Finally found it after manually putting in the no-lightbox class on each image.
For anyone struggling to find the Posts tab this is how I found it:
Template:Default (On the left hand side of the screen) then select the Posts either on the main screen or turn the Tree view on (to the right of Template:Default) Template:Default and select Content >> Posts
Then select the Posts tab on the horizontal menu >> Controls >> Post Content >> Image Lightbox:
Perhaps this could be made more intuitive in further updates. Perhaps in styles >> images?
For anyone struggling to find the **Posts tab** this is how I found it:
**Template:Default** (On the left hand side of the screen) then select the **Posts** either on the main screen or turn the **Tree view** on (to the right of Template:Default) **Template:Default** and select **Content** >> **Posts**
Then select the **Posts tab** on the horizontal menu >> **Controls** >> **Post Content** >> **Image Lightbox:**
