For some defferent templates, I use the same layout/design as footer.
Is there any possibility I can create my own section.
So I don't need to design it over and over again, but just can import?
Yes, you can export a section. Use the Export option under the Section options in the ribbon. Then use Load in any other section to import that one.
Good morning Hella
I don't mean an existing section.
for example, I created my own footer, which I want to use also in other sites.
The creation is from scratch. Can I export my own design as a section, just to use for myself?
Greetings
Good morning Hella I don't mean an existing section. for example, I created my own footer, which I want to use also in other sites. The creation is from scratch. Can I export my own design as a section, just to use for myself? GreetingsThat should be a section from the beginning. So add a blank section and position the footer within that section. Then you could export it and use in other templates.
