Hello.
I want some templates for DRUPAL. I choosed DRUPAL and I saw still only templates for html (Section). Do You have some templates for DRUPAL in Themler?
VS
Hello.
VS
When you open the BillionThemes you should also select the Themes in the Type section.
Hi.
1 - I opened http://templates.themler.com/Themes
2 - At first I choose "Created With" - Themler
3 - At second I choose CMS Type - Drupal
4 - And next I opened some templates, but I saw download only "Free HTML Download"
I want some template, which I can modify for myself. But I didn“t see.
VS
As I said before, please also select the Product Type >> Theme. If you do not select it, it shows the themes and sections all in one, sections go first as they were added more recently. That's why you need to select Themes.
thank You. But if I choosed theme fo Drupal, I found only 9 themes. :-(
BS
Unfortunately there indeed not many Drupal themes.
