when I work more than a website I have the following problem:
"The website next to a first processing, inherits the characteristics of our old website"
I have one question regarding the construction of the structure of a website (wordpress) with Themler;
I open a session to make the structure of a web site with certain features;
These features relate to the header, body and footer area; then except for my work;
When I open again Themler to work another website the basic structure that I open, brought along the features that I created in the previous website
to eliminate the characteristics above, I have to change in part Themler front-end and partly in wordpress admin panel;
Also that way if I have to re-open the previous web site I can not find the property that I have made, but I find the structure of the second website;
It would seem as if in Themler, I can work a website one by one, and then I can keep those characteristics only if export to zip files and load the theme in wordpress online
I do something wrong? or it does so?
Best regards
Hello, when I work more than a website I have the following problem: "The website next to a first processing, inherits the characteristics of our old website" I have one question regarding the construction of the structure of a website (wordpress) with Themler; I open a session to make the structure of a web site with certain features; These features relate to the header, body and footer area; then except for my work; When I open again Themler to work another website the basic structure that I open, brought along the features that I created in the previous website to eliminate the characteristics above, I have to change in part Themler front-end and partly in wordpress admin panel; Also that way if I have to re-open the previous web site I can not find the property that I have made, but I find the structure of the second website; It would seem as if in Themler, I can work a website one by one, and then I can keep those characteristics only if export to zip files and load the theme in wordpress online I do something wrong? or it does so? Best regards
