Getting back the Theme into Themler
Karschten
Karschten posted this 24 January 2016
Dear all,
basically I have the problem that I cannot re-import my Template for Joomla into Themler because I didn't know/realize (as the other posts say) that I have to use the "include" option at every export if I want to continue.
I started intensive working with Themler in the last quarter of 2015 and created a theme successfully into a stage where I wanted to test this template on a real webpage accessing from several computers.
However everthing worked but my computer: shortly after launching the tests the computer broke down and I wasn't able to restore anything but my copies from external devices.
As I did export the Theme without the "including Themler" option (at least I have a copy of the original export file; no changes done) - is there any chance to get back to this template for continuing my work or do I have to start at 0?
Many tanks in advance for your time and helpful advises
**Dear all,** basically I have the problem that I *cannot re-import* my Template for Joomla into Themler because I didn't know/realize *(as the other posts say)* that I have to use the "include" option at every export if I want to continue. I started intensive working with Themler in the last quarter of 2015 and created a theme successfully into a stage where I wanted to test this template on a real webpage accessing from several computers. However everthing worked but my computer: shortly after launching the tests the computer broke down and I wasn't able to restore anything but my **copies** from **external devices**. As I did export the Theme without the "including Themler" option (at least I have a copy of the original export file; no changes done) - is there any **chance** to get back to this template for **continuing** my **work** or do I have to start at 0? Many tanks in advance for your time and helpful advises
15 Comments
Support Team posted this 25 January 2016
Unfortunately there is no possibility to import such template. It requires to include the editor in order to be imported into the application.
Hi, Unfortunately there is no possibility to import such template. It requires to include the editor in order to be imported into the application. Sincerely, Hella
Karschten
Karschten posted this 01 November 2019
Dear Hella,
Hello all,
after exchanging my laptop / noteboook to a modern desktop pc I am failing to import Themler zip folder to Themler Desktop application.
After facing above mentioned troubles in 2016 I always exported the theme two times, one witout additonal themler data (for webpage use) and one edition with ticked "include themler" for later imports as now.
Trying to import this zip file that should include Themler is giving me an error message as attached. Maybe you can help with this problem to go on working with the Template creation.
Sincerely
Waennefredder
Dear Hella, Hello all, after exchanging my laptop / noteboook to a modern desktop pc I am failing to import Themler zip folder to Themler Desktop application. After facing above mentioned troubles in 2016 I always exported the theme two times, one witout additonal themler data (for webpage use) and one edition with ticked "include themler" for later imports as now. Trying to import this zip file that should include Themler is giving me an error message as attached. Maybe you can help with this problem to go on working with the Template creation. Sincerely Waennefredder
alexarafatonline
alexarafatonline posted this 28 March 2025
I’ve had a similar issue before where I forgot to include the necessary options during export, and I had to start over. Unfortunately, if the "include" option wasn’t selected, it can be tough to recover the template. It might be worth checking with Themler support, though. On a lighter note, I had a similar "start over" moment while playing BitLife Mod APK, where I messed up a life choice and thought I had to begin again, but somehow ended up with an unexpected win! It’s always good to back things up next time.
I’ve had a similar issue before where I forgot to include the necessary options during export, and I had to start over. Unfortunately, if the "include" option wasn’t selected, it can be tough to recover the template. It might be worth checking with Themler support, though. On a lighter note, I had a similar "start over" moment while playing [BitLife Mod APK][1], where I messed up a life choice and thought I had to begin again, but somehow ended up with an unexpected win! It’s always good to back things up next time. [1]: https://blifemodapk.com/
cloudstacksuper
cloudstacksuper posted this 16 August 2025
If you exported without the "include Themler" option, sadly you can’t re-import it back into Themler for editing. What you still have is the compiled Joomla template, which works fine on your site but isn’t editable inside Themler anymore. The only way to continue designing in Themler is to rebuild the project from scratch or from a backup that included the Themler files.
For a break from technical work, a lot of people try simple open-world games like Super Bear Adventure Mod APK, which gives a relaxing way to explore and play: https://superbearadvapk.com/
If you exported without the "include Themler" option, sadly you can’t re-import it back into Themler for editing. What you still have is the compiled Joomla template, which works fine on your site but isn’t editable inside Themler anymore. The only way to continue designing in Themler is to rebuild the project from scratch or from a backup that included the Themler files. For a break from technical work, a lot of people try simple open-world games like Super Bear Adventure Mod APK, which gives a relaxing way to explore and play: https://superbearadvapk.com/
faroob348
faroob348 posted this 19 August 2025
Restoring a theme in Themler usually involves re-importing the backup files or checking the saved project within the software. This process is similar to how players enjoy bringing back progress in Cricket League APK, where unlimited coins, rewards, and exciting features keep everything running smoothly. Just like Themler helps you recover your design work, Cricket League APK ensures a seamless experience for cricket fans who want consistent updates and engaging gameplay.
