Horizontal menu and top menu only appears on the home page
vagtino
vagtino posted this 29 November 2015
The header is appearing on every page of my template and WordPress platform I use for testing, but the two mentioned menus do not appear in the other pages and subpages.
This is due to the type of header that choose to make use of the various models that exist or is some other option Themler should I use?
Vagner
The header is appearing on every page of my template and WordPress platform I use for testing, but the two mentioned menus do not appear in the other pages and subpages. **This is due to the type of header that choose to make use of the various models that exist** or *is some other option Themler should I use?* Thank you Vagner
17 Comments
Hamzah
Hamzah posted this 29 November 2015
Hello Vagner
Just make sure your menus are inside the header container.
Hello Vagner Just make sure your menus are inside the header container.
Support Team posted this 30 November 2015
Please check that the Header and Menu control are shared between the templates. Header control is initially shared on all the templates, check that you haven't edited that settings. Also you can insert the Menu control inside the Header and it will be shared automatically on all the templates that do have Header control.
Hi, Please check that the Header and Menu control are shared between the templates. Header control is initially shared on all the templates, check that you haven't edited that settings. Also you can insert the Menu control inside the Header and it will be shared automatically on all the templates that do have Header control. Sincerely, Hella
vagtino
vagtino posted this 30 November 2015
I managed to do the horizontal menu appears on top of the header correctly, but not the top menu when I try to place the horizontal menu at the bottom of the header does not appear and when it appears in a different way on each page (scruffy).
My major difficulty has been to insert cells and columns (if applied to the top menu, search box and social networks) within the header, plus you get freely move the horizontal menu within any part of the header.
The Themler has numerous additional features compared to Artisteer, but on the other hand is much harder to make or modify the HTML structure of primary elements and those that are secondary or additional in terms of positioning.
Thank you.
Vagner.
Hi I managed to do the horizontal menu appears on top of the header correctly, but not the top menu when I try to place the horizontal menu at the bottom of the header does not appear and when it appears in a different way on each page (scruffy). My major difficulty has been to insert cells and columns (if applied to the top menu, search box and social networks) within the header, plus you get freely move the horizontal menu within any part of the header. The Themler has numerous additional features compared to Artisteer, but on the other hand is much harder to make or modify the HTML structure of primary elements and those that are secondary or additional in terms of positioning. Thank you. Vagner.
Could you please create a separate private ticket with the access to your site and some detailed explanations of the problems.
Hi, Could you please create a separate private ticket with the access to your site and some detailed explanations of the problems. Sincerely, Hella
OCPR
OCPR posted this 30 November 2015
Hi Support
In one of your answers above you suggested to "Please check that the Header and Menu control are shared between the templates." How or where can I find that settings to verify that the Header and Menu (specially the menu) is shared between the templates?
thx!
Hi Support In one of your answers above you suggested to "Please check that the Header and Menu control are shared between the templates." How or where can I find that settings to verify that the Header and Menu (specially the menu) is shared between the templates? thx!
Support Team posted this 01 December 2015
The Header control is originally shared between templates. You can select it and in the options in the left panel you will see the Show on Template option. The easiest way to share the menu is to place it within the Header container.
Another way to share the separate control is to Copy it, navigate to another template and use the Past and Share option.
Hi, The Header control is originally shared between templates. You can select it and in the options in the left panel you will see the Show on Template option. The easiest way to share the menu is to place it within the Header container. Another way to share the separate control is to Copy it, navigate to another template and use the Past and Share option. Sincerely, Hella
OCPR
OCPR posted this 01 December 2015
Perfect, thank you very much Hella!
Support Team posted this 02 December 2015
You are welcome.
obriensue498
obriensue498 posted this 06 April 2026
The issue where a horizontal menu and top menu only appear on the home page of a website could be related to how the layout or template settings are applied across different pages. In many cases, it is possible that the menu is assigned only to the homepage template, or there might be a condition in the code that restricts its visibility to that specific page. Sometimes, theme customization settings or plugin configurations may also play a role, causing the menus to not load consistently on other pages of the website.
There is a chance that adjusting global header settings or checking page-specific templates could help resolve this. It might also be useful to review whether the menu is properly assigned to all pages within the website dashboard.
The issue where a horizontal menu and top menu only appear on the home page of a website could be related to how the layout or template settings are applied across different pages. In many cases, it is possible that the menu is assigned only to the homepage template, or there might be a condition in the code that restricts its visibility to that specific page. Sometimes, theme customization settings or plugin configurations may also play a role, causing the menus to not load consistently on other pages of the website. There is a chance that adjusting global header settings or checking page-specific templates could help resolve this. It might also be useful to review whether the menu is properly assigned to all pages within the [website][1] dashboard. [1]: https://lejournaltach.fr/
henrymixhle
henrymixhle posted this 08 April 2026
This usually happens when the navigation is hard-coded only for the homepage template. If your horizontal or top menu disappears on inner pages, it’s likely not included in the global header file or isn’t being called properly across layouts. I ran into something similar while organizing a content-heavy page about restaurant menus, and fixing the shared header solved it instantly. You might want to check how your theme handles header.php (or equivalent). Also, if helpful, I came across a clean structure example here that breaks things down nicely: https://outbacksmenu.us/ it shows how consistent navigation improves usability across pages.
jackintheboxmenu3
jackintheboxmenu3 posted this 24 April 2026
The horizontal menu and top menu only appear on the home page, making the layout clean and easy to use for visitors. This helps users quickly find important links and explore useful content without confusion. If someone is searching for bojangles gravy ingredients, they can start from the home page and navigate smoothly. The simple design improves the browsing experience for everyone. https://bojanglessmenu.us/bo-tato-rounds/
Alisson_thomas6
Alisson_thomas6 posted this 30 April 2026
That’s an interesting observation, it looks like the menu behavior might be tied to a responsive or template setting affecting only the home page. You might find useful details in the Bay Property Guide which helps explain property-related navigation and structure in a clear way. Often these issues are related to header configuration or conditional page settings in the theme. Worth checking if the navigation module is set to display globally across all pages instead of just the homepage.
