Editable content in Wordpress
anneke
anneke posted this 01 December 2014
Would be great when it will be available to edit content in Wordpress backend like Artisteer.
The current way does not work properly. It's devious.
I hope it will be available soon. Think it's a crucial function.
Kind regards,
Would be great when it will be available to edit content in Wordpress backend like Artisteer. The current way does not work properly. It's devious. I hope it will be available soon. Think it's a crucial function. Kind regards,
34 Comments
Support Team posted this 01 December 2014
Hello Anneke,
Themler allows to apply design to displayed content. It's not in our plans to allow editing content inside Themler. You see that you may open the CMS admin back end and edit content and then open theme and edit it in Themler directly from your CMS. So there just no need in editing content in Themler.
Also I'd like to say that you may add a kind of static content (that is considered as part of the theme) inside Themler. I mean images, custom text blocks and event HTML code blocks which may be added with the help of Themler's controls.
Hello Anneke, Themler allows to apply design to displayed content. It's not in our plans to allow editing content inside Themler. You see that you may open the CMS admin back end and edit content and then open theme and edit it in Themler directly from your CMS. So there just no need in editing content in Themler. Also I'd like to say that you may add a kind of static content (that is considered as part of the theme) inside Themler. I mean images, custom text blocks and event HTML code blocks which may be added with the help of Themler's controls. regards, Aileen
anneke
That's true. But for editing content in the CMS (wordpress) you nee to use the primary widget area. That's the only way to show different content on the pages.
If I add (static) content inside Themler, it will be visible at all pages. So the only way to give each page is own content is use the widget area in Wordpress (but the widget area is actually not made for that).
I could have missed something, then let me know please.
kind regards,
Hi, That's true. But for editing content in the CMS (wordpress) you nee to use the primary widget area. That's the only way to show different content on the pages. If I add (static) content inside Themler, it will be visible at all pages. So the only way to give each page is own content is use the widget area in Wordpress (but the widget area is actually not made for that). I could have missed something, then let me know please. kind regards,
well, in fact you create and edit content in CMS. I mean that for example you create a new page in WP admin back end, add the link to this page to primary navigation menu. Then create another page and add link to it to menu, etc. So you have several different pages on your WP site. When you open the theme in Themler you'll see all these pages in Themler. However it is not possible to edit pages' content in Themler.
On the other hand you may add widgets to different widget areas, that also means that you create dynamic content which may be different on different pages.
I would recommend that you refer to several videos which demonstrate how to work with WP theme in Themler
https://www.youtube.com/watch?v=hTNOkaQKXts
https://www.youtube.com/watch?v=CtBQBb7-Gdc
https://www.youtube.com/watch?v=MBgiVaZZYpY
Hi, well, in fact you create and edit content in CMS. I mean that for example you create a new page in WP admin back end, add the link to this page to primary navigation menu. Then create another page and add link to it to menu, etc. So you have several different pages on your WP site. When you open the theme in Themler you'll see all these pages in Themler. However it is not possible to edit pages' content in Themler. On the other hand you may add widgets to different widget areas, that also means that you create dynamic content which may be different on different pages. I would recommend that you refer to several videos which demonstrate how to work with WP theme in Themler https://www.youtube.com/watch?v=hTNOkaQKXts https://www.youtube.com/watch?v=CtBQBb7-Gdc https://www.youtube.com/watch?v=MBgiVaZZYpY Regards, Aileen
anneke
I think didn't explain my problem very well.
I switched to the wordpress backend and added pages succesfully(also linked to the menu). But when I add content to a page (so not the homepage), this content will show up at all 'normal pages'. See for example the attached images.
In this case I used the text control.
On what way can I add the text I entered in the wordpress backend? (example image 2).
Each page needs to get his own content.
Hope you can help.
Thanks in advance,
Hi, I think didn't explain my problem very well. I switched to the wordpress backend and added pages succesfully(also linked to the menu). But when I add content to a page (so not the homepage), this content will show up at all 'normal pages'. See for example the attached images. In this case I used the text control. On what way can I add the text I entered in the wordpress backend? (example image 2). Each page needs to get his own content. Hope you can help. Thanks in advance,
Support Team posted this 02 December 2014
Seems that you are missing the control that will output your CMS content. Please add the Post Content control in the Page template, it will look like on the screen shot:
Hi, Seems that you are missing the control that will output your CMS content. Please add the Post Content control in the Page template, it will look like on the screen shot: !content-wp.png! Sincerely, Hella BillionDigital Team
anneke
anneke posted this 02 December 2014
Thanks, that's what I mean!
I thought the post content control was for the blog (posts in wordpress are different things as pages) that was why I was confused :)
Kind regards,
Thanks, that's what I mean! I thought the post content control was for the blog (posts in wordpress are different things as pages) that was why I was confused :) Kind regards,
Nice to hear that it is clear now.
I'll mark this case as solved, feel free to contact us in case of any other questions.
Nice to hear that it is clear now. I'll mark this case as solved, feel free to contact us in case of any other questions. Sincerely, Hella BillionDigital Team
shaulhadar
shaulhadar posted this 08 April 2015
Maybe making a different control to post content and page content would make more sense......please consider this...
Support Team posted this 09 April 2015
Hello Shaul,
in the next Themler update the new approach to page layout and content controls will be used. It would be possible to enable and disable page main content area. When you enable it all necessary controls which are used to output are "added". Also this method would be same for all templates.
You may read more about this new feature in the article
http://answers.billiondigital.com/articles/9037/sidebars
Please let us know if you have additional questions.
Hello Shaul, in the next Themler update the new approach to page layout and content controls will be used. It would be possible to enable and disable page main content area. When you enable it all necessary controls which are used to output are "added". Also this method would be same for all templates. You may read more about this new feature in the article http://answers.billiondigital.com/articles/9037/sidebars Please let us know if you have additional questions. Regards, Aileen
Stagger Lee posted this 09 April 2015
Can you please fix URL, leading to Access Denied page.
Hi Lee,
I'm sorry for the inconvenience, I updated the URL in the previous post.
