Hi , I like the new ui, it has great promise, but there are still a number of things that can be done more streamlined...
I am missing the option to change a section . currently you can only load a section from zip, but you can't actually change a section to one from the online themler library. in the older version you had it. this means that now you have to delete a section, and add a new one, which is an unecessary step i think.
the additional css and html look really small when they are in the right side, i don't know why, but i preferred them on the left side....its a matter or preference ofcourse.
another thing i think is strange about the ui, is that a lot of styles are reffered to as "image style". for instance, i put a map control, and i have an option called "image style" to put some presets... but it needs to actually be "map style" , because there is no image there! this happenes on other controls also, and i am used to it, but i think it will be more logical to call it in another name... its more logical to delete the word "image" and just put "style" in there .
I am really missing a tab for alignment options. for instance, you said a few months ago you will add the option to center elements in absolute containers , and currently there is no option for it, which makes users have to edit the left:0px right:0px margin-right:auto margin-left:auto each time, which is realy tidious, plus if someone doesn't do it, he will have lots of problems in responsive mode if he doesn't know this fix.
Other than that i really like the new version....
Thanks for your time :)
