Como posso instalar novas fontes de texto?
Fabiano
Fabiano posted this 03 February 2016
Como posso instalar novas fonts de texto no themler pois preciso adicionar novas fonts ao mesmo site
Support Team posted this 04 February 2016
If you can not find the desired font under the list of the Google Fonts, then you can consider using the following instructions to add any font inside the template:
https://css-tricks.com/snippets/css/using-font-face/
Hi, If you can not find the desired font under the list of the Google Fonts, then you can consider using the following instructions to add any font inside the template: https://css-tricks.com/snippets/css/using-font-face/ Sincerely, Hella