That’s an interesting observation, it looks like the menu behavior might be tied to a responsive or template setting affecting only the home page. You might find useful details in the [Bay Property Guide][1] which helps explain property-related navigation and structure in a clear way. Often these issues are related to header configuration or conditional page settings in the theme. Worth checking if the navigation module is set to display globally across all pages instead of just the homepage. [1]: https://baycountypropertyappraiser.org
briancarter5836
briancarter5836 posted this 30 April 2026
This usually happens when template loads homepage-specific navigation settings. You may want to check menu assignment and theme visibility rules for inner pages. A useful reference is Nassau property appraiser which can help you review property and record related data if needed. Hope this helps you narrow down the issue.
This usually happens when template loads homepage-specific navigation settings. You may want to check menu assignment and theme visibility rules for inner pages. A useful reference is [Nassau property appraiser][1] which can help you review property and record related data if needed. Hope this helps you narrow down the issue. [1]: https://nassaucountypropertyappraiser.org
chrmhrtsstr
chrmhrtsstr posted this 20 May 2026
People often look for ways to save Facebook story videos because they disappear after 24 hours and there is no built-in download option. That’s why different methods like online tools or simple browser tricks are commonly used depending on convenience and quality needs. In situations where you just want a quick way to keep a story for later viewing, this resource can also be useful https://tàivideodl.com/tai-video-story-facebook/
Sultan Nights
Sultan Nights posted this 20 May 2026
I completely understand how difficult it can feel to manage uneven skin tone and white patches in daily life. Along with maintaining a healthy lifestyle, proper nutrition, hydration, and regular skin care also play an important role in overall skin wellness. Many people today are choosing wellness-focused products like leucoderma cream for gentle daily skin support instead of harsh solutions.One thing I personally liked about Sultan Nights is their focus on balanced skin wellness and modern lifestyle support. Their products are designed to support healthy-looking skin naturally while encouraging consistent self-care habits. Along with external care, maintaining proper nutrition and a healthy routine can also help improve overall skin confidence over time.Always choose products carefully, follow proper usage instructions, and stay consistent with your daily wellness routine for better long-term support.
I completely understand how difficult it can feel to manage uneven skin tone and white patches in daily life. Along with maintaining a healthy lifestyle, proper nutrition, hydration, and regular skin care also play an important role in overall skin wellness. Many people today are choosing wellness-focused products like **[leucoderma cream][1]** for gentle daily skin support instead of harsh solutions.One thing I personally liked about **Sultan Nights** is their focus on balanced skin wellness and modern lifestyle support. Their products are designed to support healthy-looking skin naturally while encouraging consistent self-care habits. Along with external care, maintaining proper nutrition and a healthy routine can also help improve overall skin confidence over time.Always choose products carefully, follow proper usage instructions, and stay consistent with your daily wellness routine for better long-term support. [1]: https://sultannights.com/product/vitiligo-cream/
aditya.mahalaxmi
aditya.mahalaxmi posted this 21 May 2026
I’ve personally noticed that products with niacinamide for skin are becoming very popular because they help support smoother-looking and healthier skin with regular use. Many people prefer it for maintaining balanced skin texture, hydration, and daily skin wellness naturally. Along with a healthy lifestyle, proper hydration, and good skin care habits, using quality wellness-focused products can make a noticeable difference over time. I recently came across Zolence, and their wellness-inspired skin care range looks quite promising for people looking to maintain healthy-looking and nourished skin naturally without making their routine too complicated.
I’ve personally noticed that products with **[niacinamide for skin][1]** are becoming very popular because they help support smoother-looking and healthier skin with regular use. Many people prefer it for maintaining balanced skin texture, hydration, and daily skin wellness naturally. Along with a healthy lifestyle, proper hydration, and good skin care habits, using quality wellness-focused products can make a noticeable difference over time. I recently came across **Zolence**, and their wellness-inspired skin care range looks quite promising for people looking to maintain healthy-looking and nourished skin naturally without making their routine too complicated. [1]: https://zolence.com/product/niacinamide-face-wash/
superdia11001
superdia11001 posted this 17 June 2026
Instagram likes can be both motivating and misleading at the same time. On one hand, they can encourage creators and give feedback on what people enjoy. On the other hand, they can also create a false sense of popularity or pressure to constantly perform for an audience. Social media would feel much healthier if people focused more on meaningful engagement—like comments and conversations—rather than just chasing likes. At the end of the day, likes are temporary, but real impact and genuine expression last much longer buy Instagram likes.
Instagram likes can be both motivating and misleading at the same time. On one hand, they can encourage creators and give feedback on what people enjoy. On the other hand, they can also create a false sense of popularity or pressure to constantly perform for an audience. Social media would feel much healthier if people focused more on meaningful engagement—like comments and conversations—rather than just chasing likes. At the end of the day, likes are temporary, but real impact and genuine expression last much longer [buy Instagram likes][1]. [1]: https://pajaronian.com/buy-instagram-likes-and-followers/
