Hi!
I would love to have the possibility to select more then one column or row at a time and be able to make changes/settings that effects all of my selected rows/columns at once.
For example, I might have four rows on top of each other and I would like to set the padding and background color but only on particular columns on each row - If i could hold down cmd or shift and select all my desired columns at once it would speed up the work flow quite a bit! (This would also be great to be able to use on more then columns/rows of course!)
Thanks!
Hi! I would love to have the possibility to select more then one column or row at a time and be able to make changes/settings that effects all of my selected rows/columns at once. For example, I might have four rows on top of each other and I would like to set the padding and background color but only on particular columns on each row - If i could hold down cmd or shift and select all my desired columns at once it would speed up the work flow quite a bit! (This would also be great to be able to use on more then columns/rows of course!) Thanks!Last edited 19 November 2015 by Mr. R
