Separate Drupal instance for each themler theme
me321
me321 posted this 17 November 2015
Dear Themler,
I would like to suggest an improvement for the desktop client of Themler.
Currently, it re-uses the same Drupal instance for each theme. So if I have 5 themes then all of the regions of all of the themes get exported int each and every theme, unless I disable all the themes except the one I'm working on. And also all the content I add for testing themes and their blocks start getting in the way when working on multiple themes.
It would be much easier if a new drupal site is provisioned for each theme. Because now I have to constantly disable all the themes and their preview variants and I still am left will a large amount of blocks and nodes that are all getting seriously in the way. When you've created more than 3 themes with Themler this becomes a serious and time consuming usability issue.
Maybe an approach like the Acquia Desktop takes would be worth looking at.
Thanks and keep up the good work!
Dear Themler, I would like to suggest an improvement for the desktop client of Themler. Currently, it re-uses the same Drupal instance for each theme. So if I have 5 themes then all of the regions of all of the themes get exported int each and every theme, unless I disable all the themes except the one I'm working on. And also all the content I add for testing themes and their blocks start getting in the way when working on multiple themes. It would be much easier if a new drupal site is provisioned for each theme. Because now I have to constantly disable all the themes and their preview variants and I still am left will a large amount of blocks and nodes that are all getting seriously in the way. When you've created more than 3 themes with Themler this becomes a serious and time consuming usability issue. Maybe an approach like the Acquia Desktop takes would be worth looking at. Thanks and keep up the good work!
Support Team posted this 19 November 2015
I've added your suggestion to our wish list.
In the meantime please try the suggestion I posted in this topic.
Hi, I've added your suggestion to our wish list. In the meantime please try the suggestion I posted in [this][1] topic. Thank you, Olivia [1]: http://answers.themler.com/questions/30475/lots-of-unusable-legacy-regions
