When we translate a new theme.
The folders are named :
DE.php
FR.php
ES.php
I think it is not correct.
Actually when we have transfered the them in ftp on the website. The grafist must change the names to lowercase
de.php
fr.php
es.php
Could you check that on your side and fix it if needed - otherwise give us information to make the things more easy :)
Regards.
Remy
es.php
When we translate a new theme. The folders are named : DE.php FR.php ES.php I think it is not correct. Actually when we have transfered the them in ftp on the website. The grafist must change the names to lowercase de.php fr.php es.php Could you check that on your side and fix it if needed - otherwise give us information to make the things more easy :) Regards. Remy es.php
