Import Template joomla, it continues with the contents of the previous template
reichert
reichert posted this 20 November 2015
When I import a new template it continues with the contents of the previous template.
01 - JOOMA
http://prntscr.com/94rngf
02 - See that this is the contents of a different template that will import
http://prntscr.com/94rnzw
03 - New Theme
http://prntscr.com/94ro3f
04 -
http://prntscr.com/94rofp
The template is new, but still with the same content from the previous
I want a new theme without the contents or previous template blocks, want a template fully without taking the characteristics of the previous template
Hello When I import a new template it continues with the contents of the previous template. 01 - JOOMA http://prntscr.com/94rngf 02 - See that this is the contents of a different template that will import http://prntscr.com/94rnzw 03 - New Theme http://prntscr.com/94ro3f 04 - http://prntscr.com/94rofp The template is new, but still with the same content from the previous I want a new theme without the contents or previous template blocks, want a template fully without taking the characteristics of the previous template Thank you
Support Team posted this 20 November 2015
That happens because only one Joomla site is created on your localhost and that's why the content of the prevoius template appears in the new one. To remove it please delete or rename the following folder:
C:\ProgramData\Themler\hd_data\themler_1441363065\joomla
The numbers in the themler folder name may differ.
Hi, That happens because only one Joomla site is created on your localhost and that's why the content of the prevoius template appears in the new one. To remove it please delete or rename the following folder: C:\ProgramData\Themler\hd_data\themler_1441363065\joomla The numbers in the themler folder name may differ. Sincerely, Hella
reichert
reichert posted this 21 November 2015
I'm enjoying themler! it looks very nice!
How do I create new sites in joomla? new projects in order to use in joomla themler? is there any tutorial?
I'm enjoying themler! it looks very nice! How do I create new sites in joomla? new projects in order to use in joomla themler? is there any tutorial? Thank you
Support Team posted this 21 November 2015
Hello Junior,
you may create new Joomla theme in Themler. To do it select Joomla on start Themler screen and then select 'New Theme'.
If you want to change the content open Joomla admin back end from Themler and edit it.
Hello Junior, you may create new Joomla theme in Themler. To do it select Joomla on start Themler screen and then select 'New Theme'. If you want to change the content open Joomla admin back end from Themler and edit it. Regards, Aileen
