How do you build a responsible site without affecting the other views? I've tried choosing the mode I want to view it in, and then match it in the left pane, but it seems to loose the other views when I switch back.
For example I select the tablet view after checking the desktop/laptop views and see the banner in the slideshow is distorted, not getting smaller as does the image in it. I change the edit mode to tablet, but trying to choose smaller fonts 30 -> 13 has no effect and the text box will not reduce in size to squeeze it down within the displayed view.
I've looked at all the other available forum comments by phone, responsive, etc to maximize the search results but I cannot seem to locate any previous topic where this is covered. The docs and videos don't address this either.
How do I edit how the theme is viewed by the smaller devices without impacting the desktop/laptop theme look and feel?
How do you build a responsible site without affecting the other views? I've tried choosing the mode I want to view it in, and then match it in the left pane, but it seems to loose the other views when I switch back. For example I select the tablet view after checking the desktop/laptop views and see the banner in the slideshow is distorted, not getting smaller as does the image in it. I change the edit mode to tablet, but trying to choose smaller fonts 30 -> 13 has no effect and the text box will not reduce in size to squeeze it down within the displayed view. I've looked at all the other available forum comments by phone, responsive, etc to maximize the search results but I cannot seem to locate any previous topic where this is covered. The docs and videos don't address this either. How do I edit how the theme is viewed by the smaller devices without impacting the desktop/laptop theme look and feel?
