New Version Themler is Great! Videos?
David Marchione
David Marchione posted this 10 January 2016
Awesome Product!!
There is so much to this new version and it's much easier to grasp than before. Understanding when and if I'll need to edit within WordPress, learning I need to turn on Content & Sidebars to do so was by chance. Learning what each Extension does and the correct process, will be trial and error, overtime. I also don't know what I don't know. Detailed training videos will greatly help. I'm guessing getting them done will cut into your development time.
1 Is adding HTML container a Control like Text? If so, where is it?
2 Does adding Text in a Section/Row carry over when Exporting to Zip? (for Desktop version to my live site)
3 I have Themler installed hosted and Desktop, but while Exporting, Importing it only works if I have the zip with "Include Themler" checked?
4 Detailed training videos for updated version. (I don't know what I don't know)
**Awesome Product!!** There is so much to this new version and it's much easier to grasp than before. Understanding when and if I'll need to edit within WordPress, learning I need to turn on Content & Sidebars to do so was by chance. Learning what each Extension does and the correct process, will be trial and error, overtime. I also don't know what I don't know. Detailed training videos will greatly help. I'm guessing getting them done will cut into your development time. 1 Is adding HTML container a Control like Text? If so, where is it? 2 Does adding Text in a Section/Row carry over when Exporting to Zip? (for Desktop version to my live site) 3 I have Themler installed hosted and Desktop, but while Exporting, Importing it only works if I have the zip with "Include Themler" checked? 4 Detailed training videos for updated version. (I don't know what I don't know)
Support Team posted this 11 January 2016
We are currently working on adding and improving video tutorials.
RE1: Please check Insert Tab -> More -> HTML
RE2: Yes, if exported as HTML. As for WP and Joomla, please refer to this video https://www.youtube.com/watch?v=be5zUafikAw
RE3: Yes, this is correct, Themler works as an add-on.
RE4: The work is in progress.
Thank you!
Hi, We are currently working on adding and improving video tutorials. RE1: Please check Insert Tab -> More -> HTML RE2: Yes, if exported as HTML. As for WP and Joomla, please refer to this video https://www.youtube.com/watch?v=be5zUafikAw RE3: Yes, this is correct, Themler works as an add-on. RE4: The work is in progress. Thank you!
Lex
Lex posted this 12 January 2016
Sorry the new Themler Version is bad...
i deinstall this Version and install the older Version Themler 1.0.93.95c52
in this version it is possible to arrange flexible header individually.
the new versions are unfortunately useless, since you can only insert sections and the layout is not available for customization.
e.g. I want the header to insert a logo and the right of a text link.
that just was not possible ... very complicated.
the version 0.93 is good - because you can easily content with drag and drop to move and adapt
why that was changed? :-(
Sorry the new Themler Version is bad... i deinstall this Version and install the older Version Themler 1.0.93.95c52 in this version it is possible to arrange flexible header individually. the new versions are unfortunately useless, since you can only insert sections and the layout is not available for customization. e.g. I want the header to insert a logo and the right of a text link. that just was not possible ... very complicated. the version 0.93 is good - because you can easily content with drag and drop to move and adapt why that was changed? :-(
Support Team posted this 13 January 2016
You mean that you need to have logo and text side by side in the header? You can insert the row with columns into the section and locate the logo in one column and the text in another. Basically nothing was changed except that the section wrapper was added into the header but that does not affect any other controls inserted inside it.
If you need to create some specific layout and do have problems with that, please attach a screen shot of how you want it to look like.
Hi, You mean that you need to have logo and text side by side in the header? You can insert the row with columns into the section and locate the logo in one column and the text in another. Basically nothing was changed except that the section wrapper was added into the header but that does not affect any other controls inserted inside it. If you need to create some specific layout and do have problems with that, please attach a screen shot of how you want it to look like. Sincerely, Hella
Also just a follow up. Maybe you are missing the absolute positioning that was in the default theme before update. You can set the Positioning >> Absolute for the desired controls (logo and text) within the section and drag and drop them as you want within the container.
The same can be achieved when adding the Box Absolute control within the section. All the controls within the Box will have the absolute positioning and you will be able to drag and drop them in any place within the Box.
Also just a follow up. Maybe you are missing the absolute positioning that was in the default theme before update. You can set the Positioning >> Absolute for the desired controls (logo and text) within the section and drag and drop them as you want within the container. The same can be achieved when adding the Box Absolute control within the section. All the controls within the Box will have the absolute positioning and you will be able to drag and drop them in any place within the Box. Sincerely, Hella
