Disappearing module and no article edit button
Ian Shere
Ian Shere posted this 16 January 2016
Joomla 3.4.8
http://www.ckdev.info/atonement/school/middle-school-5-8/grade-7-8-homeroom-5-8-math
I have a CustomHTML module in a position just above content. All it holds is 3 links horizontally that I have applied the bd-button class to. If I reduce the screen size to below about laptop size it totally disappears. If I check page source the code's still there, but the module is invisible. I thought I may have inserted bootstrap code in the module to not display it - no. Module position, column, row in Themler - all set to display all.
Secondly, there's no way to edit Joomla articles in the frontend. Edit icons appear for modules (NOT wanted), but not edit icon for articles.
EDIT: Just checked on another site I have a Themler template on, and it has the same missing edit icon issue. This is a major issue!!
Joomla 3.4.8 http://www.ckdev.info/atonement/school/middle-school-5-8/grade-7-8-homeroom-5-8-math I have a CustomHTML module in a position just above content. All it holds is 3 links horizontally that I have applied the bd-button class to. If I reduce the screen size to below about laptop size it totally disappears. If I check page source the code's still there, but the module is invisible. I thought I may have inserted bootstrap code in the module to not display it - no. Module position, column, row in Themler - all set to display all. Secondly, there's no way to edit Joomla articles in the frontend. Edit icons appear for modules (NOT wanted), but not edit icon for articles. EDIT: Just checked on another site I have a Themler template on, and it has the same missing edit icon issue. This is a major issue!!
19 Comments
Ian Shere
OK I found a thread about lack of editing. https://answers.themler.com/questions/19928/joomla-article-front-end-editing
I added this control (cannot think of ANY logical reason why this is not included as standard), but it doesn't work. Selected Posts, Add Control | Post Edit | Save. Nothing.
PLEASE! Just add this back in - stop over-complicating the process!!
OK I found a thread about lack of editing. https://answers.themler.com/questions/19928/joomla-article-front-end-editing I added this control (cannot think of ANY logical reason why this is not included as standard), but it doesn't work. Selected Posts, Add Control | Post Edit | Save. Nothing. PLEASE! Just add this back in - stop over-complicating the process!! www.ckdev.info/atonement
Support Team posted this 20 January 2016
I'm terribly sorry for the delay in responding.
I have visited your site, checked the code and seems that the row that contains your buttons has the class that disables it in the tablet size screens. Please check that inside Themler.
As for the edit button, make sure that the post edit control was added within Themler to the appropriate Post control on the corresponding template. Then also the edit icon should be available for those posts within Joomla settings.
Hi, I'm terribly sorry for the delay in responding. I have visited your site, checked the code and seems that the row that contains your buttons has the class that disables it in the tablet size screens. Please check that inside Themler. As for the edit button, make sure that the post edit control was added within Themler to the appropriate Post control on the corresponding template. Then also the edit icon should be available for those posts within Joomla settings. Sincerely, Hella
Ian Shere
Ian Shere posted this 20 January 2016
That was odd. I never remember deactivating those views in the row, but, sure enough, they were. Thanks.
I did add the "Edit post" to the front page, but not subsequent. I mistakenly assumed that if I'd added it to the post on the front page it'd work like adding to sidebars and populate through every template. IMHO, this is the most logical behavior, although, honestly, I can't see a logical reason why we are even forced to add the ability to edit content anyway. This should be included just like editing modules is included. It's just there.
Anyway, I added it again, and then there were 3 copies appearing on the front page where there were none showing before. So deleted 2 and added to default template and it's all working now.
That was odd. I never remember deactivating those views in the row, but, sure enough, they were. Thanks. I did add the "Edit post" to the front page, but not subsequent. I mistakenly assumed that if I'd added it to the post on the front page it'd work like adding to sidebars and populate through every template. IMHO, this is the most logical behavior, although, honestly, I can't see a logical reason why we are even forced to add the ability to edit content anyway. This should be included just like editing modules is included. It's just there. Anyway, I added it again, and then there were 3 copies appearing on the front page where there were none showing before. So deleted 2 and added to default template and it's all working now.
Support Team posted this 21 January 2016
Sounds a bit strange about 3 copies of the edit button. In any case nice to hear that you have found the solution.
About editing the post control and changes appearing on one template only. When you open the post control options in the ribbon, you could see the Reset to Default and Set as default options. That allows you to set the styles of one Post control (from any template) as the default styles for the Post. And then in other templates use the Reset to Default option to apply those styles.
Hi, Sounds a bit strange about 3 copies of the edit button. In any case nice to hear that you have found the solution. About editing the post control and changes appearing on one template only. When you open the post control options in the ribbon, you could see the Reset to Default and Set as default options. That allows you to set the styles of one Post control (from any template) as the default styles for the Post. And then in other templates use the Reset to Default option to apply those styles. Sincerely, Hella
paulijennifer92
paulijennifer92 posted this 12 December 2022
It is very important to be able to edit the written article. In general, many people have problems with writing, but fortunately, nowadays they can be solved very easily. Once I found a cool superbpaper review, this educational resource helps people with their written works. I always advise my colleagues to use this service because excellent professionals work there. Also, sometimes I order my son's homework for college. Thanks to this, he has only the highest marks for his work.
