unable to edit meta data
weballeycat
weballeycat posted this 03 December 2015
I have been attempting to edit the meta data tags description and keywords for the home template of the website, but have been unable to do so.
I have a joomla 3.4.5 website running a themler template that I created. the url is: http://connecticutballet.org.
I have updated the meta tag information in the global configuration of the website. I have updated meta tag information in the home. I also followed the instructions in the answers section of the themler website: http://answers.themler.com/questions/32494/how-do-you-edit-meta-data-in-themler, but also to no avail. I also tried a 3rd party component that was also unable to update it.
Any help would be greatly appreciated.
Any help with this is greatly appreciate
Hello I have been attempting to edit the meta data tags description and keywords for the home template of the website, but have been unable to do so. I have a joomla 3.4.5 website running a themler template that I created. the url is: http://connecticutballet.org. I have updated the meta tag information in the global configuration of the website. I have updated meta tag information in the home. I also followed the instructions in the answers section of the themler website: http://answers.themler.com/questions/32494/how-do-you-edit-meta-data-in-themler, but also to no avail. I also tried a 3rd party component that was also unable to update it. Any help would be greatly appreciated. Thanks Any help with this is greatly appreciate
9 Comments
Support Team posted this 07 December 2015
Home template is just a template. if you need to add specific Description and Keywords to the home page simply add them under the Joomla front page menu item.
It works just fine.
The keywords and description meta tags added under the Global Configuration display ok too.
Please explain in more details what exactly you're trying to achieve.
To check what causes the issue (theme or something else) please enable default joomla template and check whether meta tags appear with this template or not.
Hi, Home template is just a template. if you need to add specific Description and Keywords to the home page simply add them under the Joomla front page menu item. It works just fine. The keywords and description meta tags added under the Global Configuration display ok too. Please explain in more details what exactly you're trying to achieve. To check what causes the issue (theme or something else) please enable default joomla template and check whether meta tags appear with this template or not. Thank you, Olivia
thomas49234
thomas49234 posted this 14 May 2025
It sounds frustrating trying all those steps without success. Sometimes Themler templates can override Joomla's default settings, especially with meta tags. Make sure the template’s custom settings aren’t conflicting with the global ones. Also, clearing your cache might help changes take effect. It’s kind of like figuring out what meta app installer para que sirve means—sometimes you have to dig deeper to see what’s really controlling the system!
It sounds frustrating trying all those steps without success. Sometimes Themler templates can override Joomla's default settings, especially with meta tags. Make sure the template’s custom settings aren’t conflicting with the global ones. Also, clearing your cache might help changes take effect. It’s kind of like figuring out what [meta app installer para que sirve][1] means—sometimes you have to dig deeper to see what’s really controlling the system! [1]: https://techboltify.com/meta-app-installer/
severalyears1585
severalyears1585 posted this 14 May 2025
You might want to double-check if the Themler template is overriding Joomla's global settings — sometimes custom templates have their own meta tag fields that need editing separately. Also, clearing your website cache after each update is crucial. For anyone managing websites with sensitive or public information, it's also important to ensure compliance with data transparency. You can refer to Public arrest records for an example of how structured metadata and access to public data is effectively managed.
You might want to double-check if the Themler template is overriding Joomla's global settings — sometimes custom templates have their own meta tag fields that need editing separately. Also, clearing your website cache after each update is crucial. For anyone managing websites with sensitive or public information, it's also important to ensure compliance with data transparency. You can refer to [Public arrest records][1] for an example of how structured metadata and access to public data is effectively managed. [1]: https://arrestsssss.org
hurry7590
hurry7590 posted this 27 May 2025
You might want to double-check if your template is overriding global settings or if there's a cache issue preventing changes from reflecting. Also, reviewing any custom overrides in the template files could help. For related research on County arrest lookup, this resource might guide you in managing data visibility and structure across different CMS setups. Hope you find a solution soon!
