Mor CSS Control
pablomartinez
pablomartinez posted this 19 December 2015
Recently I purchased some plugins for my Wordpress but I have a problem designing and working with this plugins, the CSS of Themler template is intrusive and makes my plugins don't show correctly and have to work hard to solve all of this problems.
I think this point is important to make Themler templates very more powerfull and for increase the compatibility with more websites.
Recently I purchased some plugins for my Wordpress but I have a problem designing and working with this plugins, the CSS of Themler template is intrusive and makes my plugins don't show correctly and have to work hard to solve all of this problems. I think this point is important to make Themler templates very more powerfull and for increase the compatibility with more websites.
19 Comments
Support Team posted this 19 December 2015
Could you please provide the exact examples of the CSS conflicts.
The point is that the plug-in developers should also create a CSS code that will override the template settings in order to work fine with any possible template.
Hi, Could you please provide the exact examples of the CSS conflicts. The point is that the plug-in developers should also create a CSS code that will override the template settings in order to work fine with any possible template. Sincerely, Hella
pablomartinez
For example with the White Login Label, when modifies the comments... you can see at the image...
Support Team posted this 20 December 2015
Hello Pablo,
most probably the CCS code specific for Themler theme and plugin bring a kind of conflict.
Please provide a link to the page that demonstrates the issue and let us know what exactly you'd like to change.
Hello Pablo, most probably the CCS code specific for Themler theme and plugin bring a kind of conflict. Please provide a link to the page that demonstrates the issue and let us know what exactly you'd like to change. Regards, Aileen
feliciahwilliams6
feliciahwilliams6 posted this 21 March 2025
I think this point is important to make Themler templates very more powerfull and for increase the download anime slayer compatibility with more websites.
I totally get your frustration. Enhancing Themler templates to improve compatibility with plugins and minimize CSS conflicts would make it much easier to use. It would also help increase its flexibility, allowing for smoother integration with a wider range of websites.
> Recently I purchased some plugins for my Wordpress but I have a problem designing and working with this plugins, the CSS of Themler template is intrusive and makes my plugins don't show correctly and have to work hard to solve all of this problems. > > I think this point is important to make Themler templates very more powerfull and for increase the [download anime slayer][1] compatibility with more websites. > I totally get your frustration. Enhancing Themler templates to improve compatibility with plugins and minimize CSS conflicts would make it much easier to use. It would also help increase its flexibility, allowing for smoother integration with a wider range of websites. [1]: https://animeslayer.me/
roycarlson56
roycarlson56 posted this 22 April 2025
I think this point is important to make Themler templates very more powerfull and for increase the poor bunny compatibility with more websites.
Totally agree—Themler’s CSS can be overly aggressive and breaks plugin styling way too often. Improving compatibility would make a huge difference for users trying to build functional, flexible sites.
> Recently I purchased some plugins for my Wordpress but I have a problem designing and working with this plugins, the CSS of Themler template is intrusive and makes my plugins don't show correctly and have to work hard to solve all of this problems. > > I think this point is important to make Themler templates very more powerfull and for increase the [poor bunny][1] compatibility with more websites. Totally agree—Themler’s CSS can be overly aggressive and breaks plugin styling way too often. Improving compatibility would make a huge difference for users trying to build functional, flexible sites. [1]: https://poor-bunny.io
emily852paul
emily852paul posted this 23 April 2025
Here are some ways you might ease or solve the problem, and maybe even suggest improvements :
Workarounds You Can Try Now:
1. Use a Child Theme or Custom CSS Area Wisely
You can override Themler’s intrusive styles by:
Using plugin-specific selectors with higher specificity.
Avoiding !important unless absolutely necessary.
Targeting Themler’s generic styles and resetting them.
Ex:
/* If Themler styles are overriding a plugin button */
.plugin-button {
all: unset;
background: #0073aa;
color: white;
padding: 10px 20px;
2. Load Plugin CSS After Themler’s
Make sure your plugin's CSS is loading after Themler's. This way, plugin styles can override them naturally. You can do this by:
Adjusting wp_enqueue_style priorities.
Using the wp_footer or wp_head hook to enqueue custom plugin fixes later.
