Wordpress Margin between Posts
Wendel
Wendel posted this 14 December 2015
Hallo, How can I target margin with css in Themler so posts on my blog page in Wordpress seperates. I gave the "posts" in Themler a light grey background, but on my blog page there is no seperation between the posts. The light grey starts at the top and extends to the bottom of the posts on the blog page.
Support Team posted this 16 December 2015
You can set the Posts >> Grid >> Item >> Margin bottom to the desired value. And add the Fill color for the Posts >> Article.
Hi, You can set the Posts >> Grid >> Item >> Margin bottom to the desired value. And add the Fill color for the Posts >> Article. Sincerely, Hella
Wendel
Wendel posted this 19 December 2015
Hallo Hella,
This did not work. This added space between the posts, but the grey area for each post I need seperate. So the posts will appear as blocks.
Thank you.
Hallo Hella, This did not work. This added space between the posts, but the grey area for each post I need seperate. So the posts will appear as blocks. Thank you.
Support Team posted this 20 December 2015
Please attach your theme so I could review the settings.
Hi, Please attach your theme so I could review the settings. Sincerely, Hella
