Current version: 1.0.161
Startup version file: 0
======== Proxy Settings ========
FTPPassive -> 1
AppleProxyConfigurationSelected -> 2
ProxyAutoDiscoveryEnable -> 0
ExcludeSimpleHostnames -> 0
SCOPED -> {
en1 = {
AppleProxyConfigurationSelected = 2;
ExcludeSimpleHostnames = 0;
FTPPassive = 1;
ProxyAutoDiscoveryEnable = 0;
======== END: Proxy Settings ========
======== Check HTTP ========
Check url http://127.0.0.1:12080/ ...
Unknown ERROR!
Check url http://127.0.0.1:12080/startup.php?browser=1&suffix=_4103008009 ...
Unknown ERROR!
======== END: Check HTTP ========
======== Content of file /Applications/Themler.app/Contents/Resources/logs/StartThemler.log ========
Start Themler...
Create user directories...
Checking MySQL status...
/Applications/Themler.app/Contents/LAMP/mysql/bin/mysqladmin: connect to server at 'localhost' failed
error: 'Can't connect to local MySQL server through socket '/Applications/Themler.app/Contents/Resources/db_data/mysql.sock' (2)'
Check that mysqld is running and that the socket: '/Applications/Themler.app/Contents/Resources/db_data/mysql.sock' exists!
MySQL start...
(48)Address already in use: AH00072: make_sock: could not bind to address [::]:12080
(48)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:12080
no listening sockets available, shutting down
AH00015: Unable to open logs
Apache started... OK
MacOS version is bigger than 10.10.5
======== End of file /Applications/Themler.app/Contents/Resources/logs/StartThemler.log ========
Unable to find file /Applications/Themler.app/Contents/Resources/logs/startup.php.log
Unable to find file /Applications/Themler.app/Contents/Resources/logs//apache/error_log
======== Content of file /Applications/Themler.app/Contents/Resources/logs//mysqld.log ========
======== End of file /Applications/Themler.app/Contents/Resources/logs//mysqld.log ========
======== Content of file /Applications/Themler.app/Contents/Resources/logs//mysqld.err ========
160118 16:15:45 [Note] /Applications/Themler.app/Contents/LAMP/mysql/bin/mysqld (mysqld 5.5.47-log) starting as process 37620 ...
160118 16:15:45 [Warning] Setting lower_case_table_names=2 because file system for /Applications/Themler.app/Contents/Resources/db_data/user_data/ is case insensitive
160118 16:15:46 InnoDB: The InnoDB memory heap is disabled
160118 16:15:46 InnoDB: Mutexes and rw_locks use GCC atomic builtins
160118 16:15:46 InnoDB: Compressed tables use zlib 1.2.5
160118 16:15:46 InnoDB: Initializing buffer pool, size = 128.0M
160118 16:15:46 InnoDB: Completed initialization of buffer pool
160118 16:15:46 InnoDB: highest supported file format is Barracuda.
160118 16:15:47 InnoDB: Waiting for the background threads to start
160118 16:15:48 InnoDB: 5.5.47 started; log sequence number 1595675
160118 16:15:49 [Note] Server hostname (bind-address): '0.0.0.0'; port: 12306
160118 16:15:49 [Note] - '0.0.0.0' resolves to '0.0.0.0';
160118 16:15:49 [Note] Server socket created on IP: '0.0.0.0'.
160118 16:15:50 [Note] Event Scheduler: Loaded 0 events
160118 16:15:50 [Note] /Applications/Themler.app/Contents/LAMP/mysql/bin/mysqld: ready for connections.
