Wordpress footer/header section import issue
Mark Holland
Mark Holland posted this 16 December 2015
Hi I have an issues with themler and wordpress not importing the footers and other sectional code. Its quite long winded but basically when i try and download and import from a zip i get the following error.
Error Unable to apply a preset. Wrong file format or it is corrupted
I have also posted a video here: https://drive.google.com/file/d/0B8qjEAb869SydFhlZlByakpWVTA/view
Thanks Mark Holland
Hi I have an issues with themler and wordpress not importing the footers and other sectional code. Its quite long winded but basically when i try and download and import from a zip i get the following error. Error Unable to apply a preset. Wrong file format or it is corrupted I have also posted a video here: https://drive.google.com/file/d/0B8qjEAb869SydFhlZlByakpWVTA/view Thanks Mark Holland
Mark Holland
Mark Holland posted this 17 December 2015
Anyone???
Anyone???
Support Team posted this 17 December 2015
Hello Mark,
We are sorry for confusion. The fact is that currently .zip files available on BillionThemes for sections contain HTML themes. So it is necessary, to open this theme, select a section and export it using "Export as ZIP" option and then import this ZIP in Themler.
As an alternative, this section can be added by going to Home >> Add Section from Clipart in the Property Window or Insert >> Section and then Section >> Apply From Clipart.
Hello Mark, We are sorry for confusion. The fact is that currently .zip files available on BillionThemes for sections contain HTML themes. So it is necessary, to open this theme, select a section and export it using "Export as ZIP" option and then import this ZIP in Themler. As an alternative, this section can be added by going to **Home** >> **Add Section from Clipart** in the Property Window or Insert >> Section and then **Section** >> **Apply From Clipart**. Sincerely, Nettie, BillionDigital Team
Valdemar de Salo
Valdemar de Salo posted this 26 November 2025
Hey, nachdem ich deinen Beitrag über WordPress Footer-Probleme gelesen habe, wollte ich mich kurz ablenken und stieß auf https://moro-spin.co.at . Für Spieler aus Österreich gibt es dort spezielle Boni, die das Entdecken von Spielen interessant machen. Die Plattform bietet Slots, Kartenspiele und Live-Dealer mit einer benutzerfreundlichen Oberfläche. Die schnellen Auszahlungen sorgen für zusätzlichen Komfort. So konnte ich mich kurz entspannen und etwas Unterhaltung genießen.
Valdemar de Salo
