Slideshow
freds1959
freds1959 posted this 26 January 2016
it is possible that on each page which is linked to the menu of joomla, can show a different slideshow?
I hope that you understand what I mean.
Greetings Fred
it is possible that on each page which is linked to the menu of joomla, can show a different slideshow? I hope that you understand what I mean. Greetings Fred
10 Comments
Support Team posted this 27 January 2016
You can position slideshow inside the Content section within each page when editing the content in Themler. That will include the slider into the page content and it'll appear only on that particular page.
Hi, You can position slideshow inside the Content section within each page when editing the content in Themler. That will include the slider into the page content and it'll appear only on that particular page. Sincerely, Hella
freds1959
freds1959 posted this 27 January 2016
Thanks for your answer, But have you an example in to the documents I cannot find the right solution.
Fred
Thanks for your answer, But have you an example in to the documents I cannot find the right solution. Sincerely, Fred
Have a look to the screen shot:
Drag the slider within the Content section.
Hi, Have a look to the screen shot: !insert-content.png! Drag the slider within the Content section. Sincerely, Hella
freds1959
Thanks that's made sense.
Fred
Thanks that's made sense. Sincerely, Fred
Support Team posted this 28 January 2016
You are welcome.
freds1959
freds1959 posted this 30 January 2016
Hallo Hella,
I am back again but I manage now home page has his own slideshow, but now has every page or post the same slider and what I want is that on every page or post an different slideshow is. I have put two snapshots. The difficult part is how can I connect to the menu the right slideshow. Have you a good example how to do this.
Fred
Hallo Hella, I am back again but I manage now home page has his own slideshow, but now has every page or post the same slider and what I want is that on every page or post an different slideshow is. I have put two snapshots. The difficult part is how can I connect to the menu the right slideshow. Have you a good example how to do this. Sincerely, Fred
Support Team posted this 01 February 2016
If the slider is present in all pages, that means that you have added it not in the content, but above it. Please provide an access to your site so we could see the problem.
The basic order is like this: you add a page from the Joomla back end. Then open that page within Themler and add the slider within the Content area.
Hi, If the slider is present in all pages, that means that you have added it not in the content, but above it. Please provide an access to your site so we could see the problem. The basic order is like this: you add a page from the Joomla back end. Then open that page within Themler and add the slider within the Content area. Sincerely, Hella
nezarmsm
nezarmsm posted this 20 February 2017
How can I make the slide show or the title of modules hyperlink , the title and the module link can't be open
nezarmsm
this is a print screen
Support Team posted this 21 February 2017
Slider
You may locate the HTML control inside Slide and convert it into HTML link, e.g.:
Module title
Unfortunately it cannot be converted into link.
Hello, Slider You may locate the HTML control inside Slide and convert it into HTML link, e.g.: !SliderLink.png! Module title Unfortunately it cannot be converted into link. regards, Aileen
