The Default Template, pages and posts
len
len posted this 15 January 2016
Using the desktop app, editing the default template the vertical scrollbar is missing so I cannot edit further down the page of the template.
I am trying to put a wordpress widget area above both the content and the right sidebar, also just above the footer area in a new section, both to be available on all pages of the website.
I have added the top one to the default template but the other page templates do not inherit it, how do I make that happen?
To add to my confusion there is a dropdown for Template, and then the change template icon, and also Pages and Posts to select. The "About", "FAQ", "History" pages, do these use the default or page template?
Can you please explain how this all relates and what inherits what.
Using the desktop app, editing the default template the vertical scrollbar is missing so I cannot edit further down the page of the template. I am trying to put a wordpress widget area above both the content and the right sidebar, also just above the footer area in a new section, both to be available on all pages of the website. I have added the top one to the default template but the other page templates do not inherit it, how do I make that happen? To add to my confusion there is a dropdown for Template, and then the change template icon, and also Pages and Posts to select. The "About", "FAQ", "History" pages, do these use the default or page template? Can you please explain how this all relates and what inherits what. Thanks
Support Team posted this 18 January 2016
Could you please illustrate what you are trying to achieve in screenshot?
Thank you!
Hi, Could you please illustrate what you are trying to achieve in screenshot? Thank you!
len
len posted this 25 January 2016
There is no scrollbar on the right side of the default template editor, so I can't see the footer and the bottom of the template. Picture attached with where it should be.
I am wanting to add more wordpress widget areas, including one below the content.
There is no scrollbar on the right side of the default template editor, so I can't see the footer and the bottom of the template. Picture attached with where it should be. I am wanting to add more wordpress widget areas, including one below the content.
Stagger Lee posted this 25 January 2016
Disable right sidebar. It is open.
Support Team posted this 27 January 2016
in case the issue persists please attach here your theme (save it with 'Include Themler..' option)
Hello, in case the issue persists please attach here your theme (save it with 'Include Themler..' option) regards, Aileen
