posted this
25 December 2014
Once a theme has been designed, do you need to keep the special themler module enabled?
You need to keep it enabled only if you're going to edit theme in Themler in the future. Without this module you will not be able to load this theme in Themler.
Will the drupal theme operate like an ordinary drupal theme?
In general yes, this is ordinary Drupal theme.
Does it support sub theming?
The subtheme may not work properly because the structure of the theme is quite advanced.
I'll ask our developers is there is a way to create full-functional subtheme.