Use Scoped CSS or Namespaces
If the plugin allows it, or if you’re customizing it, try wrapping plugin elements inside a uniquely named container, like:
Then style it inside a CSS scope:
.my-plugin-wrapper .plugin-element {
/* safer styling */
Best Regard,
Emily
Get I-PASS
Hi, Here are some ways you might ease or solve the problem, and maybe even suggest improvements : Workarounds You Can Try Now: 1. Use a Child Theme or Custom CSS Area Wisely You can override Themler’s intrusive styles by: Using plugin-specific selectors with higher specificity. Avoiding !important unless absolutely necessary. Targeting Themler’s generic styles and resetting them. Ex: /* If Themler styles are overriding a plugin button */ .plugin-button { all: unset; background: #0073aa; color: white; padding: 10px 20px; } 2. Load Plugin CSS After Themler’s Make sure your plugin's CSS is loading after Themler's. This way, plugin styles can override them naturally. You can do this by: Adjusting wp_enqueue_style priorities. Using the wp_footer or wp_head hook to enqueue custom plugin fixes later. Use Scoped CSS or Namespaces If the plugin allows it, or if you’re customizing it, try wrapping plugin elements inside a uniquely named container, like: Then style it inside a CSS scope: .my-plugin-wrapper .plugin-element { /* safer styling */ } Best Regard, Emily [Get I-PASS][1] [1]: https://www-ipass.com
jacobpaul1253
jacobpaul1253 posted this 23 April 2025
Recently I purchased some plugins for my Wordpress but I have a problem designing and working with this plugins, the CSS of Themler template is intrusive and makes my plugins don't show correctly, level devil - not a troll game and have to work hard to solve all of this problems.
It would be great if Themler templates improved CSS compatibility to enhance plugin functionality and reduce design issues.
> Recently I purchased some plugins for my Wordpress but I have a problem designing and working with this plugins, the CSS of Themler template is intrusive and makes my plugins don't show correctly, [level devil - not a troll game][1] and have to work hard to solve all of this problems. > > I think this point is important to make Themler templates very more powerfull and for increase the compatibility with more websites. > It would be great if Themler templates improved CSS compatibility to enhance plugin functionality and reduce design issues. [1]: https://leveldevilnotatrollgame.io/
paulrobbins092
paulrobbins092 posted this 23 April 2025
Rome Air-Port Shuttle is your go-to service for stress-free private transportation in Rome. Whether flying into Fiumicino or heading to Civitavecchia Port, they offer timely, luxurious rides Mercedes car service Rome in premium vehicles. Their bilingual drivers ensure a warm welcome and safe journey, whether you’re visiting for a vacation or on a business trip. Choose from standard transfers or plan a private tour to destinations like Tuscany or Pompeii. Clear pricing, smooth service, and a commitment to excellence make them a trusted name in Rome. Book now and enjoy effortless travel.
Rome Air-Port Shuttle is your go-to service for stress-free private transportation in Rome. Whether flying into Fiumicino or heading to Civitavecchia Port, they offer timely, luxurious rides [Mercedes car service Rome][1] in premium vehicles. Their bilingual drivers ensure a warm welcome and safe journey, whether you’re visiting for a vacation or on a business trip. Choose from standard transfers or plan a private tour to destinations like Tuscany or Pompeii. Clear pricing, smooth service, and a commitment to excellence make them a trusted name in Rome. Book now and enjoy effortless travel. [1]: https://carservicesrome.com/
maazkhalid092
maazkhalid092 posted this 24 April 2025
Panaraya verbindet Klangkunst mit innerer Ruhe. Ihre Handpans sind ideal für alle, die Entspannung, Meditation oder klangtherapeutische Arbeit suchen. Die D-Kurd-Stimmung Handpan erzeugt weiche, fließende Töne, die sich intuitiv spielen lassen. Jedes Instrument ist sorgfältig gestimmt und handgefertigt, was eine besondere Klangqualität garantiert. Geeignet für Anfänger wie auch Fortgeschrittene, unterstützt Panaraya mit kostenlosem Versand und einfacher Rückgabe. Musik wird hier zur Reise nach innen. Die Handpan als meditativer Begleiter hilft dabei, neue Perspektiven zu entdecken und achtsame Momente zu genießen.
Panaraya verbindet Klangkunst mit innerer Ruhe. Ihre Handpans sind ideal für alle, die Entspannung, Meditation oder klangtherapeutische Arbeit suchen. Die D-Kurd-Stimmung [Handpan][1] erzeugt weiche, fließende Töne, die sich intuitiv spielen lassen. Jedes Instrument ist sorgfältig gestimmt und handgefertigt, was eine besondere Klangqualität garantiert. Geeignet für Anfänger wie auch Fortgeschrittene, unterstützt Panaraya mit kostenlosem Versand und einfacher Rückgabe. Musik wird hier zur Reise nach innen. Die Handpan als meditativer Begleiter hilft dabei, neue Perspektiven zu entdecken und achtsame Momente zu genießen. [1]: https://panaraya.com/
maazkhalid092
BestDaily curates mattress reviews that help shoppers find the best fit for their personal sleep style. Covering top brands with varied features like temperature control and body support, each guide mattress for heavy people presents honest evaluations based on user feedback and expert testing. From affordable memory foam to luxury hybrids, the content is tailored to different comfort preferences. Their streamlined approach makes the buying process smooth and informed. Whether you sleep on your side, back, or stomach, BestDaily has insights to match you with the perfect mattress.
