themler.com ssl not valid, and i cant update themler for desktop-windows, and themler cant load on firefox.
mrottman3
mrottman3 posted this 09 December 2015
i just installed the themler windows software, the joomla theme has a update, at first when i press the login icon i get a sad face icon insted of loging into the biilindigital account, it happens becoas of the ssl cartification that is not valid, and seccond it is also ment for "themler.com" and not "accounts.themler.com" after i manage to bypass that problem (as a technology geek i found a way) so i get a promission error that i cant update the theme, i am using the pc as the administrator user.
i am attaching some screenshots
i am using win 8.1, and last version of chrome.
the only option to solve this prommissions error is bu me installing wamp server before themler, and then running themler as administrator.
i also have a simmilior problem with firefox, the windows can't pass the themler loading page (remote server, and loacel server) becose it will not load javascript from your website, and your website dosnt have a valid carttification signiture.
i just installed the themler windows software, the joomla theme has a update, at first when i press the login icon i get a sad face icon insted of loging into the biilindigital account, it happens becoas of the ssl cartification that is not valid, and seccond it is also ment for "themler.com" and not "accounts.themler.com" after i manage to bypass that problem (as a technology geek i found a way) so i get a promission error that i cant update the theme, i am using the pc as the administrator user. i am attaching some screenshots i am using win 8.1, and last version of chrome. the only option to solve this prommissions error is bu me installing wamp server before themler, and then running themler as administrator. i also have a simmilior problem with firefox, the windows can't pass the themler loading page (remote server, and loacel server) becose it will not load javascript from your website, and your website dosnt have a valid carttification signiture.
mrottman3
mrottman3 posted this 10 December 2015
here is a screen record that exams all the problem described above.
Support Team posted this 15 December 2015
Unfortunately, there is a known issue with SSL certificate on our end.
I would recommend you to temporarily disable it.
Then your website should work fine.
Hello, Unfortunately, there is a known issue with SSL certificate on our end. I would recommend you to temporarily disable it. Then your website should work fine. regards, Aileen
