Hi !
I can insert javascript svg icons animated parts of a Web page, say, or change page animation that I can put into the wbeoldalba can you give me this help? I thought things like that
http://tympanus.net/Development/AnimatedSVGIcons/
Hi !
Hello Peter,
as I understand you need to load .js file and then use some custom HTML and CSS.
The general idea is:
1.add custom JS code which should be located in HEAD section (for example link to .js file) under Settings >> Additional HEAD HTML
2.add HTML Control and put:
-html code into HTML section
-CSS code into CSS section
of the control
When inserting the js in the settings it will be available/inserted in all pages. What if I want to insert an external JS only in a specific page?
When trying to insert JS into HTML element, themler crashes.
Try to use the CMS Code control. Does it work with your code?
Doesn't seem to be any way to add javascript into the html themler if you add it as html or add as additional header - breaks theme
Doesn't seem to be any way to add javascript into the html themler if you add it as html or add as additional header - breaks themeHi,
Looks like you have added this post to several topics. If you need our help, we'll communicate in one of them. So lets ignore this one and continue the discussion in the one I responded initially to.
