Deleted pages still shows when the theme is exported
OCPR
OCPR posted this 06 December 2015
I am working with HTML5 themes and I noticed that if I create a new page and then delete it Themler will still create those "deleted" pages on the export Zip file. Also If I use a different name on "Title" and "Navigation Level" (on page properties) the Export Zip file will create two different pages (one for the name on "Title and one with the name on "Navigation Level")
Any way I can correct this?
Thank you!
Hi, I am working with HTML5 themes and I noticed that if I create a new page and then delete it Themler will still create those "deleted" pages on the export Zip file. Also If I use a different name on "Title" and "Navigation Level" (on page properties) the Export Zip file will create two different pages (one for the name on "Title and one with the name on "Navigation Level") Any way I can correct this? Thank you!
15 Comments
Support Team posted this 09 December 2015
Sorry for the delay.
In general, these two issues are the same issue. I've reported it to our developers. We'll let you know when we receive any news from them.
Hi, Sorry for the delay. In general, these two issues are the same issue. I've reported it to our developers. We'll let you know when we receive any news from them. Thank you, Olivia
OCPR
OCPR posted this 24 December 2015
Any updates on the fix for this bug?
Thank you!
Hi Any updates on the fix for this bug? Thank you!
Support Team posted this 24 December 2015
The fix will be included into the next hot-fix update.
Hi, The fix will be included into the next hot-fix update. Thank you, Olivia
OCPR
OCPR posted this 05 January 2016
Good, it has been fixed with the Dec 24 update, but it only works for new created themes, if I upgrade an old theme it still have the issue.
thank you!
Good, it has been fixed with the Dec 24 update, but it only works for new created themes, if I upgrade an old theme it still have the issue. thank you!
Support Team posted this 06 January 2016
I'll contact our developers regarding this.
Hi, I'll contact our developers regarding this. Sincerely, Hella
Support Team posted this 09 January 2016
After saving the template you need to reload Themler. Also in any case you will need to remove the unnecessary pages for one time.
Sorry for the inconvenience.
Hi, After saving the template you need to reload Themler. Also in any case you will need to remove the unnecessary pages for one time. Sorry for the inconvenience. Sincerely, Hella
david.blyth
david.blyth posted this 10 September 2016
I am still experiencing this, all deleted files still appear when the template is exported, including a folder and files for Blog despite the fact I have deleted all reference to it.
I have saved the html5 theme reloaded Themler and exported again and the files are still exported this is a ridiculous situation to be in with all these excess files, there should be a solution by now.
Please advise
David
Hi I am still experiencing this, all deleted files still appear when the template is exported, including a folder and files for Blog despite the fact I have deleted all reference to it. I have saved the html5 theme reloaded Themler and exported again and the files are still exported this is a ridiculous situation to be in with all these excess files, there should be a solution by now. Please advise Regards David
Support Team posted this 12 September 2016
The initially reported issue no longer happens on my side.
Could you please create a separate Private topic and attach the problem theme.
Hi, The initially reported issue no longer happens on my side. Could you please create a separate Private topic and attach the problem theme. Thank you, Olivia
david.blyth
david.blyth posted this 12 September 2016
Hi Olivia
Please find the exported zip file with the theme
David
Hi Olivia Please find the exported zip file with the theme Regards David
Support Team posted this 15 September 2016
Could you please attach the theme with Themler? We need to see what pages exist in the Themler and also check the theme version.
The attached theme is without Themler.
Hi, Could you please attach the theme with Themler? We need to see what pages exist in the Themler and also check the theme version. The attached theme is without Themler. Thank you, Olivia
david.blyth
david.blyth posted this 15 September 2016
Requested file attached
Support Team posted this 19 September 2016
Hello David,
I see the several pages which are not listed in menu, e.g.Rabbit, Pork and Beef, etc. Do you mean that these pages are removed ones?
In fact these pages do exist and they could be included into menu at any time.
If page is deleted in following way
then this page is not included into exported site. I've just checked it with your project.
Please follow the same procedure and let us know the results.
Hello David, I see the several pages which are not listed in menu, e.g.Rabbit, Pork and Beef, etc. Do you mean that these pages are removed ones? In fact these pages do exist and they could be included into menu at any time. If page is deleted in following way !DeletePage.png! then this page is not included into exported site. I've just checked it with your project. Please follow the same procedure and let us know the results. regards, Aileen
jk62
jk62 posted this 06 October 2017
I have this problem on my template. There are loads of pages and subdirectories in my HTML export that don't exist in my theme.
Can you please advise how I can remove these?
I have this problem on my template. There are loads of pages and subdirectories in my HTML export that don't exist in my theme. Can you please advise how I can remove these?
Support Team posted this 12 October 2017
The extra pages can be removed manually from the theme folder.
The original issue from this topic is already fixed. But there is could be another problem that need to be investigated. If you want us to check this issue please create a new topic and provide step by step instruction on how to reproduce the issue.
Hi, The extra pages can be removed manually from the theme folder. The original issue from this topic is already fixed. But there is could be another problem that need to be investigated. If you want us to check this issue please create a new topic and provide step by step instruction on how to reproduce the issue. Thank you, Olivia
emailrobind
emailrobind posted this 22 November 2020
same thing happening here