Here is it as well
Hi Lee, I'm sorry for the inconvenience, I updated the URL in the previous post. Here is it as well http://answers.billiondigital.com/articles/9037/sidebars Regards, Aileen
zuyev-vadik
zuyev-vadik posted this 24 August 2023
Ремонт электронных модулей (блоков) производим только после диагностики стиральной машины в целом мастером нашего сервисного центра, связано это с огромным количеством электроники которую нам приносили в ремонт, как правило оказывалась исправной и ремонта не требовала https://zapchasti-remont.ru/shop/MURRAY_SNAPPER_SIMPLICITY/
Кроме того есть еще ряд подводных камней (например замыкание внутри, после ремонта установленный модуль на стиральную машину тут же сгорал ) из за которых пришлось отказаться от ремонта электронного модуля отдельно без диагностики https://zapchasti-remont.ru/shop/goods/koleso_vedomoe_dlya_usenitsyi_snegouborschika-2541
Мы не будем держать автомобиль в заложниках, кормя обещаниями, что вот-вот закончим работу — после оценки Вы сразу узнаете точный срок выполнения работ https://zapchasti-remont.ru/shop/goods/filtr_vozdushnyiy_594201_796031_591334_590825_dlya_dvigateley_Briggs_Stratton_Intek_OHV_175_Hr-10993
Ремонт электронных модулей (блоков) производим только после диагностики стиральной машины в целом мастером нашего сервисного центра, связано это с огромным количеством электроники которую нам приносили в ремонт, как правило оказывалась исправной и ремонта не требовала https://zapchasti-remont.ru/shop/MURRAY_SNAPPER_SIMPLICITY/ Кроме того есть еще ряд подводных камней (например замыкание внутри, после ремонта установленный модуль на стиральную машину тут же сгорал ) из за которых пришлось отказаться от ремонта электронного модуля отдельно без диагностики https://zapchasti-remont.ru/shop/goods/koleso_vedomoe_dlya_usenitsyi_snegouborschika-2541 Мы не будем держать автомобиль в заложниках, кормя обещаниями, что вот-вот закончим работу — после оценки Вы сразу узнаете точный срок выполнения работ https://zapchasti-remont.ru/shop/goods/filtr_vozdushnyiy_594201_796031_591334_590825_dlya_dvigateley_Briggs_Stratton_Intek_OHV_175_Hr-10993
quartoere1987
quartoere1987 posted this 20 October 2023
Мы предлагаем передвижной шиномонтаж в Москве с набором уникальных преимуществ, которые делают нас идеальным выбором для вашего автомобиля https://24shina.moscow/prikurka-avto
Без доп https://24shina.moscow/motoshinomontazh
услуг Хранение резины без дисков (4 колеса) 7 мес 3490 - 15% = 2970! Хранение резины на дисках (4 колеса) 7 мес 3990 - 15% = 3390!
При заказе услуг выездного шиномонтажа для 2х авто и более - скидки https://24shina.moscow/
Плюс бонус за хранение https://24shina.moscow/shinomontazh
Шиномонтаж на колесах москва https://24shina.moscow/shinomontazh
Квалифицированные мастера нашего сервиса проходят профессиональное обучение перед вступлением в должность https://24shina.moscow/shinomontazh
Обращаясь к нам, Вы доверяете автомобиль первоклассным специалистам в сфере шиномонтажа https://24shina.moscow/snyatie-sekretok
Мы предлагаем передвижной шиномонтаж в Москве с набором уникальных преимуществ, которые делают нас идеальным выбором для вашего автомобиля https://24shina.moscow/prikurka-avto Без доп https://24shina.moscow/motoshinomontazh услуг Хранение резины без дисков (4 колеса) 7 мес 3490 - 15% = 2970! Хранение резины на дисках (4 колеса) 7 мес 3990 - 15% = 3390! При заказе услуг выездного шиномонтажа для 2х авто и более - скидки https://24shina.moscow/ Плюс бонус за хранение https://24shina.moscow/shinomontazh Шиномонтаж на колесах москва https://24shina.moscow/shinomontazh Квалифицированные мастера нашего сервиса проходят профессиональное обучение перед вступлением в должность https://24shina.moscow/shinomontazh Обращаясь к нам, Вы доверяете автомобиль первоклассным специалистам в сфере шиномонтажа https://24shina.moscow/snyatie-sekretok * в наличии колодки и тормозные диски для всех марок авто https://24shina.moscow/zapravka-kondicionera
tacusol-6816
tacusol-6816 posted this 20 October 2023
Внимание! Владельцы и создатели данного сайта не несут ответственность за использование ссылок и информации, представленных на этом сайте, добавленной пользователями сайта в свободной форме в виде сообщений на форуме, а так же комментариям к материалам, статьям, новостям https://www.legnostyle.ru/catalog/kuhni/?PAGEN_1=4
Российские импортёры сельскохозяйственной продукции активно закупают овощи и фрукты в Китае https://www.legnostyle.ru/modyli-dlia-kyhni.html?PAGEN_2=2
Ожидается, что объём сделок в ближайшее время достигнет 7,25 млн долларов https://www.legnostyle.ru/catalog/mebel/shkafy-sekcii-gorki/scg-8.html
Самые читаемые записи
Ценными породами в российских реалиях считаются дуб, ясень и орех https://www.legnostyle.ru/furnitura-lestnicy.html
Мебель для кабинета руководителя получается стильной и красивой, так как каждая порода отличается оригинальным рисунком https://www.legnostyle.ru/catalog/nashi-raboty/inter-er-zagorodnogo-doma-k5.html
Дуб знаменит крупными узорами коричневых, красных, бурых оттенков https://www.legnostyle.ru/catalog/mebel/derevyannye-stoly/stol-model-s-12.html
Столы, шкафы из этого материала внешне получаются представительными и солидными https://www.legnostyle.ru/risunok-na-dveri.html
Орех обладает серо-коричневой сердцевиной с темными вкраплениями https://www.legnostyle.ru/catalog/mejkomnatnie-dveri/perfetto/dver-p31.html
В мебели он смотрится благородно https://www.legnostyle.ru/catalog/mejkomnatnie-dveri/ottimo/mejkomnatnaa-dver-o7.html
Что касается ясеня, то его древесина прочная https://www.legnostyle.ru/catalog/lestnici/derevannie-marsevie-lestnici-s-plohadkami/lestnica-l1-24.html
Однако из нее получается светлая мебель, которая не всегда подходит деловому дизайну интерьера http://www.legnostyle.ru/mezhkomnatnye-dveri-knizhka.html?PAGEN_2=9
Мы не торгуем подделками https://www.legnostyle.ru/catalog/lestnici/derevannie-marsevie-lestnici-s-plohadkami/lestnica-l1-22.html
Мы стараемся не торговать не оригинальным оборудованием (подделками) http://www.legnostyle.ru/dver-dlya-vannoi.html
Мы являемся официальными представителями компаний ряда компаний производителей и дилеров в России, и предлагаем оригинальное оборудование изготовленное этими компаниями – дилерские сертификаты можно запросить в отделе продаж или ознакомиться на сайте https://www.legnostyle.ru/catalog/mebel/elitnaya-detskaya-mebel/?PAGEN_1=3
Мы предлагаем Вам выбор, а вы решаете что брать а что нет, в зависимости от ваших финансовых возможностей и желаний https://www.legnostyle.ru/catalog/inter-eri/peregorodki/a-40.html
Но помните как правило на любое оригинальное оборудование гарантия начинается от 3-х лет !!!