BestDaily curates mattress reviews that help shoppers find the best fit for their personal sleep style. Covering top brands with varied features like temperature control and body support, each guide [mattress for heavy people][1] presents honest evaluations based on user feedback and expert testing. From affordable memory foam to luxury hybrids, the content is tailored to different comfort preferences. Their streamlined approach makes the buying process smooth and informed. Whether you sleep on your side, back, or stomach, BestDaily has insights to match you with the perfect mattress. [1]: https://bestdaily.com/mattresses
maazkhalid092
maazkhalid092 posted this 30 April 2025
Posh Paper Store brings luxury and creativity together through beautifully designed stationery and invitations. Perfect for weddings, milestone events, and formal celebrations, their collections are timeless and modern. Whether you’re planning a black-tie event or a cozy gathering, their paper goods phillip jeffries wallpaper add a personalized and polished touch. With customizable options and a wide variety of templates, there’s something for everyone. Each piece is printed on high-quality paper with attention to detail and care. Their commitment to customer satisfaction makes the design and ordering process stress-free and enjoyable. Impress your guests before the event even begins with invitations that reflect your style. Posh Paper Store turns paper into lasting memories.
Posh Paper Store brings luxury and creativity together through beautifully designed stationery and invitations. Perfect for weddings, milestone events, and formal celebrations, their collections are timeless and modern. Whether you’re planning a black-tie event or a cozy gathering, their paper goods [phillip jeffries wallpaper][1] add a personalized and polished touch. With customizable options and a wide variety of templates, there’s something for everyone. Each piece is printed on high-quality paper with attention to detail and care. Their commitment to customer satisfaction makes the design and ordering process stress-free and enjoyable. Impress your guests before the event even begins with invitations that reflect your style. Posh Paper Store turns paper into lasting memories. [1]: https://www.poshpaperstore.com/
emilycandy1012
emilycandy1012 posted this 16 July 2025
I have never seen a blog as remarkable as this one. I suppose I'll tell those who know me about these level devil.
I have never seen a blog as remarkable as this one. I suppose I'll tell those who know me about these [level devil][1]. [1]: https://level-devil.io
charliechaplindunnd
charliechaplindunnd posted this 01 August 2025
To determine which CSS rules are influencing your plugins, use the developer tools in the browser (right-click on the element and choose "Inspect"). Check for styles that are replacing the styles in your plugin bitlife The CSS of the template may sometimes have more specificity. To make sure your plugin styles take priority, you may make them more precise.
To determine which CSS rules are influencing your plugins, use the developer tools in the browser (right-click on the element and choose "Inspect"). Check for styles that are replacing the styles in your plugin [bitlife][1] The CSS of the template may sometimes have more specificity. To make sure your plugin styles take priority, you may make them more precise. [1]: https://lifesimulator.online/
johnwick566
johnwick566 posted this 13 August 2025
I’ve faced a similar issue when using Themler themes with some custom plugins — the default CSS often overrides important plugin styles. What worked for me was isolating plugin elements inside a unique wrapper class and then writing targeted rules. I’ve documented the process in detail here on Anime Witchers, which might help others troubleshoot without breaking the overall site design.
I’ve faced a similar issue when using Themler themes with some custom plugins — the default CSS often overrides important plugin styles. What worked for me was isolating plugin elements inside a unique wrapper class and then writing targeted rules. I’ve documented the process in detail [here][1] on Anime Witchers, which might help others troubleshoot without breaking the overall site design. [1]: https://animewitchers.com/
yandexapp40
yandexapp40 posted this 31 August 2025
Recently, I purchased several plugins for my WordPress site, but I’ve been running into issues when trying to design and integrate them. The CSS from the Themler template is very intrusive, causing many of the plugins to display incorrectly. Fixing these conflicts requires a lot of extra time and effort.
Improving how Themler handles CSS would make the templates far more powerful and significantly enhance their compatibility with third-party plugins and tools, including popular apps like Anime Witcher.
