What is the easiest way to adjust layout for all devices?
cpetersen
cpetersen posted this 13 November 2015
I am getting frustrated with trying to figure out how to best adjust each device layout. Is there an easier way to accomplish the resizing process, especially the menus? Also, is there a way to have something NOT show up on a device? meaning, can I hide any elements? Sample attached is my try at adjusting on a tablet device with no success.
Support Team posted this 14 November 2015
You can go to the Menu >> Responsive >> Switch to responsive and set it to Tablets. Then the menu will collapse into the responsive mode starting from tablets.
Also you can disable any element for the specific responsive mode using the icons in the Display On option like shown on the screen shot:
Hi, You can go to the Menu >> Responsive >> Switch to responsive and set it to Tablets. Then the menu will collapse into the responsive mode starting from tablets. Also you can disable any element for the specific responsive mode using the icons in the Display On option like shown on the screen shot: !display-on.png! Sincerely, Hella
cpetersen
cpetersen posted this 16 November 2015
Thanks for your response. I'm still a bit confused. Is your sample image talking only about the menu resizing or how to resize the entire device's layout? Because I also need to know what is the easiest way to adjust the device's layout without having to click on every item and resizing them. Can this be done in one action? Please advise. thanks
cpetersen
P.s...I would like to also add to my prior post about resizing the entire layouts as per devices....when it comes to the tablet (ipad for example) it looks like it resizes for a portrait window and not a landscape window. How do you make it resize for either direction? Thanks
Support Team posted this 18 November 2015
please refer to this topic
http://answers.themler.com/questions/5110/responsive-design
which explains how to adapt image, slider images sizes for the different screen sizes.
As for portrait and landscape modes, unfortunately the landscape is not supported in Themler however if you set up page to look good in Portrait mode it should be OK in Landscape as well.
Let us know if you get any problem with it.
Hello, please refer to this topic http://answers.themler.com/questions/5110/responsive-design which explains how to adapt image, slider images sizes for the different screen sizes. As for portrait and landscape modes, unfortunately the landscape is not supported in Themler however if you set up page to look good in Portrait mode it should be OK in Landscape as well. Let us know if you get any problem with it. Regards, Aileen
cpetersen
cpetersen posted this 19 November 2015
thank you! P.s....I thought I viewed somewhere a video that showed how as well? I can't seem to find it again. Can you please send me a link to it? Thanks
Support Team posted this 20 November 2015
Unfortunately I'm not sure what exact video you are talking about. Please refer to the videos on our channel:
https://www.youtube.com/user/BillionThemler/videos
Hi, Unfortunately I'm not sure what exact video you are talking about. Please refer to the videos on our channel: https://www.youtube.com/user/BillionThemler/videos Sincerely, Hella
elk52442
elk52442 posted this 16 October 2025
Boost your preparation with reliable, expert-verified study materials designed for real exam success. Each topic is explained clearly to strengthen your understanding of technical analysis and trading concepts. The CMT Level II Questions and Answers from ACE4Sure provide accurate, updated content that mirrors the real exam format. With detailed explanations and practical insights, ACE4Sure helps you build confidence, master complex topics, and pass your CMT Level II exam successfully on your very first attempt.
Boost your preparation with reliable, expert-verified study materials designed for real exam success. Each topic is explained clearly to strengthen your understanding of technical analysis and trading concepts. The **[CMT Level II Questions and Answers][1]** from **ACE4Sure** provide accurate, updated content that mirrors the real exam format. With detailed explanations and practical insights, **ACE4Sure** helps you build confidence, master complex topics, and pass your **CMT Level II exam** successfully on your very first attempt. [1]: https://www.ace4sure.com/CMT-Level-II-questions.html
