Vertical menu
silentnickk
silentnickk posted this 23 December 2015
Can i to create a vertical menu with animation "accordion", as in artisteer?
14 Comments
Support Team posted this 24 December 2015
Unfortunately Themler vertical Menu supports popup layout only.
But we plan to support accordion vertical menu in the future.
Hi, Unfortunately Themler vertical Menu supports popup layout only. But we plan to support accordion vertical menu in the future. Thank you, Olivia
milu.cernochova
milu.cernochova posted this 29 January 2016
Please please, I need accordion vertical menu, too...
marc
marc posted this 22 February 2016
Do you have any idea when the vertical menu accordian will be avialable as I need one too?
I look forward to hearing from you
Marc
Do you have any idea when the vertical menu accordian will be avialable as I need one too? I look forward to hearing from you Regards Marc
Support Team posted this 24 February 2016
You can vote for this topic to pay the attention of our managers to such feature.
Hi, You can vote for this topic to pay the attention of our managers to such feature. Sincerely, Hella
Kommas.nl
Kommas.nl posted this 10 May 2016
Hope this comes in the near future. I started in Themler, but my client wants a vertical menu with accordian. Now i have to go back to Artisteer
Porrey
Porrey posted this 15 June 2016
Is the accordion effect ready?
Support Team posted this 15 June 2016
Unfortunately it is not implemented yet.
Hi, Unfortunately it is not implemented yet. Sincerely, Hella
info26
info26 posted this 15 July 2016
Is there a workaround? Or a way to integrate it by hand?
Support Team posted this 18 July 2016
as for Accordion solution I'd recommend that you look for ready solution on web. If you will need help incorporating it to Themler theme please let us know
Hello, as for Accordion solution I'd recommend that you look for ready solution on web. If you will need help incorporating it to Themler theme please let us know regards, Aileen
Konkane
Konkane posted this 02 August 2016
Avete idea delle tempistiche per implementare il menu verticale ad effetto fisarmonica?
Support Team posted this 03 August 2016
Hello Erwin,
unfortunately there're no new related to vertical menu now.
However accordion like behavior is available in responsive mode of vertical menu. So you may enable responsive for Desktops and use the settings
Hello Erwin, unfortunately there're no new related to vertical menu now. However accordion like behavior is available in responsive mode of vertical menu. So you may enable responsive for Desktops and use the settings !VMenuResp.png! Regards, Aileen
Malinka
Malinka posted this 22 October 2016
I have notice if you export theme from Artisteer to Themler the vmenu behavior from Artisteer follow into Themler.
Make vmenu in Artisteer and then export to Themler .
Best regards
Malinka
Hi I have notice if you export theme from Artisteer to Themler the vmenu behavior from Artisteer follow into Themler. Make vmenu in Artisteer and then export to Themler . Best regards Malinka
ganryfort
ganryfort posted this 17 November 2025
Hey, ich wollte schon länger genug sparen, um mir ein neues Gaming-Setup zu kaufen, aber alles lief schief – von kleinen Verlusten bis zu verpassten Gelegenheiten. Dann stieß ich auf ivybet und dachte, ich probiere mal etwas Neues. Ich habe „Starburst“ ausprobiert und war überrascht, wie spannend jede Runde war. Nach einigen Versuchen kam endlich ein Gewinn, der meine Laune richtig hob. Besonders die Boni für Spieler aus Deutschland machen alles noch interessanter. Jetzt nutze ich die Seite regelmäßig, um nach einem langen Arbeitstag ein bisschen Nervenkitzel zu genießen.
Hey, ich wollte schon länger genug sparen, um mir ein neues Gaming-Setup zu kaufen, aber alles lief schief – von kleinen Verlusten bis zu verpassten Gelegenheiten. Dann stieß ich auf [ivybet][1] und dachte, ich probiere mal etwas Neues. Ich habe „Starburst“ ausprobiert und war überrascht, wie spannend jede Runde war. Nach einigen Versuchen kam endlich ein Gewinn, der meine Laune richtig hob. Besonders die Boni für Spieler aus Deutschland machen alles noch interessanter. Jetzt nutze ich die Seite regelmäßig, um nach einem langen Arbeitstag ein bisschen Nervenkitzel zu genießen. [1]: https://ivybet.de
chinahousehold
chinahousehold posted this 30 November 2025
https://bothbest.muragon.com/
https://bothbest.bigcartel.com
https://bothbest.hp.peraichi.com/
https://kumu.io/bothbest
https://codoc.jp/sites/bothbest/
https://velog.io/@bothbest/posts
https://scrapbox.io/bothbest/
https://plaza.rakuten.co.jp/hssolar/
https://plaza.rakuten.co.jp/bothbest/
https://ameblo.jp/bamboofloor/
https://techdesigner.ru/users/bothbest/posts
https://www.hentai-foundry.com/user/bothbest/profile
https://www.hentai-foundry.com/user/chinabamboo/profile
https://bothbest.muragon.com/ https://bothbest.bigcartel.com https://bothbest.hp.peraichi.com/ https://kumu.io/bothbest https://codoc.jp/sites/bothbest/ https://velog.io/@bothbest/posts https://scrapbox.io/bothbest/ https://plaza.rakuten.co.jp/hssolar/ https://plaza.rakuten.co.jp/bothbest/ https://ameblo.jp/bamboofloor/ https://techdesigner.ru/users/bothbest/posts https://www.hentai-foundry.com/user/bothbest/profile https://www.hentai-foundry.com/user/chinabamboo/profile
