tabel or list
arawolf
arawolf posted this 04 January 2016
How can i put in a table ( 3 rows and 2 column ) or a list into a container
Support Team posted this 06 January 2016
1) Use Insert -> Layout Container to add a Container, then Use Insert -> Row with Columns to add a Row into a Container. Add 4 more Columns. Set 12 for the Tablet mode for each column.
Pleas note that Columns are located on the Row Tab.
2) Use Insert -> Layout Container to add a Container, then use Insert-> More -> HTML to add and HTML block. Use Edit HTML to enter the list code.
We will add list editing in one of the future updates.
Thank you!
1) Use Insert -> Layout Container to add a Container, then Use Insert -> Row with Columns to add a Row into a Container. Add 4 more Columns. Set 12 for the Tablet mode for each column. Pleas note that Columns are located on the Row Tab. 2) Use Insert -> Layout Container to add a Container, then use Insert-> More -> HTML to add and HTML block. Use Edit HTML to enter the list code. We will add list editing in one of the future updates. Thank you!
arawolf
arawolf posted this 06 January 2016
i don't get it. I want a table with 3 rows . So i add 1 collumn but how get i mutiple rows.
Support Team posted this 12 January 2016
Simply add one more "Row with Columns" control. Each control creates one row.
Anyway, Row with Columns is more a layout control than content control. If you need a content table or list I suggest that you add it using CMS.
Hi, Simply add one more "**Row** with Columns" control. Each control creates one row. Anyway, Row with Columns is more a layout control than content control. If you need a content table or list I suggest that you add it using CMS. Thank you, Olivia
