How can I text and along to place an image inside themler Is this possible or should I just settle this with the joomla editor?
Can you help me with this?
Sincereyly
Fred
Sincereyly
Fred
Sorry, your question is not completely clear. Maybe some screen shots will be helpful.
The difference between inserting the content from Themler and CMS back end is that when inserting in Themler, the content will be static and you will be able to edit it only from the Themler application. The content added through CMS will be possible to edit within the CMS back end.
HI
How to insert <hr> in the top of text and under it and control it size ie <hr size="10px "> or height and width
HI How to insert <hr> in the top of text and under it and control it size ie <hr size="10px "> or height and widthHi,
Size value for the <hr> tag is not supported in HTML5. I suggest you to use the Separator control that is available in Themler.
