Hello.
I have Artisteer and Themler, I bought plugin for DRUPAL and I have many jobs on this CMS system.
But I don´t see any possibility for import themes from Artisteer to Themler. And work with and change it.
Please help.
VS
Hello.
Please help.
VS
Believe me, it goes faster to build one from scratch then to fix imported one from Artisteer. Not that it is so time demanding to finish Artisteer theme in Themler, but that it goes fast in Themler from zero.
I had some illusions about it in start. Now I never use Artisteer and import old themes to Themler.
Believe me, it goes faster to build one from scratch then to fix imported one from Artisteer. Not that it is so time demanding to finish Artisteer theme in Themler, but that it goes fast in Themler from zero. I had some illusions about it in start. Now I never use Artisteer and import old themes to Themler.Hi Valdemar,
Currently, you can only convert Artisteer projects to Themler themes for HTML, Joomla and WordPress.
Drupal conversion is not supported.
Thus, you need to create your Drupal theme from scratch only using Themler.
Ivan
Hello.
I finded templates for DRUPAl and I choose DRUPAL on Your web ((http://templates.themler.com/Themes/Index?Search.RelatedMediaId=&perPage=20&sorter=Newest&Search.Key=&Search.CategoryID=&Search.FunctionalCategoryID=&Search.TemplateCategoryID=&Search.Artisteer=False&Search.Theme=False&Search.Section=False&Search.Cms=21&Search.ShowFree=False&Search.ShowPaid=False)) but I see templates only for html. Your filter maybe doesn´t work.
V.Střelka
You should also choose Themler Theme in the filter as also sections are shown in the search results. Like this:
http://templates.themler.com/Themes/Index?Search.RelatedMediaId=&perPage=20&sorter=Newest&Search.Key=&Search.CategoryID=&Search.FunctionalCategoryID=&Search.TemplateCategoryID=&Search.Artisteer=False&Search.Theme=True&Search.Section=False&Search.Cms=21&Search.ShowFree=False&Search.ShowPaid=False