Безупречная эргономика https://www.legnostyle.ru/mebel-v-stile-art.html
Каждый элемент кабинета спроектирован таким образом, чтобы создавать оптимальные условия для работы http://www.legnostyle.ru/uglovye-lestnicy.html
Деловые мелочи всегда будут под рукой, на просторной столешнице разместятся все важные бумаги, удобное кресло обеспечит эффективную поддержку позвоночника https://www.legnostyle.ru/uteplenie-vhodnyh-dverei.html
Уже давно элитная мебель перестала быть для нас чем-то необычным https://www.legnostyle.ru/catalog/mebel/gostinnie/g-2.html
Все мы хотим, заплатив деньги получить что-то необычное, особенное и, конечно же, эксклюзивное https://www.legnostyle.ru/mezhkomnatnye-dveri-garmoshka.html
Внимание! Владельцы и создатели данного сайта не несут ответственность за использование ссылок и информации, представленных на этом сайте, добавленной пользователями сайта в свободной форме в виде сообщений на форуме, а так же комментариям к материалам, статьям, новостям https://www.legnostyle.ru/catalog/kuhni/?PAGEN_1=4 Российские импортёры сельскохозяйственной продукции активно закупают овощи и фрукты в Китае https://www.legnostyle.ru/modyli-dlia-kyhni.html?PAGEN_2=2 Ожидается, что объём сделок в ближайшее время достигнет 7,25 млн долларов https://www.legnostyle.ru/catalog/mebel/shkafy-sekcii-gorki/scg-8.html Самые читаемые записи Ценными породами в российских реалиях считаются дуб, ясень и орех https://www.legnostyle.ru/furnitura-lestnicy.html Мебель для кабинета руководителя получается стильной и красивой, так как каждая порода отличается оригинальным рисунком https://www.legnostyle.ru/catalog/nashi-raboty/inter-er-zagorodnogo-doma-k5.html Дуб знаменит крупными узорами коричневых, красных, бурых оттенков https://www.legnostyle.ru/catalog/mebel/derevyannye-stoly/stol-model-s-12.html Столы, шкафы из этого материала внешне получаются представительными и солидными https://www.legnostyle.ru/risunok-na-dveri.html Орех обладает серо-коричневой сердцевиной с темными вкраплениями https://www.legnostyle.ru/catalog/mejkomnatnie-dveri/perfetto/dver-p31.html В мебели он смотрится благородно https://www.legnostyle.ru/catalog/mejkomnatnie-dveri/ottimo/mejkomnatnaa-dver-o7.html Что касается ясеня, то его древесина прочная https://www.legnostyle.ru/catalog/lestnici/derevannie-marsevie-lestnici-s-plohadkami/lestnica-l1-24.html Однако из нее получается светлая мебель, которая не всегда подходит деловому дизайну интерьера http://www.legnostyle.ru/mezhkomnatnye-dveri-knizhka.html?PAGEN_2=9 Мы не торгуем подделками https://www.legnostyle.ru/catalog/lestnici/derevannie-marsevie-lestnici-s-plohadkami/lestnica-l1-22.html Мы стараемся не торговать не оригинальным оборудованием (подделками) http://www.legnostyle.ru/dver-dlya-vannoi.html Мы являемся официальными представителями компаний ряда компаний производителей и дилеров в России, и предлагаем оригинальное оборудование изготовленное этими компаниями – дилерские сертификаты можно запросить в отделе продаж или ознакомиться на сайте https://www.legnostyle.ru/catalog/mebel/elitnaya-detskaya-mebel/?PAGEN_1=3 Мы предлагаем Вам выбор, а вы решаете что брать а что нет, в зависимости от ваших финансовых возможностей и желаний https://www.legnostyle.ru/catalog/inter-eri/peregorodki/a-40.html Но помните как правило на любое оригинальное оборудование гарантия начинается от 3-х лет !!! Безупречная эргономика https://www.legnostyle.ru/mebel-v-stile-art.html Каждый элемент кабинета спроектирован таким образом, чтобы создавать оптимальные условия для работы http://www.legnostyle.ru/uglovye-lestnicy.html Деловые мелочи всегда будут под рукой, на просторной столешнице разместятся все важные бумаги, удобное кресло обеспечит эффективную поддержку позвоночника https://www.legnostyle.ru/uteplenie-vhodnyh-dverei.html Уже давно элитная мебель перестала быть для нас чем-то необычным https://www.legnostyle.ru/catalog/mebel/gostinnie/g-2.html Все мы хотим, заплатив деньги получить что-то необычное, особенное и, конечно же, эксклюзивное https://www.legnostyle.ru/mezhkomnatnye-dveri-garmoshka.html
quartoere1987
Тип выезда Стоимость в руб https://24shina.moscow/services
ВЫЕЗД ДО 22:00 1000 ВЫЕЗД ПОСЛЕ 22:00 1500 ВЫЕЗД ЗА МКАД от 1000 + 30 руб/км ПРОСТОЙ БОЛЕЕ 30 МИНУТ от 1000 МИНИМАЛЬНЫЙ ВЫЕЗД 2500 https://24shina.moscow/kievskoe-shosse?screen=kievskoe-shosse
Выездной шиномонтаж https://24shina.moscow/kievskoe-shosse?screen=kievskoe-shosse
  • в наличии колодки и тормозные диски для всех марок авто https://24shina.moscow/
Прокол колеса - это нарушение целостности покрышки, в результате чего происходит выход воздуха https://24shina.moscow/services
Ремонт проколов и порезов шин https://24shina.moscow/snyatie-sekretok
Вы можете сэкономить https://24shina.moscow/prikurka-avto
Тип выезда Стоимость в руб https://24shina.moscow/services ВЫЕЗД ДО 22:00 1000 ВЫЕЗД ПОСЛЕ 22:00 1500 ВЫЕЗД ЗА МКАД от 1000 + 30 руб/км ПРОСТОЙ БОЛЕЕ 30 МИНУТ от 1000 МИНИМАЛЬНЫЙ ВЫЕЗД 2500 https://24shina.moscow/kievskoe-shosse?screen=kievskoe-shosse Выездной шиномонтаж https://24shina.moscow/kievskoe-shosse?screen=kievskoe-shosse * в наличии колодки и тормозные диски для всех марок авто https://24shina.moscow/ Прокол колеса - это нарушение целостности покрышки, в результате чего происходит выход воздуха https://24shina.moscow/services Ремонт проколов и порезов шин https://24shina.moscow/snyatie-sekretok Вы можете сэкономить https://24shina.moscow/prikurka-avto
quartoere1987
quartoere1987 posted this 22 October 2023
Мобильное обслуживание особенно комфортно, когда поблизости нет СТО, на котором бы могли произвести замену шин, устранить дефект резины https://24shina.moscow/motoshinomontazh
Прокол колеса в пути, потребность экстренно восстановить возможность передвижения не редкость https://24shina.moscow/services
Качество дорожного покрытия оставляет желать лучшего, но остаться без возможности передвигаться исключительно неприятно https://24shina.moscow/services
Передвигаться с пробитым колесом плохое решение https://24shina.moscow/services
Доставить резину на ближайшую станцию не всегда удобно, а услуги эвакуатора дорогое удовольствие https://24shina.moscow/prikurka-avto
Вам стоит обратиться к нам!