It is very important to be able to edit the written article. In general, many people have problems with writing, but fortunately, nowadays they can be solved very easily. Once I found a cool [superbpaper review][1], this educational resource helps people with their written works. I always advise my colleagues to use this service because excellent professionals work there. Also, sometimes I order my son's homework for college. Thanks to this, he has only the highest marks for his work. [1]: https://bestessayservicesradar.com/superbpaper-review/
neiljiohu
neiljiohu posted this 09 September 2024
截止日期的紧迫性同样会影响论文代写的定价。通常来说,临近截止日期的订单会因为需要加班加点、加速完成而收取更高的费用。紧急订单往往意味着代写者需要在短时间内高强度地工作,甚至可能需要牺牲其他订单的进度以满足客户需求,因此论文代写 http://www.hotessay.net/ 服务提供者会要求额外的加急费用。
michaelhyes89
michaelhyes89 posted this 04 May 2026
I’ve run into a similar issue before, and it can be really frustrating when modules disappear and editing options vanish without warning. Sometimes it’s tied to permission settings or a recent update glitch. I found some helpful insights while checking Fort County Records that pointed me in the right direction. You might want to review user roles or clear cache to see if that brings the edit button back. Hopefully it gets resolved quickly!
I’ve run into a similar issue before, and it can be really frustrating when modules disappear and editing options vanish without warning. Sometimes it’s tied to permission settings or a recent update glitch. I found some helpful insights while checking [Fort County Records][1] that pointed me in the right direction. You might want to review user roles or clear cache to see if that brings the edit button back. Hopefully it gets resolved quickly! [1]: https://fortbendcountycourts.org
PatrickReynolds211
PatrickReynolds211 posted this 05 May 2026
That sounds really frustrating, especially when modules just disappear and basic options like editing aren’t available. I’ve run into similar glitches before, and sometimes checking system records or updates can give a bit more clarity on what’s going wrong. You might find some useful insights through Collin court lookup as well, since it helps track related updates and activity. Hopefully the issue gets resolved soon because not being able to edit articles can really slow things down.
That sounds really frustrating, especially when modules just disappear and basic options like editing aren’t available. I’ve run into similar glitches before, and sometimes checking system records or updates can give a bit more clarity on what’s going wrong. You might find some useful insights through [Collin court lookup][1] as well, since it helps track related updates and activity. Hopefully the issue gets resolved soon because not being able to edit articles can really slow things down. [1]: https://collincountycourts.org
JasonWhitaker12
JasonWhitaker12 posted this 05 May 2026
This issue often occurs when the editing module fails to load due to cache or session conflicts. Try clearing browser cache and re-logging to see if the edit option reappears. It can also help to check user permissions or switch to a different browser/device for testing. For related records and case access, you may also review detailed information at Palm Beach Court for reference. If the problem continues, a system refresh or temporary disable of extensions usually resolves missing UI elements.
This issue often occurs when the editing module fails to load due to cache or session conflicts. Try clearing browser cache and re-logging to see if the edit option reappears. It can also help to check user permissions or switch to a different browser/device for testing. For related records and case access, you may also review detailed information at [Palm Beach Court][1] for reference. If the problem continues, a system refresh or temporary disable of extensions usually resolves missing UI elements. [1]: https://palmbeachcountycourts.org
Lauren5Davis58
Lauren5Davis58 posted this 05 May 2026
That sounds really frustrating issues like disappearing modules and missing edit buttons can seriously slow things down. I ran into something similar recently and had to double-check system permissions and cache settings. While troubleshooting, I found some helpful insights through Volusia Court Records that gave me a better idea of how these systems behave. Hopefully it’s just a temporary glitch on your end and gets resolved soon. Keep us posted if you find the fix!
That sounds really frustrating issues like disappearing modules and missing edit buttons can seriously slow things down. I ran into something similar recently and had to double-check system permissions and cache settings. While troubleshooting, I found some helpful insights through [Volusia Court Records][1] that gave me a better idea of how these systems behave. Hopefully it’s just a temporary glitch on your end and gets resolved soon. Keep us posted if you find the fix! [1]: https://volusiacountycourts.org
sophiecharlessonsss
sophiecharlessonsss posted this 05 May 2026
In cricket forums, playinexch is being discussed as part of the evolving fan landscape. The experience feels more active compared to traditional watching. It brings a new rhythm to how matches are followed. That change is drawing attention from many enthusiasts.
In cricket forums, [playinexch][1] is being discussed as part of the evolving fan landscape. The experience feels more active compared to traditional watching. It brings a new rhythm to how matches are followed. That change is drawing attention from many enthusiasts. [1]: https://playinexchss.com/
deltaexecotr
deltaexecotr posted this 05 May 2026
If your module suddenly disappears and the article edit button is missing, it’s usually caused by a theme conflict, plugin error, or permission issue in your CMS. Start by clearing your cache and disabling recently added plugins to identify the conflict. Also check user roles—sometimes editor permissions get reset, which hides the edit option.
