Headline and Slogan Editing
Krishnarup
Krishnarup posted this 01 December 2014
Can't change the text in "Headline" or "Slogan", none of them is editable. Any help ?
Hi, Can't change the text in "**Headline**" or "**Slogan**", none of them is editable. Any help ?
28 Comments
Support Team posted this 01 December 2014
Hello Krishnarup,
If you mean default Headline and Slogan text in Themler themes - it can be changed from CMS backend (File >> CMS Admin Panel).
For example, for Wordpress themes the text of Headline and Slogan Controls can be changed under the Settings >> General >> Site Title and Tagline.
In Joomla the text of the Headline and Slogan controls can be changed under Joomla Template Manager >> Styles >> click your Themler template's name >> Details >> Headline and Slogan.
Best regards,
Hello Krishnarup, If you mean default Headline and Slogan text in Themler themes - it can be changed from CMS backend (**File** >> **CMS Admin Panel**). For example, for Wordpress themes the text of Headline and Slogan Controls can be changed under the **Settings** >> **General** >> **Site Title and Tagline**. In Joomla the text of the Headline and Slogan controls can be changed under **Joomla Template Manager** >> **Styles** >> click your Themler template's name >> **Details** >> **Headline and Slogan**. Best regards, Nettie, BillionDigital Team
Krishnarup
Thanks for the quick response.
Krishnarup, you are welcome!
Krishnarup, you are welcome! Sincerely, Nettie, BillionDigital Team
Gillips
Gillips posted this 18 March 2016
I know how to add this in the CMS backend, but how to you insert these items into the template header in Themler in the first place? A basic question I realise, but that's where I'm at. I've managed, I think, to create a 'header' area: now how do I put the site title and slogan, and perhaps other elements, within it?
Support Team posted this 19 March 2016
Go to the Insert tab >> More and there will be Headline and Slogan controls. Insert them into the header.
Hi, Go to the Insert tab >> More and there will be Headline and Slogan controls. Insert them into the header. Sincerely, Hella
Gillips
Gillips posted this 20 March 2016
thanks.
thanks.
Support Team posted this 20 March 2016
You are welcome.
You are welcome. Sincerely, Hella
rgfuller
rgfuller posted this 12 May 2017
In v357 the Headline editor does not respond to color changes. Everything else seems to work.. font family, size, weight, and transform, but the color picker doesn't work. Please help.
Support Team posted this 13 May 2017
Headline is a link. Please change link color.
Hi, Headline is a link. Please change link color. Thank you, Olivia
info1605
info1605 posted this 09 August 2017
Why can't I edit the headline in the template to reflect what I want it to say so that I can see how it looks? Why is it only after the template is in the cms?
Support Team posted this 10 August 2017
That is because Themler works with the live content. And as long as the headline is possible to edit from the CMS back end, we can not edit it inside the application.
Hi, That is because Themler works with the live content. And as long as the headline is possible to edit from the CMS back end, we can not edit it inside the application. Sincerely, Hella
alexarafatonline
alexarafatonline posted this 26 May 2025
Hey, I had the same issue with editing the "Headline" and "Slogan" text. What helped me was switching to the VN MOD APK, which is a free and popular video editor for Android. You can import videos, trim, adjust speed, add effects, animations, fonts, stickers, and much more. I got it from https://thevnapks.com/ and it worked perfectly for my editing needs. Give it a try!
philljones0022
philljones0022 posted this 18 November 2025
Tower War Mod APK provides players with unlimited resources and unlocked features, enhancing the classic tower defense gameplay. Players can experiment with different strategies, upgrade towers freely, and dominate challenging levels. With smoother gameplay and extra advantages, Tower War Mod APK delivers an exciting and strategic experience.