Мессенджеры : Вы можете связаться с нами через популярные мессенджеры, такие как WhatsApp, Viber, или Telegram https://24shina.moscow/calculator
Просто отправьте нам сообщение с описанием вашей проблемы и адресом https://24shina.moscow/kievskoe-shosse?screen=kievskoe-shosse
Имея склад БУ шин, а также корпоративные условия на закупку, мы можем оперативно закупить, привезти и установить нужные шины https://24shina.moscow/PODVOZ-TOPLIVA
Не верите? Проверьте!
Ремонт прокола: от 1300 https://24shina.moscow/motoshinomontazh
Позвоните https://24shina.moscow/shinomontazh
Мобильное обслуживание особенно комфортно, когда поблизости нет СТО, на котором бы могли произвести замену шин, устранить дефект резины https://24shina.moscow/motoshinomontazh Прокол колеса в пути, потребность экстренно восстановить возможность передвижения не редкость https://24shina.moscow/services Качество дорожного покрытия оставляет желать лучшего, но остаться без возможности передвигаться исключительно неприятно https://24shina.moscow/services Передвигаться с пробитым колесом плохое решение https://24shina.moscow/services Доставить резину на ближайшую станцию не всегда удобно, а услуги эвакуатора дорогое удовольствие https://24shina.moscow/prikurka-avto Вам стоит обратиться к нам! Мессенджеры : Вы можете связаться с нами через популярные мессенджеры, такие как WhatsApp, Viber, или Telegram https://24shina.moscow/calculator Просто отправьте нам сообщение с описанием вашей проблемы и адресом https://24shina.moscow/kievskoe-shosse?screen=kievskoe-shosse Имея склад БУ шин, а также корпоративные условия на закупку, мы можем оперативно закупить, привезти и установить нужные шины https://24shina.moscow/PODVOZ-TOPLIVA Не верите? Проверьте! Ремонт прокола: от 1300 https://24shina.moscow/motoshinomontazh Позвоните https://24shina.moscow/shinomontazh
quartoere1987
Выдается гарантия на срок жизни шины (просим сохранять наряд-заказ, т https://24shina.moscow/kievskoe-shosse?screen=kievskoe-shosse
к https://24shina.moscow/motoshinomontazh
он является документом) https://24shina.moscow/calculator
Замена комплекта шин (шиномонтаж/балансировка/установка): 5500 https://24shina.moscow/calculator
Преимущества нашего выездного шиномонтажа https://24shina.moscow/price
Если заявка поступила с сайта скидка 10%
Шиномонтаж на колесах москва https://24shina.moscow/prikurka-avto
Сезонное хранение колес https://24shina.moscow/services
Выдается гарантия на срок жизни шины (просим сохранять наряд-заказ, т https://24shina.moscow/kievskoe-shosse?screen=kievskoe-shosse к https://24shina.moscow/motoshinomontazh он является документом) https://24shina.moscow/calculator Замена комплекта шин (шиномонтаж/балансировка/установка): 5500 https://24shina.moscow/calculator Преимущества нашего выездного шиномонтажа https://24shina.moscow/price Если заявка поступила с сайта скидка 10% Шиномонтаж на колесах москва https://24shina.moscow/prikurka-avto Сезонное хранение колес https://24shina.moscow/services
sizova.olesia.1991.21.1
sizova.olesia.1991.21.1 posted this 22 October 2023
Самодельная скульптура для сада – это результат очень интересной и творческой работы https://ot-ido.art/work/view?id=2474
А если использовать гипс в качестве основного материала, то можно впечатлить всех своей смекалкой и фантазией https://ot-ido.art/work/view?id=6344
Мы издавна привыкли, что статуя Древней Греции – это мраморные скульптуры https://ot-ido.art/work/view?id=8698
Но, как минимум, половина изображений богов в Древней Греции была выполнена из бронзы https://ot-ido.art/artists?page=17&search_by_letter=g
Солдаты, бывшие на дворе, услыхав выстрел, вошли в сени, спрашивая, что случилось, и изъявляя готовность наказать виновных но офицер строго остановил их https://ot-ido.art/work/genre?id=1&page=51&per-page=12
Редкость https://ot-ido.art/work/artfit?id=636
ФРАЖЕ с ХРУСТАЛЕМ https://ot-ido.art/work/view?id=10338
Хорошая сохранность стекла и серебрения на подставке https://ot-ido.art/work/view?id=4907
Старинная огромная ваза для фруктов Высота-44 https://ot-ido.art/work/artfit?id=7946
5см,диаметр чаши-26см https://ot-ido.art/work/view?id=6392
:хрустальная чаша-старинное поющее свинцовое стекло с ручной резкой,подставка-Благородный олень в лесу-бронза в серебрении велико https://ot-ido.art/work/view?id=688
https://ot-ido.art/work/genre?id=17
Требуется поставить меньшую форму внутрь большей, и можно заливать раствор https://ot-ido.art/artist/page?id=1865
Оставляется все примерно на 2 дня https://ot-ido.art/work/genre?id=9&page=4&per-page=12
Потом, все снимается https://ot-ido.art/artist/page?id=497
В итоге – прекрасная вазочка, для украшения сада https://ot-ido.art/work/view?id=5816
Ее можно использовать как интересную малую архитектурную форму для посева цветов и красивых трав https://ot-ido.art/work/view?id=8639
Самодельная скульптура для сада – это результат очень интересной и творческой работы https://ot-ido.art/work/view?id=2474 А если использовать гипс в качестве основного материала, то можно впечатлить всех своей смекалкой и фантазией https://ot-ido.art/work/view?id=6344 Мы издавна привыкли, что статуя Древней Греции – это мраморные скульптуры https://ot-ido.art/work/view?id=8698 Но, как минимум, половина изображений богов в Древней Греции была выполнена из бронзы https://ot-ido.art/artists?page=17&search_by_letter=g Солдаты, бывшие на дворе, услыхав выстрел, вошли в сени, спрашивая, что случилось, и изъявляя готовность наказать виновных но офицер строго остановил их https://ot-ido.art/work/genre?id=1&page=51&per-page=12 Редкость https://ot-ido.art/work/artfit?id=636 ФРАЖЕ с ХРУСТАЛЕМ https://ot-ido.art/work/view?id=10338 Хорошая сохранность стекла и серебрения