If you’re managing pages related to Delta Executor VNG, this issue can directly affect your updates and SEO performance. Make sure your admin access is intact and your theme files are not corrupted. Restoring a recent backup or switching to a default theme can quickly confirm whether the problem is theme-related.
If your module suddenly disappears and the article edit button is missing, it’s usually caused by a theme conflict, plugin error, or permission issue in your CMS. Start by clearing your cache and disabling recently added plugins to identify the conflict. Also check user roles—sometimes editor permissions get reset, which hides the edit option. If you’re managing pages related to **[Delta Executor VNG][1]**, this issue can directly affect your updates and SEO performance. Make sure your admin access is intact and your theme files are not corrupted. Restoring a recent backup or switching to a default theme can quickly confirm whether the problem is theme-related. [1]: https://deltaexecotr.com/delta-vng/
ropeherosemodapk
ropeherosemodapk posted this 06 May 2026
Rope Hero Mod APK is an upgraded and feature-rich version of the popular open-world action game developed by Naxeex Action & RPG Games. Designed for players who want complete control, limitless resources, and an uninterrupted experience, this version transforms the traditional gameplay into something far more dynamic and engaging. With powerful abilities, an expansive city, and unrestricted access to premium features, Rope Hero Mod APK stands as one of the most entertaining superhero-style mobile games available.
https://ropeherosemodapk.com/
Rope Hero Mod APK is an upgraded and feature-rich version of the popular open-world action game developed by Naxeex Action & RPG Games. Designed for players who want complete control, limitless resources, and an uninterrupted experience, this version transforms the traditional gameplay into something far more dynamic and engaging. With powerful abilities, an expansive city, and unrestricted access to premium features, Rope Hero Mod APK stands as one of the most entertaining superhero-style mobile games available. https://ropeherosemodapk.com/
waqaskhan.work1
waqaskhan.work1 posted this 14 June 2026
For the frontend editing issue, it can also be related to user permissions or template overrides that disable article edit icons while still allowing module edit links to appear.
I’ve seen similar behavior while checking different web and mobile execution environments and debugging setups. One reference I came across while working with related tooling is:
iOS execution tool reference
It might not be directly Joomla-specific, but it’s interesting from a debugging and environment handling perspective.
For the frontend editing issue, it can also be related to user permissions or template overrides that disable article edit icons while still allowing module edit links to appear. I’ve seen similar behavior while checking different web and mobile execution environments and debugging setups. One reference I came across while working with related tooling is: [iOS execution tool reference][1] It might not be directly Joomla-specific, but it’s interesting from a debugging and environment handling perspective. [1]: https://deltaexecutorsios.com/
neal.sutton2
neal.sutton2 posted this 20 June 2026
This behavior can sometimes occur due to configuration conflicts or missing permissions. I was comparing a few iOS execution solutions recently and came across a guide that explains the setup process in a simple way:
Delta iOS Executor guide
Worth checking if you're troubleshooting similar issues.
This behavior can sometimes occur due to configuration conflicts or missing permissions. I was comparing a few iOS execution solutions recently and came across a guide that explains the setup process in a simple way: [Delta iOS Executor][1] guide Worth checking if you're troubleshooting similar issues. [1]: https://deltaiosaxecutor.com/
deltaios439
deltaios439 posted this 13 July 2026
It sounds like the issue could be related to the template or page builder not properly loading the editing interface after a recent update or cache conflict. I would first clear the CMS and browser cache, then check whether the module is hidden in the layout or disabled by a plugin/theme conflict. If the problem started after an update, rolling back or comparing recent changes may also help. While troubleshooting this kind of issue, I often look for alternative tools and workflows that can save time if a builder becomes unreliable. I found this useful overview of different options: https://deltaios.us/alternatives. Hopefully, you're able to restore the missing module and article edit button without having to rebuild the page from scratch.
nowwatchonlinetv
nowwatchonlinetv posted this yesterday
Verity Mod for Minecraft adds new gameplay features, mechanics, Verity Mod Minecraft items, and experiences to the game. It can make survival more interesting by introducing fresh challenges, content, exploration, and customization options.
Verity Mod for Minecraft adds new gameplay features, mechanics, [Verity Mod Minecraft][1] items, and experiences to the game. It can make survival more interesting by introducing fresh challenges, content, exploration, and customization options. [1]: https://veritymodmc.com/
nowwatchonlinetv
ARMSX3 is a PlayStation 3 emulator project designed to run PS3 games on compatible devices. It aims to recreate PS3 hardware, graphics, audio, and controls through software for gaming.
[ARMSX3 is a PlayStation 3 emulator][1] project designed to run PS3 games on compatible devices. It aims to recreate PS3 hardware, graphics, audio, and controls through software for gaming. [1]: https://armsx3.net/
nowwatchonlinetv
Fold Craft Launcher is an Android application that helps users run Minecraft Java Edition on mobile devices. It supports customization, modding, performance settings, controls, and different Minecraft versions for gaming.
[Fold Craft Launcher][1] is an Android application that helps users run Minecraft Java Edition on mobile devices. It supports customization, modding, performance settings, controls, and different Minecraft versions for gaming. [1]: https://foldcraftlauncher.org/
