DFG
posted this
22 February 2017
Hi!
How to integrate Language control from Themler with WP CMS using plugins really has a lack of support and pure tutorial.
All we have is this article: http://answers.themler.com/articles/4765/language, and knowing that Language control added in Themler, the list of languages is hardcoded in functions.php file.
I do not understand how to success with this data mentioned above, and I am still having issue:
- Language control displays default menu in menu area. It is not editable in Themler, and I can not edit "lang" attribute in <html> tag (Should I edit/delete this in functions.php? What is the code?)
- I have set WPML plugin and all languages, with widget language selector enabled. It works!
How to integrate Language control from Themler with WPML plugin settings?
This way I language selector would be customizedIdesigned in Themler.
I believe this was also original concern here: "do not want to use a plugin for language-switcher because i can not customize it in Themler"
Hope to get your answer asap.
DFG
Hi!
DFG
