Database
ABI WEB DESIGN
ABI WEB DESIGN posted this 12 January 2016
Hi,I am using SEO extension to create internal links for my website but this SEO extension affect only the text inserted in Joomla core article body.Some of the pages in my website are created by inserting the text in Themler directly and not in core Joomla article field,that is way internal links can't be created on this pages.I asked the other developers they said that will try to adjust their extension but they ask :
  **"Do you know where does that Themler save the description in database?
I will try to get that description by using the article ID."**
Greetings,
Mariyan
Hi,I am using SEO extension to create internal links for my website but this SEO extension affect only the text inserted in Joomla core article body.Some of the pages in my website are created by inserting the text in Themler directly and not in core Joomla article field,that is way internal links can't be created on this pages.I asked the other developers they said that will try to adjust their extension but they ask : **"Do you know where does that Themler save the description in database? I will try to get that description by using the article ID."** Greetings, Mariyan
Support Team posted this 13 January 2016
We are investigating this issue.
Thank you!
Hi, We are investigating this issue. Thank you!
Support Team posted this 20 January 2016
Hello Mariyan,
I'm sorry for delay in response.
Themler does not saves/edits Description value.
Please describe the issue is more details:
-what SEO plugin you're using?
-what exactly happens when you're trying to create external links for the articles which were edited in Themler?
Hello Mariyan, I'm sorry for delay in response. Themler does not saves/edits Description value. Please describe the issue is more details: -what SEO plugin you're using? -what exactly happens when you're trying to create external links for the articles which were edited in Themler? regards, Aileen
ABI WEB DESIGN
ABI WEB DESIGN posted this 20 January 2016
I am using MijoSEF for seo extension. The issue is not about the external links but about the internal links.I set the word "SEO" as internal link in my entire website and in the articles which come from Joomla core article body you can see this internal links - http://www.awesomescreenshot.com/image/922963/fb0418eef2a161f22fcd77fe0d6a25ea but on the pages where I insert the content using Themler elements, the internal links are not affected - http://www.awesomescreenshot.com/image/922972/1665c5ea37a0d660288b51119d807f58 and I will have to do it manually. The developer of the MijoSEF extension suggested to try fix this but they need to know -
"Where does that Themler save the description in database?I will try to get that description by using the article ID. "
So,if you can give me this information they may be able to adjust their extension working properly with Themler .
Greetings,
Mariyan
Hello, I am using MijoSEF for seo extension. The issue is not about the external links but about the internal links.I set the word "SEO" as internal link in my entire website and in the articles which come from Joomla core article body you can see this internal links - http://www.awesomescreenshot.com/image/922963/fb0418eef2a161f22fcd77fe0d6a25ea but on the pages where I insert the content using Themler elements, the internal links are not affected - http://www.awesomescreenshot.com/image/922972/1665c5ea37a0d660288b51119d807f58 and I will have to do it manually. The developer of the MijoSEF extension suggested to try fix this but they need to know - **"Where does that Themler save the description in database?I will try to get that description by using the article ID. "** So,if you can give me this information they may be able to adjust their extension working properly with Themler . Greetings, Mariyan
Support Team posted this 22 January 2016
Thanks.
Themler does not saves/edits Description value. Thanks.
