Themla Full Data Backup
len
len posted this 15 January 2016
In Artisteer I can backup each project as an artx file, its solid and it works.
How do I backup project data used by Themla, either individually or all at one go?
I have read a number of forum threads, and the only suggestion I see is to export the project with the editor as a zip file but will this work and contain all the Themla data.
There are other threads talking about the Wordpress installation in the Themla folder and database, but I dont see how this will work, and is there a different Wordpress install for each new theme I create?
My concern is if the PC goes down.
I have voted for the wishlist item to store Themla data on a different drive, I have RAID1 data drive which I would prefer to store Themla data on, then backup that to a network.
Please advise urgently.
In Artisteer I can backup each project as an artx file, its solid and it works. How do I backup project data used by Themla, either individually or all at one go? I have read a number of forum threads, and the only suggestion I see is to export the project with the editor as a zip file but will this work and contain all the Themla data. There are other threads talking about the Wordpress installation in the Themla folder and database, but I dont see how this will work, and is there a different Wordpress install for each new theme I create? My concern is if the PC goes down. I have voted for the wishlist item to store Themla data on a different drive, I have RAID1 data drive which I would prefer to store Themla data on, then backup that to a network. Please advise urgently.
Support Team posted this 18 January 2016
You are able to export and import theme as *.zip.
Thank you!
Hi, You are able to export and import theme as *.zip. !111.png! Thank you!
len
len posted this 16 December 2016
Can you please confirm,:
To save a theme as a backup and re-import in case I lose all data and need to re-install Themler, do export the theme with or without Themler for customising.
Can you please confirm,: To save a theme as a backup and re-import in case I lose all data and need to re-install Themler, do export the theme with or without Themler for customising.
Export the theme with the editor included to be able to import it in the Themler further.
Hi, Export the theme with the editor included to be able to import it in the Themler further. Sincerely, Hella
len
Is Solution
len posted this 21 December 2016
Thanks for confirming
LenW
Thanks for confirming LenW
