slider in joomla
danielzawacki
danielzawacki posted this 09 January 2016
How to change the effects of the slider? I tried all the possibilities but nothing changes?
I do not understand what is the function of Add Extension?
Translate from french with google translate
Merci-Thamk you
DanielZ
How to change the effects of the slider? I tried all the possibilities but nothing changes? I do not understand what is the function of Add Extension? Translate from french with google translate Merci-Thamk you DanielZ
Support Team posted this 11 January 2016
There is no need to use the extension. Slider Effects are set at Slider Tab -> Carousel.
We will work on improving this.
Thank you!
Hi, There is no need to use the extension. Slider Effects are set at Slider Tab -> Carousel. !111.png! We will work on improving this. Thank you!
