I cannot locate in Themler where I can control what displays on what Template.
For example:
I build the theme all in the Home template. Then I select the Page template from the drop down menu and start making changes, and those changes are also changed on the Home template. I do not want this.
I remember in past versions I could control this. How can I control the templates in this latest version?
I cannot locate in Themler where I can control what displays on what Template. **For example:** I build the theme all in the **Home template**. Then I select the **Page template** from the drop down menu and start making changes, and those changes are also changed on the **Home template**. I do not want this. I remember in past versions I could control this. How can I control the templates in this latest version? Thanks