[Tower War Mod APK][1] provides players with unlimited resources and unlocked features, enhancing the classic tower defense gameplay. Players can experiment with different strategies, upgrade towers freely, and dominate challenging levels. With smoother gameplay and extra advantages, Tower War Mod APK delivers an exciting and strategic experience. [1]: https://riseapk.org/tower-war-mod-apk/
troutjohnson88
troutjohnson88 posted this 03 December 2025
“Avatar World Mod APK gives players access to unlocked items and customization options that aren’t available in the regular version, which is why a lot of people look into it. Just keep in mind it’s not the official release, so you should always be careful about where you download from and understand the risks that come with modified apps. If you’re just trying to learn more about it, you can check out the details here: https://avatarwrldapk.com
— it explains what’s included and how it differs from the standard game.”
“Avatar World Mod APK gives players access to unlocked items and customization options that aren’t available in the regular version, which is why a lot of people look into it. Just keep in mind it’s not the official release, so you should always be careful about where you download from and understand the risks that come with modified apps. If you’re just trying to learn more about it, you can check out the details here: https://avatarwrldapk.com — it explains what’s included and how it differs from the standard game.”
Abbas Khan
Abbas Khan posted this 21 December 2025
Inat Box Pro is a mobile application offering a wide range of content in Turkish and other languages. Specifically designed for Turkish users, it offers thousands of Turkish and international channels, including sports, drama, news, and entertainment. With inatbox apk, your smartphone transforms into a streaming platform, allowing you to enjoy a variety of content for free.
Inat Box Pro is a mobile application offering a wide range of content in Turkish and other languages. Specifically designed for Turkish users, it offers thousands of Turkish and international channels, including sports, drama, news, and entertainment. With **[inatbox apk][1]**, your smartphone transforms into a streaming platform, allowing you to enjoy a variety of content for free. [1]: https://inatboxapkindirin.com.tr/
oswaldo3
oswaldo3 posted this 21 December 2025
Armoury Crate latest version brings bug fixes, better stability, and improved RGB syncing. Updating ensures compatibility with new ASUS hardware and gives smoother control over performance profiles. armoury crate offline installer
Armoury Crate latest version brings bug fixes, better stability, and improved RGB syncing. Updating ensures compatibility with new ASUS hardware and gives smoother control over performance profiles. [armoury crate offline installer][1] [1]: https://armorycrate.com/
oswaldo3
oswaldo3 posted this 22 December 2025
Can’t say enough good things about Appliance Repair Las Cruces! They fixed my oven quickly, explained the issue, and were super professional. If you need appliance repair in Las Cruces, these are the folks to call. dryer repair
Can’t say enough good things about Appliance Repair Las Cruces! They fixed my oven quickly, explained the issue, and were super professional. If you need appliance repair in Las Cruces, these are the folks to call. [dryer repair][1] [1]: https://appliancerepairlascruces.com/
oswaldo3
oswaldo3 posted this 23 December 2025
The Potbelly sandwich shop menu guide makes ordering smoother and faster. how much is a potbelly sandwich
The Potbelly sandwich shop menu guide makes ordering smoother and faster. [how much is a potbelly sandwich][1] [1]: https://thepotbellymenu.com/
oswaldo3
oswaldo3 posted this 29 December 2025
Dojen Moe seems pretty cool and I’m intrigued to explore more. From what I’ve seen so far, it could be useful for a lot of different purposes. I’d love to hear from anyone who has experience using it and how they found it in daily use. dojen moe
Dojen Moe seems pretty cool and I’m intrigued to explore more. From what I’ve seen so far, it could be useful for a lot of different purposes. I’d love to hear from anyone who has experience using it and how they found it in daily use. [dojen moe][1] [1]: https://glowyp.com/dojen-moe/
philljones0022
philljones0022 posted this 05 January 2026
Kinemaster Mod APK offers an enhanced video editing experience by giving users access to premium tools and features without limitations. It allows creators to apply advanced effects, smooth transitions, and high-quality exports for professional results. Ideal for mobile editors, Kinemaster Mod APK makes video creation more flexible, creative, and efficient.
Kinemaster Mod [APK][1] offers an enhanced video editing experience by giving users access to premium tools and features without limitations. It allows creators to apply advanced effects, smooth transitions, and high-quality exports for professional results. Ideal for mobile editors, Kinemaster Mod APK makes video creation more flexible, creative, and efficient. [1]: https://prokinmasterapk.com/
