what have I to do that the style I made with Themler is shown in the frontend? I inserted the " vmenu" suffix in my Joomla module as described in the forum. But the vertical menu only are normal links without buttons and without the "right" style.
The vertical menu also isn't shown in Themler, only the module position is shown - without any links or buttons.
Thank you.
Hi, what have I to do that the style I made with Themler is shown in the frontend? I inserted the " vmenu" suffix in my Joomla module as described in the forum. But the vertical menu only are normal links without buttons and without the "right" style. The vertical menu also isn't shown in Themler, only the module position is shown - without any links or buttons. Thank you.Last edited 21 January 2016 by axa
