desktop, I have a lot of 'left over' formatting and content from the default Themler template. Even when you select File>New and then import, you're still not working from a blank canvas. Am I doing something wrong or is there a way around this? From desktop Themler I saved as a zip file, the originally CMS exported project and re-imported back into my CMS. Everything looks the same in the CMS as it originally did, so there's none of the extra formatting I saw on desktop Themler. So my ideal scenario would to have both desktop and CMS templates display the same layout.