Restoring a theme in Themler usually involves re-importing the backup files or checking the saved project within the software. This process is similar to how players enjoy bringing back progress in [Cricket League APK][1], where unlimited coins, rewards, and exciting features keep everything running smoothly. Just like Themler helps you recover your design work, Cricket League APK ensures a seamless experience for cricket fans who want consistent updates and engaging gameplay. [1]: http://circketleagueapk.com
geometrydash2io.io
geometrydash2io.io posted this 20 August 2025
That’s tough—unfortunately without the 'include Themler' option, you usually Geometry Dash can’t re-import to continue editing. You can still use the exported theme on Joomla, but for editing in Themler you may need to rebuild parts of it
That’s tough—unfortunately without the 'include Themler' option, you usually [Geometry Dash][1] can’t re-import to continue editing. You can still use the exported theme on Joomla, but for editing in Themler you may need to rebuild parts of it [1]: https://geometrydash2.io
micheal65ho
micheal65ho posted this 21 August 2025
Restoring a theme in Themler is often a matter of re-importing project files, checking compatibility, and ensuring all assets are correctly linked. Themler’s flexible design tools make it easier to recover and continue customization without losing your progress. Much like enhancing user experience in simulation platforms such as BUSSID mod apk, attention to detail and proper setup play a key role in achieving smooth performance and a professional outcome.
Restoring a theme in Themler is often a matter of re-importing project files, checking compatibility, and ensuring all assets are correctly linked. Themler’s flexible design tools make it easier to recover and continue customization without losing your progress. Much like enhancing user experience in simulation platforms such as [BUSSID mod apk][1], attention to detail and proper setup play a key role in achieving smooth performance and a professional outcome. [1]: https://bussimulateindoapk.pro/
seoaza7
seoaza7 posted this 21 August 2025
Getting back the Theme into Themler can be a smooth process if you back up your files and settings properly. Many users treat it just like reinstalling a favorite app or game, similar to how gamers revisit Hill Climb Racing 2 mod apk for enhanced features. With the right steps, restoring your theme keeps your design consistent and easy to manage.
Getting back the Theme into Themler can be a smooth process if you back up your files and settings properly. Many users treat it just like reinstalling a favorite app or game, similar to how gamers revisit [Hill Climb Racing 2 mod apk][1] for enhanced features. With the right steps, restoring your theme keeps your design consistent and easy to manage. [1]: https://hilclimbapk.com/hill-climb-racing-2-mod-apk/
olivegarden2
olivegarden2 posted this 25 August 2025
If you’re working on getting back the Theme into Themler, the process often requires re-importing or restoring the design files carefully. Many developers also take this chance to refresh their layouts, much like browsing through the Olive Garden menu where you can explore different options such as pasta, soups, and salad combinations. Keeping backups and testing compatibility ensures your theme restoration
If you’re working on getting back the Theme into Themler, the process often requires re-importing or restoring the design files carefully. Many developers also take this chance to refresh their layouts, much like browsing through the [Olive Garden menu][1] where you can explore different options such as pasta, soups, and salad combinations. Keeping backups and testing compatibility ensures your theme restoration [1]: http://olive-gardan.com
Karschten
Karschten posted this 25 August 2025
Please can somebody close this question as those (probably) spam is annoying. Or can I do this on my own, @mods?
alimohammed26919
alimohammed26919 posted this 16 October 2025
“Thanks for this useful explanation! I was facing a similar issue — restoring themes can be tricky sometimes. By the way, for those interested in gaming, check out my site: https://leaguecricketmodapk.com/
— It’s a fun and competitive app that many enjoy. Hope more users benefit from both these guides!”
“Thanks for this useful explanation! I was facing a similar issue — restoring themes can be tricky sometimes. By the way, for those interested in gaming, check out my site: https://leaguecricketmodapk.com/ — It’s a fun and competitive app that many enjoy. Hope more users benefit from both these guides!”
pixelcarracerpro1
pixelcarracerpro1 posted this 08 November 2025
Pixel Car Racer Mod iOS lets iPhone and iPad users enjoy the modded version of the game with all cars, money, and parts unlocked. You can customize your vehicles freely, tune engines, and race without limits, just like the Android version, but optimized for iOS devices.
[Pixel Car Racer Mod iOS][1] lets iPhone and iPad users enjoy the modded version of the game with all cars, money, and parts unlocked. You can customize your vehicles freely, tune engines, and race without limits, just like the Android version, but optimized for iOS devices. [1]: https://pixelcarracer.pro/pixel-car-racer-mod-ios/
playpixelcarracer
playpixelcarracer posted this 18 November 2025
Pixel Car Racer Mod APK with unlimited money lets you unlock any car, upgrade every part, and customize your builds without waiting. You can jump straight into drag or street racing with fully tuned vehicles and enjoy all premium features for free. It’s the easiest way to enjoy the game without limits.
[Pixel Car Racer Mod APK with unlimited money][1] lets you unlock any car, upgrade every part, and customize your builds without waiting. You can jump straight into drag or street racing with fully tuned vehicles and enjoy all premium features for free. It’s the easiest way to enjoy the game without limits. [1]: https://playpixelcarracer.com/
attouguiessam
attouguiessam posted this 05 January 2026
It seems you're having trouble restoring an old Joomla template in Themler—if the original export file didn't use the "include Themler" option, unfortunately, it's not possible to continue editing in Themler without starting from scratch.
By the way, if you want to relax after your design work, try playing FNF mods—it's both entertaining and a great way to practice rhythm!
It seems you're having trouble restoring an old Joomla template in Themler—if the original export file didn't use the "include Themler" option, unfortunately, it's not possible to continue editing in Themler without starting from scratch. By the way, if you want to relax after your design work, try playing [FNF mods][1]—it's both entertaining and a great way to practice rhythm! [1]: https://fnfmods.io/
mattshma13
mattshma13 posted this 05 January 2026
You are doing a right choice! you could play some brainrot games after finish your work
You are doing a right choice! you could play some [brainrot][1] games after finish your work [1]: https://abrainrot.com