на подставке https://ot-ido.art/work/view?id=4907 Старинная огромная ваза для фруктов Высота-44 https://ot-ido.art/work/artfit?id=7946 5см,диаметр чаши-26см https://ot-ido.art/work/view?id=6392 :хрустальная чаша-старинное поющее свинцовое стекло с ручной резкой,подставка-Благородный олень в лесу-бронза в серебрении велико https://ot-ido.art/work/view?id=688 https://ot-ido.art/work/genre?id=17 Требуется поставить меньшую форму внутрь большей, и можно заливать раствор https://ot-ido.art/artist/page?id=1865 Оставляется все примерно на 2 дня https://ot-ido.art/work/genre?id=9&page=4&per-page=12 Потом, все снимается https://ot-ido.art/artist/page?id=497 В итоге – прекрасная вазочка, для украшения сада https://ot-ido.art/work/view?id=5816 Ее можно использовать как интересную малую архитектурную форму для посева цветов и красивых трав https://ot-ido.art/work/view?id=8639
zabirova_lena_1988_15_3
zabirova_lena_1988_15_3 posted this 22 October 2023
В данном случае паркетные доски приклеиваются к фанерам с помощью клеевого состава, рекомендованного производителем https://floor-x.com/kovry/sostav_100-viskoza~100-poliester/brend_ligne-pure/vid-pomescheniya_dom~kvartira~gostinaya~spalnya/cvet_cherniy~seriy~serebristiy~ugolniy~shokoladniy~bejevo-rijiy~rozoviy~sinyaya-stal~myatniy~bejevo-salatoviy~belosnejniy~golubo-sero-rozoviy~rozovo-jeltiy/strana_belgiya/razmer_200-300~250-350~140-200~60-120~170-235~200-295/
Такой вид укладки сложнее “плавающего”, потому что нужно успевать наносить клей и приклеивать доски в достаточно быстром темпе, чтобы клей не успевал засыхать https://floor-x.com/kovry/vid-pomescheniya_kvartira~gostinaya/cvet_bejeviy~temno-bejeviy~shokoladniy~sinyaya-stal~raznocvetniy~belosnejniy~golubo-sero-rozoviy/strana_belgiya/razmer_250-350~140-200~60-120~170-235~300-395/proizvoditeli_ligne-pure/
Паркетное покрытие, несмотря на его многолетнее использование и постоянно растущее разнообразие напольных материалов, нисколько не сдает позиций и по-прежнему популярно и востребовано https://floor-x.com/kovry/razmer-kovra--sm_200-300/brend_ligne-pure/vid-pomescheniya_kvartira~gostinaya~spalnya/cvet_goluboy~bejeviy~serebristiy~bejevo-seriy~shokoladniy~rozoviy~myatniy~sinevato-zeleniy~raznocvetniy~belosnejniy~golubo-sero-rozoviy/razmer_250-350~140-200~60-120~170-235~300-395/proizvoditeli_ligne-pure/
Ведь необыкновенно приятно самостоятельно выложить необыкновенный узор на покрытии из натуральной древесины https://floor-x.com/kovry/vid-pomescheniya_kvartira~gostinaya/cvet_cherniy~bejevo-seriy~shokoladniy~bejevo-rijiy~sinevato-zeleniy~raznocvetniy~bejevo-salatoviy~belosnejniy~golubo-sero-rozoviy~rozovo-jeltiy/strana_belgiya/razmer_200-300~250-350~140-200~60-120~300-395/
По этой причине не теряет актуальности вопрос: как правильно выполняется укладка паркетной доски своими руками — далее рассмотрим пошаговую инструкцию https://floor-x.com/kovry/razmer-kovra--sm_200-300/vid-pomescheniya_dom~gostinaya/visota-vorsa-s-osnovaniem_75-mm/cvet_cherniy~seriy~beliy~serebristiy~dimchatiy~lazurno-seriy~sinevato-zeleniy~krasno-rozoviy~rozovo-jeltiy/razmer_170-240~60-120/
Можно очень точно подобрать напольное покрытие к оформлению практически любого интерьера https://floor-x.com/kovry/cena-za-m2_po-zaprosu/sostav_50-sherst/vid-pomescheniya_kvartira~spalnya/kollekciya_current/cvet_beliy~kapuchino~bejevo-seriy~shokoladniy~bejevo-rijiy~rozoviy~sinyaya-stal~salatoviy~sinevato-zeleniy~raznocvetniy~golubo-sero-rozoviy~krasno-rozoviy/strana_belgiya/razmer_140-200~60-120~140-195~170-235~250-345~300-395/proizvoditeli_ligne-pure/
Рисунок поверхности зависит от распила и может меняться от однородного до затейливого, с сучками и прожилками https://floor-x.com/kovry/brend_ligne-pure/vid-pomescheniya_kvartira~gostinaya/cvet_cherniy~beliy~bejevo-seriy~shokoladniy~stalnoy~bejevo-rijiy~sinyaya-stal~myatniy~bejevo-salatoviy~belosnejniy~golubo-sero-rozoviy~krasno-rozoviy/strana_belgiya/razmer_170-240~250-350~140-200~60-120~170-235/
Современные способы обработки древесины также вносят разнообразие в декоративный ряд https://floor-x.com/kovry/cena-za-m2_po-zaprosu/vid-pomescheniya_dom~kvartira~spalnya/kollekciya_luminous/cvet_goluboy~bejeviy~temno-bejeviy~serebristiy~bejevo-seriy~shokoladniy~myatniy~raznocvetniy~belosnejniy~golubo-sero-rozoviy/strana_belgiya/razmer_250-350~140-200~60-120~170-235~200-295~300-395/
Отпаривание (применяется к буку) делает цвет натурального дерева более насыщенным и - это вычесывание слабых волокон с помощью жесткой металлической щетки https://floor-x.com/kovry/sostav_viskoza~dekolan/vid-pomescheniya_kvartira~gostinaya/cvet_cherniy~seriy~bejeviy~bejevo-seriy~bejevo-rijiy~raznocvetniy~belosnejniy~golubo-sero-rozoviy/strana_belgiya/razmer_200-300~250-350~140-200~170-235/
В результате поверхность становится фактурной, ребристой и хорошо подходит к стилю кантри https://floor-x.com/kovry/sostav_50-viskoza~dekolan/vid-pomescheniya_kvartira~gostinaya/kollekciya_current/cvet_cherniy~goluboy~temno-bejeviy~shokoladniy~bejevo-rijiy~myatniy~raznocvetniy~belosnejniy~golubo-sero-rozoviy~rozovo-jeltiy/razmer_170-240~200-300~250-350~140-200~60-120~300-395/proizvoditeli_ligne-pure/
Износостойкость такой доски повышается, ее можно укладывать в общественных помещениях с высокой нагрузкой на пол https://floor-x.com/kovry/cvet_cherniy~beliy~kapuchino~serebristiy~dimchatiy~myatniy~salatoviy~sinevato-zeleniy~bejevo-salatoviy/
матовый 0/2645Плитка 0/110художественный 0/4881-полосный 8/3232-полосный 0/123-полосный 9/159браш 1/38глянцевый 0/124Елочка 0/304Классический 0/2649Корабельный брус 0/55Под бревно 0/24Под дерево 0/1579Под камень 0/113Под кирпич 0/101под плитку 0/344Прямой 0/1193Сапожок 0/141текстурный 0/124Фигурный 0/261
