Section Bugs - Icon effects broken when adding link
john106
john106 posted this 20 January 2016
When inserting a section with icons (the dog, cat and fish sample, or any section with icons), the effects assigned to the icon get wiped out after a link is assigned. See attached pics. Even if we insert any icon, anywhere on the page and assign it a default effect (shadow for example), hover effect (like shift up 10px), it breaks the effect and the icon after a link is added to that icon.
To make matters worse, the icon disappears from the editor after the preview is closed!?!?
Not sure how to fix this. Happens on any browser we try to preview the page on. Any way to fix this? Tried re-assigning the effects but it still breaks when a link exists for the icon.
Before a link is added
Adding a link to the icon
Effects are gone and hover effect no longer works
Icon is gone after preview is closed
When inserting a section with icons (the dog, cat and fish sample, or any section with icons), the effects assigned to the icon get wiped out after a link is assigned. See attached pics. Even if we insert any icon, anywhere on the page and assign it a default effect (shadow for example), hover effect (like shift up 10px), it breaks the effect and the icon after a link is added to that icon. To make matters worse, the icon disappears from the editor after the preview is closed!?!? Not sure how to fix this. Happens on any browser we try to preview the page on. Any way to fix this? Tried re-assigning the effects but it still breaks when a link exists for the icon. ![Before a link is added][1] ![Adding a link to the icon][2] ![Effects are gone and hover effect no longer works][3] ![Icon is gone after preview is closed][4] [1]: http://www.smithwickcrossinghoa.org/tmp/1.jpg [2]: http://www.smithwickcrossinghoa.org/tmp/2.jpg [3]: http://www.smithwickcrossinghoa.org/tmp/3.jpg [4]: http://www.smithwickcrossinghoa.org/tmp/4.jpg
6 Comments
DouzanStudio
DouzanStudio posted this 20 January 2016
It happens to me too in wordpress , In html it works fine.
Support Team posted this 21 January 2016
Thank you for reporting the issue. I have forwarded it to our developers.
Hello, Thank you for reporting the issue. I have forwarded it to our developers. Sincerely, Nettie, BillionDigital Team
jonnimunki
jonnimunki posted this 28 January 2016
I also have this issue. Once I add a hyperlink to icons in wordpress it sets its own style, can't change it. if I do it just reverts once i refresh the content. Only seems to be a problem for the content, not the template.
really annoying. had to spend time finding the icons on the web and exporting them from illustrator as png instead, then adding hyperlink to image.
Loving the new version of themler besides this though! thanks, keep the updates coming!
I also have this issue. Once I add a hyperlink to icons in wordpress it sets its own style, can't change it. if I do it just reverts once i refresh the content. Only seems to be a problem for the content, not the template. really annoying. had to spend time finding the icons on the web and exporting them from illustrator as png instead, then adding hyperlink to image. Loving the new version of themler besides this though! thanks, keep the updates coming!
john106
john106 posted this 28 January 2016
It's definitely a problem here for content AND the template. It breaks no matter what when a link is assigned to the icon.
Support Team posted this 03 March 2016
The issue if fixed and the fix is included into the latest Beta update - version 217.
Hello, The issue if fixed and the fix is included into the latest Beta update - version 217. Sincerely, Nettie, BillionDigital Team
kanew9162
kanew9162 posted this 19 May 2025
That’s definitely a frustrating issue, especially when hover effects are a key part of the design experience. It might be worth checking if there's a conflict in your CSS or JS that's overriding icon styles once wrapped in a hyperlink. Also, for anyone working on gear-related visuals or setups, this best fishing line guide might help test visual clarity and styling consistency in similar layouts. Let me know if adjusting z-index or display properties worked for you!
That’s definitely a frustrating issue, especially when hover effects are a key part of the design experience. It might be worth checking if there's a conflict in your CSS or JS that's overriding icon styles once wrapped in a hyperlink. Also, for anyone working on gear-related visuals or setups, this [best fishing line guide][1] might help test visual clarity and styling consistency in similar layouts. Let me know if adjusting z-index or display properties worked for you! [1]: https://pickfishingline.com