Recently, I purchased several plugins for my WordPress site, but I’ve been running into issues when trying to design and integrate them. The CSS from the Themler template is very intrusive, causing many of the plugins to display incorrectly. Fixing these conflicts requires a lot of extra time and effort. Improving how Themler handles CSS would make the templates far more powerful and significantly enhance their compatibility with third-party plugins and tools, including popular apps like [Anime Witcher][1]. [1]: https://animewitcher.org/
yandexapp40
I’ve been testing a few WordPress plugins lately, and I keep facing the same issue: the default CSS from Themler overrides many plugin styles. This makes certain layouts break or display incorrectly, and I end up spending hours adjusting the code manually.
It would be great if future updates of Themler offered better CSS isolation or compatibility options. That way, templates could work more smoothly with external tools and popular apps like HiTV without requiring so much extra effort.
I’ve been testing a few WordPress plugins lately, and I keep facing the same issue: the default CSS from Themler overrides many plugin styles. This makes certain layouts break or display incorrectly, and I end up spending hours adjusting the code manually. It would be great if future updates of Themler offered better CSS isolation or compatibility options. That way, templates could work more smoothly with external tools and popular apps like [HiTV][1] without requiring so much extra effort. [1]: https://hitv-apk.org/
yandexapp40
Possible Solutions & Improvements for Themler CSS Conflicts
If you’re struggling with Themler’s CSS interfering with plugin layouts, here are some practical steps you can take right now, along with ideas for long-term improvements:
Workarounds You Can Apply Immediately
1. Override Styles with Custom CSS or a Child Theme
  • Use more specific selectors to target plugin elements.
  • Reset or neutralize intrusive Themler rules.
  • Keep !important as a last resort.
Example:
css
/* Resetting Themler’s override on plugin buttons */
.plugin-button {
all: unset;
color: #fff;
padding: 10px 20px;
border-radius: 4px;
2. Ensure Plugin CSS Loads After Themler
  • Adjust wp_enqueue_style priorities so plugin styles take precedence.
  • If needed, enqueue CSS fixes later in the wp_footer or wp_head hooks.
3. Use Scoped CSS or Namespaces
  • Wrap plugin content in a custom container (e.g., .my-plugin-wrapper).
  • Apply scoped rules only within that namespace to avoid global conflicts.
Example:
css
font-size: 16px;
line-height: 1.5;
Suggestions for Future Improvements
It would be highly beneficial if Themler offered better CSS isolation and compatibility settings. Features such as scoped styling, modular CSS loading, or plugin-friendly overrides would save developers countless hours and allow smoother integration with third-party tools and apps yacine tv.
**Possible Solutions & Improvements for Themler CSS Conflicts** If you’re struggling with Themler’s CSS interfering with plugin layouts, here are some practical steps you can take right now, along with ideas for long-term improvements: ### Workarounds You Can Apply Immediately **1. Override Styles with Custom CSS or a Child Theme** * Use more specific selectors to target plugin elements. * Reset or neutralize intrusive Themler rules. * Keep `!important` as a last resort. *Example:* ```css /* Resetting Themler’s override on plugin buttons */ .plugin-button { all: unset; background: #0073aa; color: #fff; padding: 10px 20px; border-radius: 4px; } ``` **2. Ensure Plugin CSS Loads After Themler** * Adjust `wp_enqueue_style` priorities so plugin styles take precedence. * If needed, enqueue CSS fixes later in the `wp_footer` or `wp_head` hooks. **3. Use Scoped CSS or Namespaces** * Wrap plugin content in a custom container (e.g., `.my-plugin-wrapper`). * Apply scoped rules only within that namespace to avoid global conflicts. *Example:* ```css .my-plugin-wrapper .plugin-element { font-size: 16px; line-height: 1.5; } ``` --- ### Suggestions for Future Improvements It would be highly beneficial if Themler offered **better CSS isolation and compatibility settings**. Features such as scoped styling, modular CSS loading, or plugin-friendly overrides would save developers countless hours and allow smoother integration with third-party tools and apps [yacine tv][1]. [1]: https://yacinetv--app.org/
animewitcher787
animewitcher787 posted this 10 November 2025
If themier offered best CSS setting then it will be beneficial. Character like styllin, CSS loading or plugin can save your hours and smooth flow with app anime witcher.
If themier offered best CSS setting then it will be beneficial. Character like styllin, CSS loading or plugin can save your hours and smooth flow with app [anime witcher][1]. [1]: https://animeswitcher.com/
animeslayers787
animeslayers787 posted this 10 November 2025
Themier CSS are long term improvement ideas for app like anime slayer.
If you’re struggling with Themler’s CSS interfering with plugin layouts, here are some practical steps you can take right now, along with ideas for long-term improvements: Themier CSS are long term improvement ideas for app like [anime slayer][1]. [1]: https://animeslayers.org/