Укладывать обрезанные элементы нужно аналогично укладыванию обычного паркета https://floor-x.com/kovry/brend_ligne-pure/cvet_temno-bejeviy~serebristiy~dimchatiy~bejevo-seriy~rozoviy~myatniy~raznocvetniy~golubo-sero-rozoviy/razmer_60-120/
Не забывайте про технологический зазор у стен, соблюдайте его ровность, вставляя клинья либо регулируемые спейсеры (специальные проставки) https://floor-x.com/kovry/vid-pomescheniya_dom~kvartira~spalnya/cvet_ugolniy~shokoladniy~stalnoy~bejevo-rijiy~rozoviy~sinyaya-stal~bejevo-salatoviy~belosnejniy~rozovo-jeltiy/strana_belgiya/razmer_200-300~250-350~140-200~60-120~170-235~200-295/proizvoditeli_ligne-pure/
Второй ряд начинайте с оставшегося обрезка последней доски с первого ряда https://floor-x.com/kovry/cena-za-m2_po-zaprosu/sostav_100-viskoza~sherst~50-sherst/brend_ligne-pure/vid-pomescheniya_dom~kvartira~gostinaya/ves-pokritiya-obschiy_3750-gr-m2~5000-g-m2~5000-gr--m2/cvet_cherniy~seriy~goluboy~temno-bejeviy~beliy~serebristiy~dimchatiy~shokoladniy~bejevo-rijiy~rozoviy~sinyaya-stal~salatoviy~sinevato-zeleniy~raznocvetniy~bejevo-salatoviy~belosnejniy~golubo-sero-rozoviy~rozovo-jeltiy/strana_belgiya/razmer_170-240~200-300~250-350~170-235~200-295~250-345~300-395/proizvoditeli_ligne-pure/
каждую доски прикладывайте к соседней, вставляя шип в соответствующий паз https://floor-x.com/kovry/sostav_100-poliester~dekolan/vid-pomescheniya_kvartira/cvet_cherniy~serebristiy~bejevo-seriy~shokoladniy~bejevo-rijiy~rozoviy~sinyaya-stal~belosnejniy~golubo-sero-rozoviy/razmer_200-300~140-200~60-120~170-235~300-395/
Для этого укладываемую доску сначала держим под углом 30? https://floor-x.com/kovry/vid-pomescheniya_dom~kvartira~spalnya/cvet_goluboy~temno-bejeviy~beliy~dimchatiy~bejevo-seriy~bejevo-rijiy~rozoviy~salatoviy~sinevato-zeleniy~raznocvetniy~belosnejniy~golubo-sero-rozoviy/strana_belgiya/razmer_200-300~250-350~140-200~60-120~250-345~300-395/proizvoditeli_ligne-pure/
Нажимаем вперед и вниз, чтобы замковые элементы соединились https://floor-x.com/kovry/vid-pomescheniya_kvartira~spalnya/cvet_seriy~goluboy~beliy~dimchatiy~bejevo-seriy~shokoladniy~bejevo-rijiy~rozoviy~sinyaya-stal~myatniy~salatoviy~sinevato-zeleniy~raznocvetniy~golubo-sero-rozoviy/strana_belgiya/razmer_200-300~60-120~170-235~250-345~300-395/proizvoditeli_ligne-pure/
Далее резиновым молоточком надо постукивать по боковине крайней доски, чтобы соединение укрепилось https://floor-x.com/kovry/brend_ligne-pure/vid-pomescheniya_kvartira~spalnya/ves-pokritiya-obschiy_3750-gr-m2/cvet_goluboy~bejeviy~serebristiy~bejevo-seriy~shokoladniy~myatniy~raznocvetniy~belosnejniy~golubo-sero-rozoviy/strana_belgiya/razmer_250-350~140-200~60-120~170-235~300-395/
В данном случае паркетные доски приклеиваются к фанерам с помощью клеевого состава, рекомендованного производителем https://floor-x.com/kovry/sostav_100-viskoza~100-poliester/brend_ligne-pure/vid-pomescheniya_dom~kvartira~gostinaya~spalnya/cvet_cherniy~seriy~serebristiy~ugolniy~shokoladniy~bejevo-rijiy~rozoviy~sinyaya-stal~myatniy~bejevo-salatoviy~belosnejniy~golubo-sero-rozoviy~rozovo-jeltiy/strana_belgiya/razmer_200-300~250-350~140-200~60-120~170-235~200-295/ Такой вид укладки сложнее “плавающего”, потому что нужно успевать наносить клей и приклеивать доски в достаточно быстром темпе, чтобы клей не успевал засыхать https://floor-x.com/kovry/vid-pomescheniya_kvartira~gostinaya/cvet_bejeviy~temno-bejeviy~shokoladniy~sinyaya-stal~raznocvetniy~belosnejniy~golubo-sero-rozoviy/strana_belgiya/razmer_250-350~140-200~60-120~170-235~300-395/proizvoditeli_ligne-pure/ Паркетное покрытие, несмотря на его многолетнее использование и постоянно растущее разнообразие напольных материалов, нисколько не сдает позиций и по-прежнему популярно и востребовано https://floor-x.com/kovry/razmer-kovra--sm_200-300/brend_ligne-pure/vid-pomescheniya_kvartira~gostinaya~spalnya/cvet_goluboy~bejeviy~serebristiy~bejevo-seriy~shokoladniy~rozoviy~myatniy~sinevato-zeleniy~raznocvetniy~belosnejniy~golubo-sero-rozoviy/razmer_250-350~140-200~60-120~170-235~300-395/proizvoditeli_ligne-pure/ Ведь необыкновенно приятно самостоятельно выложить необыкновенный узор на покрытии из натуральной древесины https://floor-x.com/kovry/vid-pomescheniya_kvartira~gostinaya/cvet_cherniy~bejevo-seriy~shokoladniy~bejevo-rijiy~sinevato-zeleniy~raznocvetniy~bejevo-salatoviy~belosnejniy~golubo-sero-rozoviy~rozovo-jeltiy/strana_belgiya/razmer_200-300~250-350~140-200~60-120~300-395/ По этой причине не теряет актуальности вопрос: как правильно выполняется укладка паркетной доски своими руками — далее рассмотрим пошаговую инструкцию https://floor-x.com/kovry/razmer-kovra--sm_200-300/vid-pomescheniya_dom~gostinaya/visota-vorsa-s-osnovaniem_75-mm/cvet_cherniy~seriy~beliy~serebristiy~dimchatiy~lazurno-seriy~sinevato-zeleniy~krasno-rozoviy~rozovo-jeltiy/razmer_170-240~60-120/ Можно очень точно подобрать напольное покрытие к оформлению практически любого интерьера https://floor-x.com/kovry/cena-za-m2_po-zaprosu/sostav_50-sherst/vid-pomescheniya_kvartira~spalnya/kollekciya_current/cvet_beliy~kapuchino~bejevo-seriy~shokoladniy~bejevo-rijiy~rozoviy~sinyaya-stal~salatoviy~sinevato-zeleniy~raznocvetniy~golubo-sero-rozoviy~krasno-rozoviy/strana_belgiya/razmer_140-200~60-120~140-195~170-235~250-345~300-395/proizvoditeli_ligne-pure/ Рисунок поверхности зависит от распила и может меняться от однородного до затейливого, с сучками и прожилками https://floor-x.com/kovry/brend_ligne-pure/vid-pomescheniya_kvartira~gostinaya/cvet_cherniy~beliy~bejevo-seriy~shokoladniy~stalnoy~bejevo-rijiy~sinyaya-stal~myatniy~bejevo-salatoviy~belosnejniy~golubo-sero-rozoviy~krasno-rozoviy/strana_belgiya/razmer_170-240~250-350~140-200~60-120~170-235/ Современные способы обработки древесины также вносят разнообразие в декоративный ряд https://floor-x.com/kovry/cena-za-m2_po-zaprosu/vid-pomescheniya_dom~kvartira~spalnya/kollekciya_luminous/cvet_goluboy~bejeviy~temno-bejeviy~serebristiy~bejevo-seriy~shokoladniy~myatniy~raznocvetniy~belosnejniy~golubo-sero-rozoviy/strana_belgiya/razmer_250-350~140-200~60-120~170-235~200-295~300-395/ Отпаривание (применяется к буку) делает цвет натурального дерева более насыщенным и - это вычесывание слабых волокон с помощью жесткой металлической щетки https://floor-x.com/kovry/sostav_viskoza~dekolan/vid-pomescheniya_kvartira~gostinaya/cvet_cherniy~seriy~bejeviy~bejevo-seriy~bejevo-rijiy~raznocvetniy~belosnejniy~golubo-sero-rozoviy/strana_belgiya/razmer_200-300~250-350~140-200~170-235/ В результате поверхность становится фактурной, ребристой и хорошо подходит к стилю кантри https://floor-x.com/kovry/sostav_50-viskoza~dekolan/vid-pomescheniya_kvartira~gostinaya/kollekciya_current/cvet_cherniy~goluboy~temno-bejeviy~shokoladniy~bejevo-rijiy~myatniy~raznocvetniy~belosnejniy~golubo-sero-rozoviy~rozovo-jeltiy/razmer_170-240~200-300~250-350~140-200~60-120~300-395/proizvoditeli_ligne-pure/ Износостойкость такой доски повышается, ее можно укладывать в общественных помещениях с высокой нагрузкой на пол https://floor-x.com/kovry/cvet_cherniy~beliy~kapuchino~serebristiy~dimchatiy~myatniy~salatoviy~sinevato-zeleniy~bejevo-salatoviy/ матовый 0/2645Плитка 0/110художественный 0/4881-полосный 8/3232-полосный 0/123-полосный 9/159браш 1/38глянцевый 0/124Елочка 0/304Классический 0/2649Корабельный брус 0/55Под бревно 0/24Под дерево 0/1579Под камень 0/113Под кирпич 0/101под плитку 0/344Прямой 0/1193Сапожок 0/141текстурный 0/124Фигурный 0/261 Укладывать обрезанные элементы нужно аналогично укладыванию обычного паркета https://floor-x.com/kovry/brend_ligne-pure/cvet_temno-bejeviy~serebristiy~dimchatiy~bejevo-seriy~rozoviy~myatniy~raznocvetniy~golubo-sero-rozoviy/razmer_60-120/ Не забывайте про технологический зазор у стен, соблюдайте его ровность, вставляя клинья либо регулируемые спейсеры (специальные проставки) https://floor-x.com/kovry/vid-pomescheniya_dom~kvartira~spalnya/cvet_ugolniy~shokoladniy~stalnoy~bejevo-rijiy~rozoviy~sinyaya-stal~bejevo-salatoviy~belosnejniy~rozovo-jeltiy/strana_belgiya/razmer_200-300~250-350~140-200~60-120~170-235~200-295/proizvoditeli_ligne-pure/ Второй ряд начинайте с оставшегося обрезка последней доски с первого ряда https://floor-x.com/kovry/cena-za-m2_po-zaprosu/sostav_100-viskoza~sherst~50-sherst/brend_ligne-pure/vid-pomescheniya_dom~kvartira~gostinaya/ves-pokritiya-obschiy_3750-gr-m2~5000-g-m2~5000-gr--m2/cvet_cherniy~seriy~goluboy~temno-bejeviy~beliy~serebristiy~dimchatiy~shokoladniy~bejevo-rijiy~rozoviy~sinyaya-stal~salatoviy~sinevato-zeleniy~raznocvetniy~bejevo-salatoviy~belosnejniy~golubo-sero-rozoviy~rozovo-jeltiy/strana_belgiya/razmer_170-240~200-300~250-350~170-235~200-295~250-345~300-395/proizvoditeli_ligne-pure/ каждую доски прикладывайте к соседней, вставляя шип в соответствующий паз https://floor-x.com/kovry/sostav_100-poliester~dekolan/vid-pomescheniya_kvartira/cvet_cherniy~serebristiy~bejevo-seriy~shokoladniy~bejevo-rijiy~rozoviy~sinyaya-stal~belosnejniy~golubo-sero-rozoviy/razmer_200-300~140-200~60-120~170-235~300-395/ Для этого укладываемую доску сначала держим под углом 30? https://floor-x.com/kovry/vid-pomescheniya_dom~kvartira~spalnya/cvet_goluboy~temno-bejeviy~beliy~dimchatiy~bejevo-seriy~bejevo-rijiy~rozoviy~salatoviy~sinevato-zeleniy~raznocvetniy~belosnejniy~golubo-sero-rozoviy/strana_belgiya/razmer_200-300~250-350~140-200~60-120~250-345~300-395/proizvoditeli_ligne-pure/ Нажимаем вперед и вниз, чтобы замковые элементы соединились https://floor-x.com/kovry/vid-pomescheniya_kvartira~spalnya/cvet_seriy~goluboy~beliy~dimchatiy~bejevo-seriy~shokoladniy~bejevo-rijiy~rozoviy~sinyaya-stal~myatniy~salatoviy~sinevato-zeleniy~raznocvetniy~golubo-sero-rozoviy/strana_belgiya/razmer_200-300~60-120~170-235~250-345~300-395/proizvoditeli_ligne-pure/ Далее резиновым молоточком надо постукивать по боковине крайней доски, чтобы соединение укрепилось https://floor-x.com/kovry/brend_ligne-pure/vid-pomescheniya_kvartira~spalnya/ves-pokritiya-obschiy_3750-gr-m2/cvet_goluboy~bejeviy~serebristiy~bejevo-seriy~shokoladniy~myatniy~raznocvetniy~belosnejniy~golubo-sero-rozoviy/strana_belgiya/razmer_250-350~140-200~60-120~170-235~300-395/
romanova_liudmila_1982_10_11
romanova_liudmila_1982_10_11 posted this 22 October 2023
На приеме оценивается степень деформации стопы: исследуется высота сводов при статической нагрузке (в положении стоя), без нагрузки (в положении лежа), проводится функциональное тестирование, неврологическое обследование на предмет нарушения чувствительности, сухожильных рефлексов и др https://www.uni-ort.ru/neurology
Температура измеряется с помощью ртутного или электронного термометра ( градусника ) https://www.uni-ort.ru/cardiology
Для этого на 5 минут зажимают градусник подмышкой и затем оценивают полученный результат https://www.uni-ort.ru/allergology
Также могут измерять температуру в ротовой полости и в анальном отверстии https://www.uni-ort.ru/allergology
Пищевая аллергия – это разновидность пищевой непереносимости, реакция иммунной системы на какой-то продукт питания https://www.uni-ort.ru/neurology
Часто развивается на фоне хронических заболеваний желудочно-кишечного тракта и предрасположенности к развитию аллергий https://www.uni-ort.ru/price
Значительное влияние на развитие пищевой аллергии у ребенка оказывает питание матери во время беременности ( употребление аллергенных продуктов ) https://www.uni-ort.ru/promo
