Hiya
I would like to build a template that has the header fixed to the top of the page, on top of a module position so that on each page, I can change images, video, scroller etc, that is under the header.
Do you have a video explain how to create that sort of layout and how to add the section, layout container etc?
There are lots of templates with this sort of design but I can't find how they get the section/container to be under the header.
Hiya I would like to build a template that has the header fixed to the top of the page, on top of a module position so that on each page, I can change images, video, scroller etc, that is under the header. Do you have a video explain how to create that sort of layout and how to add the section, layout container etc? There are lots of templates with this sort of design but I can't find how they get the section/container to be under the header. Thank you
