Automatic backup of themes?
funmaking
funmaking posted this 11 December 2014
I have seen in my hosting account many backups of my theme. Some of them when I don't work in theme updating or changing nothing and other when I have update the theme to last version.
Is this normal? This issue makes the disk space is growing without my supervision.
I send you a screenshot:
enter image description here
Hello, I have seen in my hosting account many backups of my theme. Some of them when I don't work in theme updating or changing nothing and other when I have update the theme to last version. Is this normal? This issue makes the disk space is growing without my supervision. I send you a screenshot: ![enter image description here][1] Thank you [1]: http://i59.tinypic.com/14lh3bt.png
Support Team posted this 11 December 2014
The new .zip file is generated every time you download the theme. You can delete them now manually.
From our side we'll consider this issue in the future updates and will try to make the template removal process automatic.
Hi, The new .zip file is generated every time you download the theme. You can delete them now manually. From our side we'll consider this issue in the future updates and will try to make the template removal process automatic. Sincerely, Hella BillionDigital Team
funmaking
I haven't downloaded the theme, only I have updated it.
It may be because I have tried to send the theme from my hosting to billionthemes....
I haven't downloaded the theme, only I have updated it. It may be because I have tried to send the theme from my hosting to billionthemes....
Support Team posted this 12 December 2014
Indeed, it creates the back up in such situation as well. Our developers are working on this issue now.
Hi, Indeed, it creates the back up in such situation as well. Our developers are working on this issue now. Sincerely, Hella BillionDigital Team