Version: '5.5.47-log' socket: '/Applications/Themler.app/Contents/Resources/db_data/mysql.sock' port: 12306 Only for Themler
======== End of file /Applications/Themler.app/Contents/Resources/logs//mysqld.err ========
Unable to find file /Users/Hughes1960/Documents/../Library/Themler/hd_data/cms/startup/_logs/cms.log
Current version: 1.0.161 Startup version file: 0 ======== Proxy Settings ======== FTPPassive -> 1 AppleProxyConfigurationSelected -> 2 ProxyAutoDiscoveryEnable -> 0 ExcludeSimpleHostnames -> 0 __SCOPED__ -> { en1 = { AppleProxyConfigurationSelected = 2; ExcludeSimpleHostnames = 0; FTPPassive = 1; ProxyAutoDiscoveryEnable = 0; }; } ======== END: Proxy Settings ======== ======== Check HTTP ======== Check url http://127.0.0.1:12080/ ... Unknown ERROR! Check url http://127.0.0.1:12080/startup.php?browser=1&suffix=_4103008009 ... Unknown ERROR! ======== END: Check HTTP ======== ======== Content of file /Applications/Themler.app/Contents/Resources/logs/StartThemler.log ======== Start Themler... Create user directories... Checking MySQL status... /Applications/Themler.app/Contents/LAMP/mysql/bin/mysqladmin: connect to server at 'localhost' failed error: 'Can't connect to local MySQL server through socket '/Applications/Themler.app/Contents/Resources/db_data/mysql.sock' (2)' Check that mysqld is running and that the socket: '/Applications/Themler.app/Contents/Resources/db_data/mysql.sock' exists! MySQL start... (48)Address already in use: AH00072: make_sock: could not bind to address [::]:12080 (48)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:12080 no listening sockets available, shutting down AH00015: Unable to open logs Apache started... OK MacOS version is bigger than 10.10.5 ======== End of file /Applications/Themler.app/Contents/Resources/logs/StartThemler.log ======== Unable to find file /Applications/Themler.app/Contents/Resources/logs/startup.php.log Unable to find file /Applications/Themler.app/Contents/Resources/logs//apache/error_log ======== Content of file /Applications/Themler.app/Contents/Resources/logs//mysqld.log ======== ======== End of file /Applications/Themler.app/Contents/Resources/logs//mysqld.log ======== ======== Content of file /Applications/Themler.app/Contents/Resources/logs//mysqld.err ======== 160118 16:15:45 [Note] /Applications/Themler.app/Contents/LAMP/mysql/bin/mysqld (mysqld 5.5.47-log) starting as process 37620 ... 160118 16:15:45 [Warning] Setting lower_case_table_names=2 because file system for /Applications/Themler.app/Contents/Resources/db_data/user_data/ is case insensitive 160118 16:15:46 InnoDB: The InnoDB memory heap is disabled 160118 16:15:46 InnoDB: Mutexes and rw_locks use GCC atomic builtins 160118 16:15:46 InnoDB: Compressed tables use zlib 1.2.5 160118 16:15:46 InnoDB: Initializing buffer pool, size = 128.0M 160118 16:15:46 InnoDB: Completed initialization of buffer pool 160118 16:15:46 InnoDB: highest supported file format is Barracuda. 160118 16:15:47 InnoDB: Waiting for the background threads to start 160118 16:15:48 InnoDB: 5.5.47 started; log sequence number 1595675 160118 16:15:49 [Note] Server hostname (bind-address): '0.0.0.0'; port: 12306 160118 16:15:49 [Note] - '0.0.0.0' resolves to '0.0.0.0'; 160118 16:15:49 [Note] Server socket created on IP: '0.0.0.0'. 160118 16:15:50 [Note] Event Scheduler: Loaded 0 events 160118 16:15:50 [Note] /Applications/Themler.app/Contents/LAMP/mysql/bin/mysqld: ready for connections. Version: '5.5.47-log' socket: '/Applications/Themler.app/Contents/Resources/db_data/mysql.sock' port: 12306 Only for Themler ======== End of file /Applications/Themler.app/Contents/Resources/logs//mysqld.err ======== Unable to find file /Users/Hughes1960/Documents/../Library/Themler/hd_data/cms/startup/_logs/cms.log
