Would be great to remove the themler icon in the backend afterwards.
Would be great to remove the themler icon in the backend afterwards.Hi,
You can download theme without Themler and re-install it:
In this case Themler will not be included into the theme at all.
I know this feature. But I mean after installing on clients side.
I know this feature. But I mean after installing on clients side.OK, we'll let our users vote for this option.
Dear Hella,
I have the same problem. When i installed all to client i need to remove THEMLER from backend. I tried to uncheck this option, exported as .ZIP folder the theme. Then installed the theme, but then the content, menu, flags, etc. all got mixed up, nothing was ok on front end.
Some other solution or better please?? Thanks!
Dear Hella, I have the same problem. When i installed all to client i need to remove THEMLER from backend. I tried to uncheck this option, exported as .ZIP folder the theme. Then installed the theme, but then the content, menu, flags, etc. all got mixed up, nothing was ok on front end. Some other solution or better please?? Thanks!You copied whole WordPress installation. At the same time you copied preview folder too.
You copied whole WordPress installation. At the same time you copied preview folder too.Hi,
You mean that if you export the theme with the editor included it looks different? There should be no such behavior. Please provide a link to your site and your theme with the editor included.
