not change this store woocomerce s.o.s.
vicentea
vicentea posted this 06 January 2016
Happy new year.
they upgraded my account but I have not change this store woocomerce and customer me this by pressing for quer do not see changes
and now that I already do the made everything more why I upgrade
Happy new year. they upgraded my account but I have not change this store woocomerce and customer me this by pressing for quer do not see changes and now that I already do the made everything more why I upgrade
Support Team posted this 06 January 2016
Sorry, but your question is not clear. Maybe you could provide more detailed explanation and you can also write in your native language, we'll use translator.
Hi, Sorry, but your question is not clear. Maybe you could provide more detailed explanation and you can also write in your native language, we'll use translator. Sincerely, Hella
vicentea
vicentea posted this 07 January 2016
se supone que amplie la cuenta para poder trabajar en woocomerce tengo este cliente http://ecoenergyhn.com/tienda/ que es la imagen que les envie dicha tienda ocupo editarla.
se supone que al pagar los $199 hiba poder editar estas tiendas y no puedo por que
se supone que amplie la cuenta para poder trabajar en woocomerce tengo este cliente http://ecoenergyhn.com/tienda/ que es la imagen que les envie dicha tienda ocupo editarla. se supone que al pagar los $199 hiba poder editar estas tiendas y no puedo por que
Support Team posted this 12 January 2016
Hello Vincente,
do you mean that you have got a problem creating WooCommerce theme?
If yes, please describe it in details.
Hello Vincente, do you mean that you have got a problem creating WooCommerce theme? If yes, please describe it in details. regards, Aileen
vicentea
vicentea posted this 15 January 2016
Saludos el problema lo tengo con ecoenergyhn.com/tienda diseñe la tienda en la aplicación en linea , pero cuando toca editar directamente dicha página no me permite editarla y pone un fondo blanco y el cliente me pregunta que pasa.
Recomiéndeme navegador web para trabajar y sistema operativo
Saludos el problema lo tengo con ecoenergyhn.com/tienda diseñe la tienda en la aplicación en linea , pero cuando toca editar directamente dicha página no me permite editarla y pone un fondo blanco y el cliente me pregunta que pasa. Recomiéndeme navegador web para trabajar y sistema operativo
Support Team posted this 21 January 2016
Hello Vincente,
have you got a problem with editing content directly in Themler? If yes, what exactly you have tried to edit?
Several screenshots which demonstrates the issue would be helpful.
Hello Vincente, have you got a problem with editing content directly in Themler? If yes, what exactly you have tried to edit? Several screenshots which demonstrates the issue would be helpful. regards, Aileen