Клинически характеризуется появлением зудящей сыпи, чиханием, насморком, отеком слизистых https://www.uni-ort.ru/allergology
Возникают боли и тяжесть в животе, рвота, диарея ( жидкий стул ) https://www.uni-ort.ru/dermatology
боли, дискомфорт, онемение, покалывание в области стопы, лодыжки, голени ограничение подвижности в голеностопном суставе изменение внешнего вида сосудов, локализованных в этой области деформации, на первом пальце, молоткообразные пальцы, косолапость профилактические осмотры спортсменов боли в пояснице и коленях https://www.uni-ort.ru/endocrinology
Зачастую они возникают на фоне проблем с лодыжкой и стопой https://www.uni-ort.ru/otolaryngology
Перед проведением компьютерной томографии пациент снимает с себя все металлические украшения, после чего ложится на передвижной стол томографа ( аппарат КТ ) https://www.uni-ort.ru/physicaltherapy
Во время исследования необходимо лежать неподвижно ( при необходимости фиксируют голову, руки, ноги ) https://www.uni-ort.ru/nephrology
Стол начинает продвигаться сквозь специальное кольцо с датчиками, от которых идут рентгеновские лучи https://www.uni-ort.ru/endocrinology
В результате на компьютере получают послойные изображения исследуемого органа высокого качества https://www.uni-ort.ru/surgery
Фебрильные судороги – это приступы судорог ( непроизвольное сокращение мышц ), возникающие на фоне повышенной температуры тела ( выше 38 градусов ) у детей до шести лет, у которых ранее не наблюдалось таких приступов ( при отсутствии температуры ) и нет других причин для их возникновения https://www.uni-ort.ru/physicaltherapy
Фебрильные судороги не являются эпилепсией ( заболевание нервной системы ) https://www.uni-ort.ru/ophthalmology
Как правило, их возникновение связывают с недостаточной зрелостью нервной системы ребенка https://www.uni-ort.ru/immunology
Приступ судорог может длиться от нескольких секунд до пятнадцати минут https://www.uni-ort.ru/massage
Проявляется внезапным началом, закатыванием глаз, напряжением мышц, подергиванием конечностей https://www.uni-ort.ru/neurology
Характерной позой является запрокидывание головы, изгиб спины, сжимание зубов https://www.uni-ort.ru/nephrology
Ребенок может перестать дышать и посинеть, потерять сознание https://www.uni-ort.ru/allergology
На приеме оценивается степень деформации стопы: исследуется высота сводов при статической нагрузке (в положении стоя), без нагрузки (в положении лежа), проводится функциональное тестирование, неврологическое обследование на предмет нарушения чувствительности, сухожильных рефлексов и др https://www.uni-ort.ru/neurology Температура измеряется с помощью ртутного или электронного термометра ( градусника ) https://www.uni-ort.ru/cardiology Для этого на 5 минут зажимают градусник подмышкой и затем оценивают полученный результат https://www.uni-ort.ru/allergology Также могут измерять температуру в ротовой полости и в анальном отверстии https://www.uni-ort.ru/allergology Пищевая аллергия – это разновидность пищевой непереносимости, реакция иммунной системы на какой-то продукт питания https://www.uni-ort.ru/neurology Часто развивается на фоне хронических заболеваний желудочно-кишечного тракта и предрасположенности к развитию аллергий https://www.uni-ort.ru/price Значительное влияние на развитие пищевой аллергии у ребенка оказывает питание матери во время беременности ( употребление аллергенных продуктов ) https://www.uni-ort.ru/promo Клинически характеризуется появлением зудящей сыпи, чиханием, насморком, отеком слизистых https://www.uni-ort.ru/allergology Возникают боли и тяжесть в животе, рвота, диарея ( жидкий стул ) https://www.uni-ort.ru/dermatology боли, дискомфорт, онемение, покалывание в области стопы, лодыжки, голени ограничение подвижности в голеностопном суставе изменение внешнего вида сосудов, локализованных в этой области деформации, на первом пальце, молоткообразные пальцы, косолапость профилактические осмотры спортсменов боли в пояснице и коленях https://www.uni-ort.ru/endocrinology Зачастую они возникают на фоне проблем с лодыжкой и стопой https://www.uni-ort.ru/otolaryngology Перед проведением компьютерной томографии пациент снимает с себя все металлические украшения, после чего ложится на передвижной стол томографа ( аппарат КТ ) https://www.uni-ort.ru/physicaltherapy Во время исследования необходимо лежать неподвижно ( при необходимости фиксируют голову, руки, ноги ) https://www.uni-ort.ru/nephrology Стол начинает продвигаться сквозь специальное кольцо с датчиками, от которых идут рентгеновские лучи https://www.uni-ort.ru/endocrinology В результате на компьютере получают послойные изображения исследуемого органа высокого качества https://www.uni-ort.ru/surgery Фебрильные судороги – это приступы судорог ( непроизвольное сокращение мышц ), возникающие на фоне повышенной температуры тела ( выше 38 градусов ) у детей до шести лет, у которых ранее не наблюдалось таких приступов ( при отсутствии температуры ) и нет других причин для их возникновения https://www.uni-ort.ru/physicaltherapy Фебрильные судороги не являются эпилепсией ( заболевание нервной системы ) https://www.uni-ort.ru/ophthalmology Как правило, их возникновение связывают с недостаточной зрелостью нервной системы ребенка https://www.uni-ort.ru/immunology Приступ судорог может длиться от нескольких секунд до пятнадцати минут https://www.uni-ort.ru/massage Проявляется внезапным началом, закатыванием глаз, напряжением мышц, подергиванием конечностей https://www.uni-ort.ru/neurology Характерной позой является запрокидывание головы, изгиб спины, сжимание зубов https://www.uni-ort.ru/nephrology Ребенок может перестать дышать и посинеть, потерять сознание https://www.uni-ort.ru/allergology