> Hello > > I have been attempting to edit the meta data tags description and keywords for the home template of the website, but have been unable to do so. > > I have a joomla 3.4.5 website running a themler template that I created. the url is: http://connecticutballet.org. > > I have updated the meta tag information in the global configuration of the website. I have updated meta tag information in the home. I also followed the instructions in the answers section of the themler website: http://answers.themler.com/questions/32494/how-do-you-edit-meta-data-in-themler, but also to no avail. I also tried a 3rd party component that was also unable to update it. > > Any help would be greatly appreciated. > > Thanks > > Any help with this is greatly appreciate You might want to double-check if your template is overriding global settings or if there's a cache issue preventing changes from reflecting. Also, reviewing any custom overrides in the template files could help. For related research on **[County arrest lookup](https://arestsorg.com/)**, this resource might guide you in managing data visibility and structure across different CMS setups. Hope you find a solution soon!
odomadam753
odomadam753 posted this 28 May 2025
You might want to inspect the index.php and templateDetails.xml files in your themler template folder to ensure there’s no hardcoded or overriding metadata. Also, sometimes Joomla caches the old data—try clearing cache and re-saving. If you're working on legal or public record topics, reviewing metadata from sites handling Kentucky arrest records might help you understand structure and best practices.
You might want to inspect the index.php and templateDetails.xml files in your themler template folder to ensure there’s no hardcoded or overriding metadata. Also, sometimes Joomla caches the old data—try clearing cache and re-saving. If you're working on legal or public record topics, reviewing metadata from sites handling **[Kentucky arrest records](https://arrestss-ky.org/)** might help you understand structure and best practices.
emilycandy1012
emilycandy1012 posted this 28 May 2025
Excellent website, retro games. Where did you learn about this post? I've been reading a few articles on your website and thoroughly enjoy your writing style.
Excellent website, [retro games][1]. Where did you learn about this post? I've been reading a few articles on your website and thoroughly enjoy your writing style. [1]: https://retrogamesonline.io
lightfury621
lightfury621 posted this 6 days ago
When it comes to hosting an event with a photobooth, choosing the right software is just as important as the booth itself. The software will dictate how smooth the experience is for your guests, the quality of the photos, and the overall fun factor. Whether you are planning a wedding, a corporate event, or a party, the best photobooth software can elevate the experience and create lasting memories. In this guide, we will explore some of the top software options for running a photobooth at your event, with a focus on features like Photobooth Web online, virtual photo booth online free services, and innovative tools like photo booth 360 and mirror photo booth experiences. View gallery for interesting designs.
When it comes to hosting an event with a photobooth, choosing the right software is just as important as the booth itself. The software will dictate how smooth the experience is for your guests, the quality of the photos, and the overall fun factor. Whether you are planning a wedding, a corporate event, or a party, the best photobooth software can elevate the experience and create lasting memories. In this guide, we will explore some of the top software options for running a photobooth at your event, with a focus on features like Photobooth Web online, virtual photo booth online free services, and innovative tools like photo booth 360 and mirror photo booth experiences. [View gallery][1] for interesting designs. [1]: https://www.photoboothweb.id/gallery
mdaasik90
mdaasik90 posted this 6 days ago
Fantastic post! The importance of data-driven SEO agency in dubai cannot be overstated. Your insights on analytics and performance tracking were right on point.
SEO servcies in KSA
seo agency in bahrain
Fantastic post! The importance of data-driven [SEO agency in dubai][1] cannot be overstated. Your insights on analytics and performance tracking were right on point. [SEO servcies in KSA][2] [seo agency in bahrain][3] [1]: https://shaazseoagency.ae/ [2]: https://shaazseoagency.ae/top-seo-agency-in-saudi-arabia-ksa/ [3]: https://shaazseoagency.ae/top-seo-agency-in-bahrain/
lightfury621
lightfury621 posted this 5 days ago
Applebee’s is known for its welcoming atmosphere, delicious food, and fantastic drink options, making it a popular destination for both casual dining and special occasions. But what truly sets it apart is the Applebee’s Happy Hour Menu, offering some of the best deals on food and drinks during specific hours of the day. Whether you’re looking for a quick bite after work or a relaxing evening with friends, the Happy Hour deals at Applebee’s ensure you enjoy great food at a discounted price. In this guide, we’ll explore everything you need to know about Applebee’s Happy Hour Menu, from the timings and deals to the most popular items you must try. See here for more info.
Applebee’s is known for its welcoming atmosphere, delicious food, and fantastic drink options, making it a popular destination for both casual dining and special occasions. But what truly sets it apart is the Applebee’s Happy Hour Menu, offering some of the best deals on food and drinks during specific hours of the day. Whether you’re looking for a quick bite after work or a relaxing evening with friends, the Happy Hour deals at Applebee’s ensure you enjoy great food at a discounted price. In this guide, we’ll explore everything you need to know about Applebee’s Happy Hour Menu, from the timings and deals to the most popular items you must try. [See here][1] for more info. [1]: https://applebees-happyhour.com/applebees-oriental-chicken-salad/
