Sugest for developer
designdrago
designdrago posted this 18 November 2015
Hi again,
I use a lot of software Dreamweaver , WYSIWYG Web Builder , Adobe Muse, Bootsap ,...etc, among the best Thempler but I used one softwer its Pinegrow, which is nice but for person which know coding and more must know to work with him, but he have very interesting tools which when you click at any object or section have solutions in tools to you can see Html code and another tools where you can see css -stylesheets, it is will be great if your developer can do in THEMLER that options for many reasons, first - themler owner can learning code and stylesheets rules, second it's easy way to add code.
Second my idea is new tools - File Publisher, where you can add - example scripts, download part - pdf exampe word etc.
I use many programs as graphic designers , and most of that I bought them yet missed some details be perfect for users who are not as educated in coding and such is the most as customers , I would like to develope team thinking in that direction
That is one of my more ideas :D to be best
Hi again, I use a lot of software Dreamweaver , WYSIWYG Web Builder , Adobe Muse, Bootsap ,...etc, among the best Thempler but I used one softwer its Pinegrow, which is nice but for person which know coding and more must know to work with him, but he have very interesting tools which when you click at any object or section have solutions in tools to you can see Html code and another tools where you can see css -stylesheets, it is will be great if your developer can do in THEMLER that options for many reasons, first - themler owner can learning code and stylesheets rules, second it's easy way to add code. Second my idea is new tools - File Publisher, where you can add - example scripts, download part - pdf exampe word etc. I use many programs as graphic designers , and most of that I bought them yet missed some details be perfect for users who are not as educated in coding and such is the most as customers , I would like to develope team thinking in that direction That is one of my more ideas :D to be best
Vitaliy WD
Vitaliy WD posted this 18 November 2015
+1 for that. But need to create separate topic with this idea.
> tools which when you click at any object or section have solutions in > tools to you can see Html code and another tools where you can see css > -stylesheets, it is will be great if your developer can do in THEMLER that options for many reasons, first - themler owner can learning code > and stylesheets rules, second it's easy way to add code. +1 for that. But need to create separate topic with this idea.
Support Team posted this 20 November 2015
Thanks for the suggestion.
Actually you can see all the CSS applied to the control using the Inspect element tool and add the desired CSS under the Settings >> Additional CSS tab.
In any case, our developers have already implemented the following option: you will be able to see all the styles applied to the control from the different levels. So there would be styles set for this particular control and also all the inherited styles will be listed as well with the references from which control that style is inherited.
This option should be available in the next major update.
Hi, Thanks for the suggestion. Actually you can see all the CSS applied to the control using the Inspect element tool and add the desired CSS under the Settings >> Additional CSS tab. In any case, our developers have already implemented the following option: you will be able to see all the styles applied to the control from the different levels. So there would be styles set for this particular control and also all the inherited styles will be listed as well with the references from which control that style is inherited. This option should be available in the next major update. Sincerely, Hella
designdrago
designdrago posted this 20 November 2015
Thanks Hella and Team,
I know that options / inspect Elements - Settings ...etc / , it is nice to hear to have in future update control styles in diferent levels, i have few sugestions for your developer, that is what is need most web designer,
1. Options - Send Back Send To Front - that tools is very useful / Why this / - Sometimes design requires such a that solution, example footer http://www.vintageheirloom.com/, , few times i write code and that part It was at front of all other objects / header, footer etc /
  1. In Animation - Options drag and drop to be Animation before other / the same options as the Pages control of the project will be the first and the last ,see attacments.
  2. Tools / Show - Hide - If they have this option in this case could have a modal layer in side toolbars and pop advertising layer , which is now a trend in design websites that are activated later. etc, I know You say that the third part, but we as designer like to be more easy for us, also i see to have more software that as tools in side toolbars.
WE TRY TO BE BEST
Thank You
Thanks Hella and Team, I know that options / inspect Elements - Settings ...etc / , it is nice to hear to have in future update control styles in diferent levels, i have few sugestions for your developer, that is what is need most web designer, 1. Options - Send Back Send To Front - that tools is very useful / Why this / - Sometimes design requires such a that solution, example footer http://www.vintageheirloom.com/, , few times i write code and that part It was at front of all other objects / header, footer etc / 2. In Animation - Options drag and drop to be Animation before other / the same options as the Pages control of the project will be the first and the last ,see attacments. 3. Tools / Show - Hide - If they have this option in this case could have a modal layer in side toolbars and pop advertising layer , which is now a trend in design websites that are activated later. etc, I know You say that the third part, but we as designer like to be more easy for us, also i see to have more software that as tools in side toolbars. WE TRY TO BE BEST Thank You
Support Team posted this 23 November 2015
thank you for your suggestions.
Let also other users vote for them.
Hello, thank you for your suggestions. Let also other users vote for them. regards, Aileen
