Hide left sidebar from posts on phone
jansen.marcus
jansen.marcus posted this 02 February 2016
Hey,
I would like to know if it's possible from within Themler to hide the left sidebar on a post template (not on the home template), but only for phones (not for desktop, laptop, tablet)?
Can anyone give me some advise?
Mark
Hey, I would like to know if it's possible from within Themler to hide the left sidebar on a post template (not on the home template), but only for phones (not for desktop, laptop, tablet)? Can anyone give me some advise? Regards, Mark
Support Team posted this 02 February 2016
If you disable the sidebar for the phone view on the Post template, it will be disabled on all the other templates. So for that you may consider removing the original sidebar from the Post template, then add a column and insert the widget area in it. Then you will be able to edit the options of that column (sidebar) doe the Post template only.
Hi, If you disable the sidebar for the phone view on the Post template, it will be disabled on all the other templates. So for that you may consider removing the original sidebar from the Post template, then add a column and insert the widget area in it. Then you will be able to edit the options of that column (sidebar) doe the Post template only. Sincerely, Hella
jansen.marcus
Hi Hello,
Thanks for your approach.
I've tried this in my test environment and it seems to be de solution I'm looking for.
Thanks a lot!
Mark
Hi Hello, Thanks for your approach. I've tried this in my test environment and it seems to be de solution I'm looking for. Thanks a lot! Mark
You are welcome.
